SL8830 启动电压2.5V LED面板灯升压恒流芯片LED车灯照明 LED开路保护 过温保护
2021年08月17日 10:59 发布者:小郑
General DescriptionThe SL8830 is boost topology switching regulator for LED driver. It provides built-in gate driver
pin for driving external N-MOSFET. The non-inverting input of error amplifier connects to a 0.2V
reference voltage. It has programmable soft start time set by external capacitor, and over voltage
protection set by external resistor. The LED current can be adjusted by an external signal connecting
to the EN pin. EN pin accepts either a DC voltage or a PWM signal. The PWM signal filter components
are contained within the chip.
Features
Start-up Voltage: 2.5V
Wide Supply Voltage Operating Range: 4.5V to 24V
Precision Feedback Reference Voltage: 0.2V (Max.)
Analog and Digital Dimming Control
Shutdown Current: 6μA (Max.)
Internal Fixed Switching Frequency: 300KHz
Programmable Soft Start Function (SS)
Programmable Over Voltage Protection (OVP)
Over Temperature Protection (OTP)
Package: SOP-8L(EP)
Applications
LED Module
Display Backlight
Car Lighting
Portable LED Lighting
Typical Application Circuit
