DC 15V~150V降压恒压芯片,兼容PN6005,无需改板
2022年03月21日 10:19    发布者:小郑
GENERAL DESCRIPtiON
   SL3150 is a Buck regulator that
provides accurate constant voltage (CV)
regulation without opto-coupler. It has an
integrated 150V MOSFET to simplify the
structure and reduce costs. These features
make it an ideal regulator for off-line low
power applications, such as home
appliances and standby power.
   SL3150 is a green -mode-operation
regulator. Both the peak current and
switching frequency decrease as the load
decreases. This feature provides excellent
efficiency at light load, and improves the
overall average efficiency. SL3150 features
various protections, including thermal
shutdown (OTP), VCC under-voltage
lockout (UVLO), overload protection (OLP),
short-circuit protection (SCP), and open
loop protection.
   SL3150 is offered in SOP7 package.
FEATURES
  Primary-Side CV control.
  Wide input range: 15V~150V
  Integrated 150V/5.0Ω MOSFET and
current source
  < 30mW no-load power consumption
  Fixed 5.0V output voltage
  Up to 400mA output Current
  Low VCC Operating Current
  Frequency foldback
  Limited maximum frequency
  Internally biased VCC
  OTP, UVLO, OLP, SCP, Open loop
APPLICATIONS
  Standby power
  E-bike applications
  Industrial controls
  Consumer electronics
TYPICAL APPLICATION
https://file.elecfans.com/web2/M00/36/D3/pYYBAGI31-2AWSnCAAEHQhi3upc225.png
https://file.elecfans.com/web2/M00/36/D3/pYYBAGI31_-AJ1SRAAGFPDXXoR8721.png
