wallys Routerboard/DR6018V4-wifi6-Qualcomm-IPQ6010-IPQ6018-FAMILY-2T2R-2.5G-ETH-port- 5G-celluar-Modem-802.11ax
2022年03月23日 16:46    发布者:wallyswifi
DR6018
Support OpenWRT, Support:QUECTEL RM500Q-GL&Support:QCN9074 WiFi 6E Card
Support OpenWRT IPQ6010 802.11ax 2x2 2.4G&5G 2.5Gbps Ethernet Port
Qualcomm-Atheros IPQ6010Quad-core ARM 64bit A53 @1.8GHz Processor 1GB DDRL3L System Memory 32MB NOR Flash, 256MB NAND Flash Supports Dynamic Frequency Selection (DFS) 2x2 On-board 2.4GHz radio, up to 573Mbps physical Data Rate 2x2 On-board 5GHz radio, up to 1201Mbps physical Data RateSupport: QUECTEL RM500Q-GLSupport: QCN9074 WiFi 6E Card
Absolute Maximum Rating
Parameter
RatingUnit
Supply Voltage
24V~48V
Operating Temperature Range
-40 to +70oC
Storage Temperature Range
-45 to +105oC
Operating Humidity Range
5 to +95 (non-condensing)%
Hardware Specifications
Symbol
Parameter
CPU
CPU Frequency
Quad-core ARM 64 bit A53 @1.8 GHz processor
System Memory
1GB (2x 512MB) DDR3L 16-bit interface with 32-bit memory bus design
Ethernet Port
1 x 1Gbps Ethernet Ports & POE3 x 1Gbps Ethernet Ports , 1x 2.5Gbps Ethernet Port
NGFF Slot
M.2 (NGFF) “E Key” Socket with MiniPCIe 3.0
SD Card Slot
1x SD Card Slot
USB /header
1x USB 2.0 Port
POE
24V~48V passive POE/Active POE(Suport 802.3bt)
DC Jack
24V power supply
LED header
FFC/FPC Connector
Serial Port
1x Serial Port 4 Pin Connector
Wireless
On-board 2x2 2.4GHz MU-MIMO OFDMA 802.11b/802.11g/802.11n/802.11ax, max 23dBm per chain
On-board 2x2 5GHz MU-MIMO OFDMA 802.11a/n/ac/ax, max 20dBm per chain
4 x MMCX Connectors
Bluetoothoptional
Nor Flash
8-32MB(normally is 8MB)
Nand Flash
256MB
DDR
1GB
Dimension
185mm x 116mm
Radio TX Specifications(5180MHz-5825MHz)
Operating ModeData RatePowerTolerance
1 Chain2 Chains
5Ghz 802.11ax HE20MCS020dBm23dbm±2dB
MCS120dBm23dBm±2dB
MCS220dBm23dBm±2dB
MCS320dBm23dBm±2dB
MCS419dBm22dBm±2dB
MCS518dBm21dBm±2dB
MCS617dBm20dBm±2dB
MCS716dBm19dBm±2dB
MCS815dBm18dBm±2dB
MCS914dBm17dBm±2dB
MCS1013dBm16dBm±2dB
MCS1113dBm16dbm±2dB
5Ghz 802.11ax HE400MCS020dBm23dbm±2dB
MCS120dBm23dBm±2dB
MCS220dBm23dBm±2dB
MCS320dBm23dBm±2dB
MCS419dBm22dBm±2dB
MCS518dBm21dBm±2dB
MCS617dBm20dBm±2dB
MCS716dBm19dBm±2dB
MCS815dBm18dBm±2dB
MCS914dBm17dBm±2dB
MCS1013dBm16dBm±2dB
MCS1113dBm16dbm±2dB
5Ghz 802.11ax HE80MCS020dBm23dbm±2dB
MCS120dBm23dBm±2dB
MCS220dBm23dBm±2dB
MCS320dBm23dBm±2dB
MCS419dBm22dBm±2dB
MCS518dBm21dBm±2dB
MCS617dBm20dBm±2dB
MCS716dBm19dBm±2dB
MCS815dBm18dBm±2dB
MCS914dBm17dBm±2dB
MCS1013dBm16dBm±2dB
MCS1113dBm16dbm±2dB
WEB:https://www.wallystech.com/wifi6 routerWi-Fi 6EWiFi 6802.11acQCN9074/QCN9024/QCN9072/QCA9882/QCA9880/QCN6024IPQ4029/IPQ4019panel antennaomni  antennaWireless Access Point
