wallys Qualcomm-IPQ4019/IPQ4029-DUAL-BAND-802.11AC-WAVE2-MU-MIMO-ONBOARD-WIFI-RADIO-EMBEDDED-BOARD-supporting-LTE
2022年03月21日 14:43 发布者:wallyswifi
Featuring with industrial-grade IPQ4019/IPQ4029 chipset Integrated with 2x 2 5G high power Radio module and 2x2 2.4G high power Radio module Support 4.940GHz to 5.825GHz Frequency RangeSupport 2.400GHz to 2.482GHz Support 2 x 5G MMCX Connectors and 2x2.4G MMCX Support 5MHz/10MHz/20MHz/40MHz/80MHz Bandwidth Support 11ABGN/AC Support fixed data rateRoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicalsOur Firmware supports all the modules of QuectelDR40x9IPQ4019 IPQ4029 ,802.11AC 2x2 2.4G&5G Support all the modules of Quectel
IPQ4019/IPQ4029 2x2 2.4Ghz&5G Support HTTPS
Absolute Maximum Rating
ParameterRatingUnit
Supply Voltage24V~48V
Operating Temperature Range-40 to +70oC
Storage Temperature Range-45 to +105oC
Operating Humidity Range5 to +95 (non-condensing)%
Storage Humidity Range0 to +90 (non-condensing)%
Hardware Specifications
SymbolParameter
CPUIPQ4029(Quad core ARM Cortex A7 at 716.8 MHz)
Antenna Connector2 x 5G MMCX connectors;2x2.4G MMCX
10/100/1000Mbps Gigabit Ethernet2xRJ45
SFP connector1xSFP fiber module connector (optional)
3G/4G connector1xminipcie 3G/4G connector support with two sim card
USB connector1xUSB 3.0 connector
POE24V~48V passive POE
DC Jack24V~48V power supply
ROHS ComplianceYES
Dimension115mm x 105mm x 16mm
Max Power48.1V x 0.180A= 8.658W
Nor Flash2MB~32MB
Nand Flash128MB
DDR256MB~512MB
Radio TX Specifications(5180MHz-5825MHz)
Operating ModeData RatePowerTolerance
1 Chain2 Chains
802.11a6 Mbps27dBm30dbm±2dB
54 Mbps23dBm26dbm±2dB
802.11n HT20MCS0, MCS826dBm29dbm±2dB
MCS7, MCS1522dBm25dbm±2dB
802.11n HT40MCS0, MCS825dBm28dbm±2dB
MCS7, MCS1521dBm24dbm±2dB
802.11acMCS0, MCS10,MCS2025dBm28dbm±2dB
MCS9,MCS19,MCS2919dBm22dbm±2dB
Radio RX Specifications(5180MHz-5825MHz)
Operating ModeData RateSensitivity
802.11a6 Mbps-96dBm
54 Mbps-78dBm
802.11n HT20MCS0, MCS8-93dBm
MCS7, MCS15-73dBm
802.11n HT40MCS0, MCS8-90dBm
MCS7, MCS15-70dBm
802.11AC HT40MCS0, MCS10,MCS20-90dBm
MCS9,MCS19,MCS29-67dBm
802.11AC HT80MCS0, MCS10,MCS20-88dBm
MCS9,MCS19,MCS29-62dBm
Radio TX Specifications(2412MHz-2482MHz)
1 Chain2 Chains
802.11g6 Mbps27dbm30dbm±2dB
54 Mbps25dbm28dbm±2dB
802.11n HT20MCS0, MCS826dbm29dbm±2dB
MCS7, MCS1525dbm28dbm±2dB
802.11n HT40MCS0, MCS826dbm29dbm±2dB
MCS7, MCS1524dbm27dbm±2dB
Radio RXSpecifications(2412MHz-2482MHz)
802.11g6 Mbps-96dBm
54 Mbps-78dBm
MCS7, MCS15-73dBm
MCS7, MCS15-70dBm
Interface MAP
Wallys Communications (Suzhou) Co LTD develops, designs and manufactures wireless communication products, including routers, network cards, AP and antennas. Customization is also supported, mainly for export market, using Qualcomm chipsets, welcome to consult.
EMAIL:sales@wallystech.com
WEB:https://www.wallystech.com/
products:
wifi6 router
wifi 6E
Wi-Fi 6E
Wi-Fi 6
WiFi 6
802.11ax
802.11ac
wireless
QCN9074/QCN9024/QCN9072/QCA9882/QCA9880/QCN6024
IPQ6010/IPQ6018/IPQ6000/IPQ8072/IPQ5018/IPQ8074/IPQ8072A
IPQ4029/IPQ4019
Dipole Antenna
panel antenna
Smart antenna
omni antenna
Wireless Access Point
