wifi6-IPQ5018-QCN9074-2T2R-2.5G-ETH-port-802.11AX-wallys
2022年04月26日 10:31 发布者:wallyswifi
wifi6-IPQ5018-QCN9074-2T2R-2.5G-ETH-port-802.11AX-wallysDual-core ARM 64bit A53@1.0GHz Processor512MB DDRL3L System Memory4MB NOR Flash, 128MB NAND Flash2x2 On-board 2.4GHz radio,up to 573Mbps physical Data RateSupport BT5.1Two PCIe2.0 connector can support QCN90xx production
Absolute Maximum Rating
Parameter
RatingUnit
Supply Voltage
12V
Operating Temperature Range
-40 to +70oC
Storage Temperature Range
-45 to +105oC
Operating Humidity Range
5 to +95 (non-condensing)%
Hardware Specifications
Symbol
Parameter
CPU
Qualcomm-Atheros IPQ5018
CPU Frequency
Dual-core ARM 64 bit A53 @1.0 GHz processor
System Memory
512MB DDR3L 16-bit interface with 32-bit memory bus design
Ethernet Port
4 x 1Gbps Ethernet Ports or 1X2.5Gbps Ethernet Port;
1 x1Gbps Ethernet Port
NGFF Slot
2 X M.2 (NGFF) “E Key” Socket with MiniPCIe 2.0(For WiFi Module)
EMMC
4G/8G(optional)
USB /header
1x USB 3.0 Port
POE
NA
DC Jack
12V power supply
LED header
LED for power ,Wifi strength
Serial Port
support
Wireless
On-board 2x22.4GHz MU-MIMO OFDMA 802.11b/802.11g/802.11n/802.11ax,max 23dBm per chain
2x IPEX Connectors
BluetoothBT5.1
Nor Flash
8MB
Nand Flash
128 MB
DDR
512MB
Dimension
185mm x 116mm
Radio TX Specifications(2412MHz-2482MHz)
Operating ModeData RatePowerTolerance
1 Chain2 Chains
2.4Ghz 802.11ax HE20MCS023dbm26dbm±2dB
MCS123dBm26dBm±2dB
MCS223dBm26dBm±2dB
MCS323dBm26dBm±2dB
MCS423dBm26dBm±2dB
MCS523dBm26dBm±2dB
MCS623dBm26dBm±2dB
MCS722dBm25dBm±2dB
MCS821dBm24dBm±2dB
MCS921dBm24dBm±2dB
MCS1018dBm21dBm±2dB
MCS1117dbm20dbm±2dB
2.4Ghz 802.11ax HE40MCS023dbm26dbm±2dB
MCS123dBm26dBm±2dB
MCS223dBm26dBm±2dB
MCS323dBm26dBm±2dB
MCS423dBm26dBm±2dB
MCS523dBm26dBm±2dB
MCS623dBm26dBm±2dB
MCS722dBm25dBm±2dB
MCS821dBm24dBm±2dB
MCS921dBm24dBm±2dB
MCS1021dBm24dBm±2dB
MCS1119dbm22dbm±2dB
Wallys Communications (Suzhou) Co LTD develops, designs and manufactures wireless communication products, including routers, network cards, AP and antennas. Customization is also supported, mainly for export market, welcome to consult.EMAIL:sales@wallystech.comWEB:https://www.wallystech.com/
