STM32WLE5CC原理图
2021年11月01日 11:29    发布者:DN1139
电路原理图https://www.stmicroelectronics.com.cn/content/ccc/fragment/product_related/rpn_information/product_circuit_diagram/group0/f6/18/ff/eb/ab/7c/40/db/bd_stm32wlexxx_256k/files/bd_stm32wlexxx_256k.png/jcr:content/translations/en.bd_stm32wlexxx_256k.png
所有功能
[*]Radio
[*]Frequency range: 150 MHz to 960 MHz
[*]Modulation: LoRa®, (G)FSK, (G)MSK and BPSK
[*]RX sensitivity: –123 dBm for 2-FSK(at 1.2 Kbit/s), –148 dBm for LoRa® (at 10.4 kHz, spreading factor 12)
[*]Transmitter high output power, programmable up to +22 dBm
[*]Transmitter low output power, programmable up to +15 dBm
[*]Compliant with the following radio frequency regulations: ETSI EN 300 220, EN 300 113, EN 301 166, FCC CFR 47 Part 15, 24, 90, 101 and the Japanese ARIB STD-T30, T-67, T-108
[*]Compatible with standardized or proprietary protocols such as LoRaWAN®, Sigfox™, W-MBus and more (fully open wireless system-on-chip)
[*]Ultra-low-power platform
[*]1.8 V to 3.6 V power supply
[*]–40 °C to +105 °C temperature range
[*]Shutdown mode: 31 nA (VDD = 3 V)
[*]Standby (+ RTC) mode:360 nA (VDD = 3 V)
[*]Stop2 (+ RTC) mode: 1.07 μA (VDD = 3 V)
[*]Active-mode MCU: < 72 μA/MHz (CoreMark®)
[*]Active-mode RX: 4.82 mA
[*]Active-mode TX: 15 mA at 10 dBm and 87 mA at 20 dBm (LoRa® 125 kHz)
[*]内核
[*]32-bit Arm® Cortex®-M4 CPU
[*]Adaptive real-time accelerator (ART Accelerator) allowing 0-wait-state execution from Flash memory, frequency up to 48 MHz, MPU and DSP instructions
[*]1.25 DMIPS/MHz (Dhrystone 2.1)
[*]Security and identification
[*]Hardware encryption AES 256-bit
[*]True random number generator (RNG)
[*]Sector protection against read/write operations (PCROP, RDP, WRP)
[*]CRC calculation unit
[*]Unique device identifier (64-bit UID compliant with IEEE 802-2001 standard)
[*]96-bit unique die identifier
[*]Hardware public key accelerator (PKA)
[*]Supply and reset management
[*]High-efficiency embedded SMPS step-down converter
[*]SMPS to LDO smart switch
[*]Ultra-safe, low-power BOR (brownout reset) with 5 selectable thresholds
[*]Ultra-low-power POR/PDR
[*]Programmable voltage detector (PVD)
[*]VBAT mode with RTC and 20x32-byte backup registers
[*]clock sources
[*]32 MHz crystal oscillator
[*]TCXO support: programmable supply voltage
[*]32 kHz oscillator for RTC with calibration
[*]High-speed internal 16 MHz factory trimmed RC (± 1 %)
[*]Internal low-power 32 kHz RC
[*]Internal multi-speed low-power 100 kHz to 48 MHz RC
[*]PLL for CPU, ADC and audio clocks
[*]Memories
[*]Up to 256-Kbyte Flash memory
[*]Up to 64-Kbyte RAM
[*]20x32-bit backup register
[*]Bootloader supporting USART and SPI inteRFaces
[*]OTA (over-the-air) firmware update capable
[*]Rich analog peripherals (down to 1.62 V)
[*]12-bit ADC 2.5 Msps, up to 16 bits with hardware oversampling, conversion range up to 3.6 V
[*]12-bit DAC, low-power sample-and-hold
[*]2x ultra-low-power comparators
[*]System peripherals
[*]Semaphores for processor firmware process synchronization
[*]Controllers
[*]2x DMA controller (7 channels each) supporting ADC, DAC, SPI, I2C, LPUART, USART, AES and timers
[*]2x USART (ISO 7816, IrDA, SPI)
[*]1x LPUART (low-power)
[*]2x SPI 16 Mbit/s (1 over 2 supporting I2S)
[*]3x I2C (SMBus/PMBus™)
[*]2x 16-bit 1-channel timer
[*]1x 16-bit 4-channel timer (supporting motor control)
[*]1x 32-bit 4-channel timer
[*]3x 16-bit ultra-low-power timer
[*]1x RTC with 32-bit sub-second wakeup counter
[*]1x independent SysTick
[*]1x independent watchdog
[*]1x window watchdog
[*]Up to 43 I/Os, most 5 V-tolerant
[*]Development support
[*]Serial-wire debug (SWD), JTAG for the application processor
[*]All packages ECOPACK2 compliant
