Wifi6E-Qualcomm-QCN9074 M-2-E-Key-Interface-802-11ax-wallys
2022年04月21日 11:14    发布者:wallyswifi
Wifi6E-Qualcomm-QCN9074/QCA9882 M-2-E-Key-Interface-802-11ax-wallys
■ Qualcomm Atheros QCN9074■ 6GHz, max 23dBm per chain, up to 4949Mbps■ Single Band 6GHz 4x4 WiFi 6E (802.11ax)■ 4 spatial streams (4SS)■ M.2 E Key Interface■ PCI Express 3.0 Interface
Absolute Maximum Rating
ParameterRatingUnit
Operating Temperature Range-20 to 70oC
Storage Temperature Range-40 to 90oC
Operating Humidity Range5 to +95 (non-condensing)%
Storage Humidity Range0 to +90 (non-condensing)%
Hardware Specifications
Symbol
Parameter
Chipset
WLAN Host Interface
System Memory
2Mbit serial I2C bus EEPROM
Standard Operating Voltage
5V
Operating Systems
QSDK
Host Interface
M.2 E Key
Antenna Cable / Port
4 x MMCX Connectors,4T4R
Frequency Range
5.925GHz-7.125GHz
Data Rates for WALN
Channel Spectrum Widths for WLAN
Support 20/40/80/160MHz at 6GHz
Modulation Techniques
OFDMA: BPSK, QPSK, DBPSK, DQPSK,16-QAM, 64-QAM, 256-QAM,1024-QAM, 4096-QAM
Temperature Range
Operating: -20°C to 70°C, Storage: -40°C to 90°C
Humidity
Operating: 5% to 95% (non-condensing), Storage: Max. 90% (non-condensing)
Certification
TBD
Power Consumption
TBD
Reference Design
PN02.7
Dimensions (WxHxD)
57mm x 63mm x 6mm
Wallys Communications (Suzhou) Co LTD  develops, designs and manufactures wireless communication products, including routers, network cards, AP and antennas. Customization is also supported, The market is global, welcome to consult.EMAIL:sales@wallystech.comWEB:https://www.wallystech.com/
