Maxim Integrated I/O集线器助力欧姆龙公司扩展NXR系列IO-Link产线,实现工业4.0
2021年02月23日 16:19 发布者:eechina
欧姆龙利用Maxim Integrated的IO-Link产品扩展其NXR系列产品的数字I/O性能Maxim Integrated Products, Inc (NASDAQ: MXIM)宣布其双通道IO-Link产品被欧姆龙(OMRON Corporation)所采纳,用于该公司NXR系列的IO-Link控制器和IO-Link I/O集线器,以扩展IO-Link双向控制器和数字IO性能。借助Maxim Integrated的MAX14819A双通道IO-Link控制器和MAX14827A IO-Link器件,以及MAX14912和MAX14915数字输出器件,NXR系列产品为欧姆龙客户提供便捷途径,扩展其工厂自动化系统IO,并将智能化推向产线前沿。欧姆龙的创新NXR系列产品可持续诊断、监测客户现场生产设备的健康状况及工作状态。
• 关于Maxim Integrated IO-Link方案的详细信息,请访问:https://www.maximintegrated.com/cn/products/interface/industrial-digital-io.html?utm_source=PR-Newswire_&utm_medium=press-rels&utm_content=LANDPG-DIO&utm_campaign=FY21_Q1_2020_JUL_INH-IndCom_WW_OmronPR_EN
• 关于Maxim Integrated IO-Link收发器的详细信息,请访问:https://www.maximintegrated.com/cn/products/interface/io-link-transceivers.html?utm_source=PR-Newswire_&utm_medium=press-rels&utm_content=LANDPG-IOLink&utm_campaign=FY21_Q1_2020_JUL_INH-IndCom_WW_OmronPR_EN
• 订购MAX14819A或了解更多信息,请访问:https://www.maximintegrated.com/cn/products/interface/sensor-interface/MAX14819.html?utm_source=PR-Newswire_&utm_medium=press-rels&utm_content=PRDFOL-MAX14819&utm_campaign=FY21_Q1_2020_JUL_INH-IndCom_WW_OmronPR_EN
• 订购MAX14827A或了解更多信息,请访问:https://www.maximintegrated.com/cn/products/interface/transceivers/MAX14827A.html?utm_source=PR-Newswire_&utm_medium=press-rels&utm_content=PRDFOL-MAX14827A&utm_campaign=FY21_Q1_2020_JUL_INH-IndCom_WW_OmronPR_EN
• 订购MAX14912或了解更多信息,请访问:https://www.maximintegrated.com/cn/products/power/mosfet-drivers-controllers/MAX14912.html?utm_source=PR-Newswire_&utm_medium=press-rels&utm_content=PRDFOL-MAX14912&utm_campaign=FY21_Q1_2020_JUL_INH-IndCom_WW_OmronPR_EN
• 订购MAX14915或了解更多信息,请访问:https://www.maximintegrated.com/cn/products/power/mosfet-drivers-controllers/MAX14915.html?utm_source=PR-Newswire_&utm_medium=press-rels&utm_content=PRDFOL-MAX14915&utm_campaign=FY21_Q1_2020_JUL_INH-IndCom_WW_OmronPR_EN
IO-Link的双向链路赋予传感器和执行器以智能,使设备能够瞬间适应生产条件的变化,并实时制定决策,推动更高智能化的生产进程。Maxim Integrated独特的IO-Link技术,结合可灵活通过软件配置的数字输出产品,为欧姆龙提供实现IO-Link 输入/输出集线器方案的新机遇。同时,欧姆龙采用IO-Link技术的创新举措也有助于加速该标准在工业领域的普及。
欧姆龙正在将第一款远端数字输出IO-Link I/O集线器(NXR-CD166C-IL2模块)增加到其系列产品中,使IO-Link的应用不仅仅限于传感器领域。该公司正在解决由于客户长期缺乏产线工程师而导致的双重问题,帮助用户降低产线的停工时间、提高新设备的调试效率。欧姆龙分析了生产过程中不必要的、低效的工作环节,开发了具有各种节省时间功能的NXR系列。该公司通过使用新型NXR IO-Link控制器(NXR-ILM08C-EIT)和IO-Link I/O集线器(NXR-[]D166C-IL2),已经将设备配置和调试时间缩短90%。此外,新的NXR系列IO-Link控制器和I/O集线器产品可充分利用智能诊断功能,实时收集整个产线的工作信息,从而有效缩短停工时间。此外,由于器件本身内置断线监测和强大的保护功能,有效提升了系统可靠性。
评价
• 欧姆龙公司控制器事业部负责网络和IO产品管理的产品经理Haedon Lee表示:“凭借Maxim Integrated的方案,我们已经实现了为网络增加额外数字IO的新途径,进一步将智能化推向生产前沿。”
• Maxim Integrated工业通信及医疗健康事业部副总裁Jeff DeAngelis表示:“通过扩展IO-Link技术在我们数字IO和模拟IO工业芯片组中的应用,使得欧姆龙能够通过简单的方式来扩展数字IO的数量,开辟了重新配置生产线的新能力。”
IO-Link概览
IO-Link (IEC 61131-9) 是第一个支持传感器与执行器进行通信的全球标准技术。功能强大的点对点通信基于成熟的、采用现有电缆的3线传感器和执行器链路。
