Holtek HT82V863R CCD监控摄影机处理方案
2011年10月14日 17:34 发布者:1640190015
Holtek(盛群半导体)公司的HT82V863R是新一代的 CCD监控摄影机处理器, 采用更精简的 64LQFP封装, 新的影像处理器在低照,色彩及噪声等各项影像处理上,其性能都比 HT82V862R 优秀,提供数字式高动态处理,自动背光补偿及数字式线锁定同步等功能.本文介绍了HT82V863R主要特性,方框图以及系统应用框图.The HT82V863R is a single chip digital image processor for Ye, Cy, Mg and G colour CCD video camera systems. It receives CFA patterns from colour CCDs and generates NTSC/PAL CVBS signals using internal video encoders and the 10-bit DAC. In addition, it also provides an AE/AWB algorithm, timing generation module together with other circuitry. The device contains a microcontroller in which an OTP ROM is integrated internally to implement the basic camera functions such as the AE/AWB algorithm. The video camera system consists of a CDS/AGC/ADC IC (HT82V842A), DSP IC (HT82V863R), Vertical Driver IC (HT82V805) and CCD sensors. It also provides a proprietary function to eliminate so called “line crawl” and automatic CCD defect compensation function to correct up to 30 bad pixels and 4 consequential bad pixels.
HT82V863R主要特性:
• Input: Supports Ye, Mg, Cy, G colour filters for NTSC/PAL, 270K/320K/410K/470K CCD sensors
• Output: NTSC/PAL Analog CVBS
• Automatic CCD Defect compensation Up to 50 bad pixels and 4 consequential bad pixels correction
• Automatic Back Light compensation
• Programmable False Colour suppression
• Programmable High Light suppression
• Programmable Sharpness enhancement
• Programmable Colour Saturation and Hue function
• Programmable Contrast and Brightness function
• Programmable GAMMA curve
• Integrate a 96-step CCD timing generator
• Support AE/AWB algorithm function
• Support OSD function
• Integrate a 2-D DNR function
• Integrate the digital WDR
• Integrate the digital Line Lock function to reduce colour rolling
• Integrate a NTSC/PAL video encoder
• Integrate a 10-bit DAC
• Support CCIR656 digital out
• Integrate a one-channel 6-bit ADC
• Integrate OTP ROM with ISP function for multiple programming codes
• Support Mirror function
• Support a master I2C interface for external EEPROM to store parameters
• Support a slave I2C interface for communication with an external host
• Embedded LVR and POR circuits
• Embedded 3.3V-to-1.8V regulator
• Single 3.3V power supply
• 64/80-LQFP package
图1. HT82V863R方框图
图2. HT82V863R系统应用框图
详情请见:
http://www.holtek.com.tw/pdf/video/ht82v863rv100.pdf
Holtek(盛群半导体)公司的HT82V863R是新一代的CCD监控摄影机处理器, 采用更精简的64LQFP封装, 新的影像处理器在低照,色彩及噪声等各项影像处理上,其性能都比HT82V862R优秀,提供数字式高动态处理,自动背光补偿及数字式线锁定同步等功能。
HT82V863R是一种单芯片数字影像处理器,用于Ye,Cy,Mg 和G彩色CCD摄像机系统。它接收来自彩色CCD的CFA图案,并使用内部视频编码器和10位DAC来生成NTSC / PAL CVBS信号。此外,该器件还提供AE / AWB算法,时序产生模块和其他的电路。该器件包含了一个微控制器,在该微控制器里集成了一个OTP ROM,以实现基本的相机功能,如AE / AWB算法。这一摄像机系统包括一个CDS/AGC/ADC IC(HT82V842A),DSP IC(HT82V863R),垂直驱动IC(HT82V805)和CCD传感器。它还具有专门的功能,以消除所谓的“行爬”,还具备自动CCD缺陷补偿功能,最多可纠正30个坏像素和4个相应的坏像素。
88493
图1 HT82V863R方框图
88492
图2 HT82V863R系统应用框图
HT82V863R主要特性
•输入:NTSC / PAL,270K/320K/410K/470K CCD传感器的Ye,Mg,Cy,G颜色过滤器
•输出:NTSC/ PAL模拟CVBS
•自动CCD缺陷补偿,最多可纠正50个坏像素和4个相应的坏像素
•自动背光补偿
•可编程假彩色抑制
•可编程高光抑制
•可编程的清晰度增强
•可编程的色彩饱和度和色调功能
•可编程的对比度和亮度功能
•可编程gamma曲线
•集成一个96步的CCD时序发生器
•支持AE/AWB算法功能
•支持OSD功能
•集成2-D DNR功能
•集成数字WDR
•集成数字线锁定功能,以减少色彩滚动
•集成NTSC/PAL视频编码器
•集成了一个10位DAC
•支持CCIR656数字
•集成一个通道6位ADC
•集成OTP ROM与ISP功能,用于多种编程代码
•支持镜像功能
•支持一个主I2C接口,用于外部EEPROM,用来来存储参数
•支持一个仆通信I2C接口,用于外部主机的通讯
•嵌入式低电压复位POR电路
•嵌入式3.3V~1.8V稳压器
• 3.3V单电源
• 64/80-LQFP封装
