IR IRDC3477 SupIRBuck 15A DC电源解决方案
2011年09月24日 23:55 发布者:1046235000
IR公司的IRDC3477是 SupIRBuck容易使用全集成高效15A DC/DC电压稳压器.输入电压3V-27V,输出电压0.5V-12V,连续提供15A的负载电流,非常低的输出电流具有极好的效率,可编程开关频率和软起动,过流保护热补偿,内有精密的基准电压(0.5V, +/‐1%),主要用在笔记本和台式电脑,消费类电子如STB,LCD,TV和打印机等,12V和24V分布式电源,通用POL DC/DC转换器,游戏控制台和图像卡.本文介绍了IR3477主要特性,功能框图, 基本应用电路图和IR3477演示板电路图与材料清单,以及IR3477M 评估板特性, 评估板电路图和IR3477M 评估板材料清单与PCB元件布局图.The IR3477 SupIRBuckTM is an easy‐to‐use, fully integrated and highly efficient DC/DC voltage regulator. The onboard constant on time hysteretic controller and MOSFETs make IR3477 a space‐efficient solution that delivers up to 15A of precisely controlled output voltage.
Programmable switching frequency, soft start, and thermally compensated over current protection allows for a very flexible solution suitable for many different applications and an ideal choice for battery powered applications.
Additional features include pre‐bias startup, very precise 0.5V reference, under/over voltage shutdown, thermal protection, power good output, and enable input with voltage monitoring capability.
IR3477主要特性:
Input Voltage Range: 3V to 27V
Output Voltage Range: 0.5V to 12V
Continuous 15A Load Capability
Constant On‐Time Control
Compensation Loop not Required
Excellent Efficiency at Very Low Output Currents
Programmable Switching Frequency and Soft Start
Thermally Compensated Over Current Protection
Power Good Output
Precision Voltage Reference (0.5V, +/‐1%)
Enable Input with Voltage Monitoring Capability
Pre‐bias Start Up
Thermal Shut Down
Under/Over Voltage Fault Protection
Forced Continuous Conduction Mode Option
Small, Low Profile 5mm x 6mm QFN Package
IR3477应用:
Notebook and Desktop Computers
Consumer Electronics – STB, LCD, TV, Printers
12V and 24V Distributed Power Systems
General Purpose POL DC‐DC Converters
Game Consoles and Graphics Cards
图1. IR3477方框图
图2. IR3477基本应用电路图
图3. IR3477演示板电路图: VOUT = 1.05V, FS = 300kHz
演示板材料清单(BOM):
IR3477M 评估板
The IR3477 SupIRBuckTM is an easy-to-use, fully integrated and highly efficient DC/DC voltage regulator. The onboard constant on time hysteretic controller and MOSFETs make IR3477 a space-efficient solution that delivers up to 15A of precisely controlled output voltage. IR3477 is housed in a 20-lead 5mmx6mm QFN package.
Key features offered by IR3477 include: programmable switching frequency, soft start, temperature compensated over current protection, and thermal shutdown allowing a very flexible solution suitable for many different applications and an ideal choice for battery powered applications.
Additional features include pre-bias startup, a very precise 0.5V reference, forced continuous conduction mode option, over/under voltage protection, power good output, and enable input with voltage monitoring capability.
This user guide contains the schematic, bill of materials, and operating instructions of the IRDC3477 evaluation board. Detailed product specifications, application information and performance curves at different operating conditions are available in the IR3477 data sheet.
IR3477M 评估板特性:
VIN = +12V
VCC = +5V
VOUT = +1.05V
IOUT = 0 to 15A
FS = 300kHz @ CCM
L = 1μH
CIN = 22μF (ceramic 1210) + 68μF (electrolytic)
COUT = 47μF (ceramic 0805) + 330μF (PC-CON)
图4.IR3477M 评估板外形图
图5.IR3477M 评估板电路图
IR3477M 评估板材料清单:
图6.IR3477M 评估板元件布局图(顶层)
图7.IR3477M 评估板元件布局图(底层)
详情请见:
45372和
45373
