BCT5007 FM低噪声放大器芯片
2022年01月06日 11:36 发布者:LIJINTAO123
供应BCT5007 FM低噪声放大器芯片 深圳锦宏世纪科技 李生 18938047300
BCT5007 is a Low-Noise-Amplifier (LNA), without earphone or telescopic antenna, re-using GSM antenna to receive FM-radio signal. BCT5007 is characterized with low noise, high gain and high linearity. Typical noise figure is 1.2dB and power gain is 21dB. BCT5007 is powered by 2.6V~3.6V supply with typical 2.8V. EN supports 2.8V / 1.8V GPIO input. BCT5007 integrates RF radio switch inside, implementing high impedance under shut-down condition. Shut-down current is less than 0.1μA. BCT5007 is available in slim 2.2mm×2.2mm×1mm SOT363 package. The specified operating free-air temperature ranges from -40℃ to 85℃.
APPLICATIONSMobile phoneMID/PAD with FMMobile audio device
FEATURESWithout any earphone or telescopic antenna receive FM-radio signal through re-using GSM antennaUltra-low noise figure 1.2dBStandard CMOS process technologyHigh power gain of 21dBHigh linearityEN supports 1.8V/2.8V GPIOSupply voltage: 2.6V-3.6VShutdown current:<0.1uA Slim SOT363 package
