适用于隔离式电源的变压器驱动器ZCC6601 替代SN6505
2021年11月30日 10:48 发布者:我心随我
适用于隔离式电源的变压器驱动器ZCC6601 替代SN6505DESCRIPTIONTheZCC6601 is a monolithic oscillator/power-driver, specifically designed forsmall form factor, isolated power supplies in isolated interface applications.It drives a low-profile, center-tapped transformer primary from a 3.3 Vor 5 VDC power supply. The secondary can be wound to provide any isolated voltagebased on transformerturns ratio.TheZCC6601 consists of an oscillator followed by a gate drive circuit thatprovides the complementary output signals to drive the ground referencedN-channel power switches. The internal logic ensures break-before-make actionbetween the two switches.TheZCC6601 is available in a small SOT23-5 package, and is specified for operationat temperatures from –40°C to 125°C. FEATURES• Push-Pull Driver for SmallTransformers• Single 3.3 V or 5 V Supply• High Primary-side Current Drive:– 5 V Supply: 650 mA (max)– 3.3 V Supply: 450 mA (max)• Low Ripple on Rectified OutputPermits SmallOutput Capacitors• Soft start and Current limit• Thermal shutdown• Small 5-pin SOT23 Package• Short circuit protection• Over temperature protection APPLICATIONS• Isolated Interface Power Supply forCAN, RS-485, RS-422, RS-232, SPI, I2C, Low-PowerLAN• Industrial Automation• Process Control• Medical Equipment
