Powerint LCS702HG 150W电源参考设计(RDR239)
2011年10月19日 17:52 发布者:1046235000
Powerint公司的HiperLCS系列LCS702HG集成了多功能控制器,高边和低边栅极驱动器,以及半桥配置的两个功率MOSFET,可节省30多个外接元件,工作频率高达1MHz,20%,50%和100%负载点的平均效率为95%,主要用在高效电源(80PLUS 银,金和白金),LCD TV电源和LED街区和区域照明.本文介绍了HiperLCS系列主要特性,方框图, 150 W 激光打印机电源图以及采用HiperLCSTM LCS702HG的150W LLC高压DC/DC谐振转换器参考设计主要特性,电路图,材料清单和PCB布局图.The HiperLCS is an integrated LLC power stage incorporating a multi-function controller, high-side and low-side gate drivers, plus two power MOSFETs in a half-bridge configuration.
The variable frequency controller provides high efficiency by switching the power MOSFETs at zero voltage (ZVS), eliminating switching losses.
HiperLCS系列主要特性:
• LLC half-bridge power stage incorporating controller, high and low-side gate drives, and high-voltage power MOSFETs
• Eliminates up to 30 external components
• High maximum operating frequency of 1 MHz
• Nominal steady-state operation up to 500 kHz
• Dramatically reduces magnetics size and allows use of SMD ceramic output capacitors
• Precise duty symmetry balances output rectifier current, improving efficiency
• 50% ±0.3% typical at 300 kHz
• Comprehensive fault handling and current limiting
• Programmable brown-in/out thresholds and hysteresis
• Undervoltage (UV) and overvoltage (OV) protection
• Programmable over-current protection (OCP)
• Short-circuit protection (SCP)
• Over-temperature protection (OTP)
• Programmable dead-time for optimized design
• Programmable burst mode maintains regulation at no-load and improves light load efficiency
• Programmable soft-start time and delay before soft-start
• Accurate programmable minimum and maximum frequency limits
• Single package designed for high-power and high-frequency
• Reduces assembly cost and reduces PCB layout loop areas
• Simple single clip attachment to heat sink
• Exposed thermal pad connected to ground potential – no insulators required between package and heat sink
• Staggered pin arrangement for simple PC board routing and high-voltage creepage requirements
• Paired with HiperPFS PFC product gives complete, high efficiency, low part count PSU solutions
HiperLCS系列应用:
• High-efficiency power supplies (80 PLUS Silver, Gold and Platinum)
• LCD TV power supplies
• LED street and area lighting
• Printer power supplies
• Audio amplifier
图1. HiperLCS系列方框图
图2.150 W 激光打印机电源
This document is an engineering report describing a 24 V, 150 W LLC DC-DC converter utilizing a LCS702HG integrated LLC power stage IC. The report and board is intended as a general purpose test platform to demonstrate operation and capabilities of the HiperLCS family of devices.
The design operates from an input voltage range of 300 V to 420 V DC and requires an auxiliary supply of 12 V. The high-voltage DC input in a typical system would be supplied from a PFC stage and the 12 V from system bias or standby supply.
150W电源参考设计主要特性:
Low parts count, low cost, simple resonant (LLC) converter
Integration of controller, high-side and low-side MOSFETS and drivers reduces
component count and design effort
High operating frequency (250 kHz)
Reduces transformer core size (EEL25) and size of converter
Enables ceramic in place of electrolytic output capacitors
High-efficiency
>95% efficiency at full load
>95% average efficiency (20%, 50%, 100% load points)
Capacitive current sense for low power dissipation
Burst mode ensures no-load regulation
图3. 150W电源参考设计外形图
150W电源参考设计指标:
图5.150W电源参考设计电路图
150W电源参考设计材料清单(BOM):
图6. 150W电源变压器电路框图
图7.150W电源PCB布局图(顶层)
图8.150W电源PCB布局图(底层)
详情请见:
http://www.powerint.com/sites/default/files/product-docs/hiperlcs_family_datasheet.pdf
和
http://www.powerint.com/sites/default/files/PDFFiles/rdr239.pdf
xueyao0127 2011年10月20日
学到了非常感谢
学到了非常感谢
非常有用,多谢
