SL4007 大功率升压恒压芯片 2.8-24V输入 输出ADJ
2021年08月26日 14:19 发布者:小郑
General DescriptionThe SL4007 is boost topology switching regulator for wide operating voltage applications. It
provides built-in gate driver pin for driving external N-MOSFET. The non-inverting input of error
amplifier connects to a 1.2V precision reference voltage. It has programmable switching frequency set
by external resistor, and programmable inductor peak current limit connects a resistor from CS to GND.
Current mode control and external compensation network make is easy and flexible to stabilize the
system.
The SL4007 is available in the small footprint SOP-8L(EP) package to fit in space-saving PCB
layout for application fields.
Features
Start-up Voltage: 2.8V
Wide Supply Voltage Operating Range: 5V to 24V
Precision Feedback Reference Voltage: 1.2V (±2%)
Shutdown Current: <3μA
Programmable Switching Frequency: 100KHz~1000KHz
Input Under Voltage Protection(UVP)
Switching MOSFET Over Current Protection (OCP)
Over Temperature Protection (OTP)
Package: SOP-8L(EP)
Applications
Chargers
LCD Displays
Handheld Devices
Portable Products
Power Bank
Typical Application Circuit
