PCIE Gen4 HBA卡
2021年09月06日 17:27 发布者:reetest
Key Features: • PCIe Gen4 16Gb/s External Connectivity• High Performance with 16Gb/s PCIe Data Transfer Rates• PLX PEX88032,B0 Switch Chip• Quad Mini-SAS HD (SFF-8674) External Connectors• x16 Gen4 Host Interface • x1, x2, x4, x8, x16 External Port Configurations• Base Mode and Synthetic Mode• Compliant with PCI SIG External Cabling Revision 4.0, Version 0.3• Heartbeat LEDs• HHHL PCIe CEM Form Factor• Active Optical Cable Support Key Advantages: • External UART with CLI • FW Upgradeable• Supports CMI PCI SIG Messaging Between Upstream and Downstream Ports• Software Configurable Sideband Signals – PCI SIG Compliant – 100Mhz Differential PCIe Reference Clock – Downstream PCIe Resets• Downstream Port Containment (DPC) and eDPC• 100% Passive Cooling (No Active Fans Required)• PCIe Clocking Options – SRIS/SRNS, NON-SRIS, Common-Clocking
锐测电子提供SolidGear Minipod for SD/SDIO/eMMC. Minipod测试附件
