IPQ4019/IPQ4029/OpenWRT-802.11ac-wallys
2022年04月25日 13:07 发布者:wallyswifi
IPQ4019-2T2R-Dual-Band-2-4GHz-5GHz-support-OpenWRT-802.11ac-Wave-2Featuring withindustrial-grade IPQ4019 chipsetIntegrated with 2x 2 5G high powerRadio module and 2x2 2.4G high power Radio moduleSupport 5.180GHz to5.825GHz Frequency Range;Support 2.412GHz to 2.482GHzSupport 2 x 5G MMCX Connectors and 2x2.4G MMCX20MHz/40MHz/80MHz BandwidthSupport 11ABGN/802.11ACRoHS compliance ensure a high levelprotection of human health and the environment from risks that can be posed by
Symbol
Parameter
CPU
IPQ4019(Quad core ARM Cortex A7 at 716.8 MHz)
Antenna Connector
2 x 5G MMCX connectors;2x2.4G MMCX
10/100/1000Mbps
Gigabit Ethernet
2xRJ45
DC Jack
12 power supply
ROHS Compliance
YES
Dimension
65mmx35mm x 16mm
Max Power
12V x 0.8A= 9.6W
Nor Flash
32MB
DDR
256MB
1) Pin41-Pin48 indicates the differential signals of network port 1, which are 0,1,2, and 3 in sequence
2) Pin48 to Pin52, P55 to Pin58 indicates the differential signals of network port 2. The sequence is differential signals 0,1,2, and 3
The schematic diagram of the extended circuit is as follows:
3) Pin64-Pin69 indicates the differential signals of USB3.0 are TX, RX, and HS in sequence
4) Pin 79,80 is a 12V input power signal and the input voltage is in the range of 11v-13v
5) Pin32 -Pin35 indicates the serial port signal, Pin32 indicates the output 3.3V, Pin33, and Pin34 indicates the output input signal
The schematic diagram of the extended circuit is as follows,
Wallys Communications (Suzhou) Co LTD develops, designs and manufactures wireless communication products, including routers, network cards, AP and antennas. Customization is also supported, mainly for export market, welcome to consult.EMAIL:sales@wallystech.comWEB:https://www.wallystech.com/
