BCT0104/ET0104/TXS0104 四通道双向电平转换
2022年01月06日 13:45 发布者:LIJINTAO123
供应BCT0104/ET0104/TXS0104 4-Bit Bidirectional Voltage-Level Translator 深圳锦宏世纪科技 李生 18938047300
This two-bit non-inverting translator is a bidirectional voltage-level translator and can be used to establish digital switching compatibility between mixed-voltage systems. It uses two separate configurable power-supply rails, with the A ports supporting operating voltages from 1.65V to 5.5V while it tracks the VCCA supply, and the B ports supporting operating voltages from 2.3V to 5.5V while it tracks the VCCB supply. This allows the support of both lower and higher logic signal levels while providing bidirectional translation capabilities between any of the 1.8V, 2.5V, 3.3V, and 5V voltage nodes.When the output-enable (OE) input is low, all I/Os are placed in the high-impedance state, which significantly reduces the power-supply quiescent current consumption. OE has an internal pull-down current source, as long as VCCA is powered.To ensure the high-impedance state during power up or power down, OE should be tied to GND through a pull-down resistor; the minimum value of the resistor is determined by the current-sourcing capability of the driver.
APPLICATIONSI2C BUSPortable POS SystemsSmart Card ReadersCell-PhonesGPSPortable Communication DevicesFEATURESNo Direction-Control Signal NeededData Rates24Mbps (Push-Pull)
2Mbps (Open-Drain)1.65V to 5.5V on A Ports and 2.3V to 5.5V on B Ports (VCCA ≤ VCCB)VCC Isolation: If Either VCC is at GND, Both Ports are in the High-Impedance StateNo Power-Supply Sequencing Required, Either VCCA or VCCB can be Ramped FirstIOFF: Supports Partial-Power-Down Mode OperationAvailable in QFN3.5x3.5-14L, TQFN3x3-16L package.
