Semtech SX865x系列4或5线电阻触摸屏控制方案
2011年08月18日 11:10 发布者:Liming
Semtech公司的SX865x系列(SX8654, SX8655和SX8656)是4/5线电阻触摸屏控制器,低电压2.3V-3.6V工作,低功耗,关断电流仅0.4uA,器件集成了LDO稳压器,4/5线触摸屏接口,精密的比率12位ADC,高达5000(X-Y)座标/秒.主要用在游戏机,手提音乐设备,手机,DSC,DVR,POS/POI终端和触摸屏监视器.本文介绍了SX865x系列主要特性和方框图, 接近检测接口框图,以及模拟前端(AFE)框图, 触摸接口框图和应用框图,典型应用电路框图推荐外接元件数值表.The SX8654, SX8655 and SX8656 belong to a family of high performance haptics enabled 4/5-wire resistive touch screen controller with proximity detection, optimized for hand held applications such as mobile phones, portable music players, game machines, point-of-sales terminal and other consumer and industrial applications. They feature a wide input supply range from 2.3V to 3.6V. The controller computes touch screen X-Y coordinates and touch pressure with a precision, low power 12-bit analog-digital converter. On-chip data averaging processing algorithms can be activated to reduce host activity and suppress system noise. The processing core features low power modes which intelligently minimize current in operation as well as in automatic shut-down.
A capacitive proximity detection circuit has been integrated into the SX8654 and SX8656 to enable host controlled power management for battery applications. Proximity detection above 5 cm is possible using either the resistive touch screen as the sensor or with a single conductive plate, with communication to the host via the serial interface.
The SX8654 and SX8655 also integrate a haptics motor driver for Linear Resonant Actuator (LRA) and Eccentric Rotating Mass (ERM) micro motors with up to 250mA drive current. Haptics control can be performed using either an external PWM signal or the I2C serial interface, providing simple host interfacing and minimizing its I/O requirement.
Integrated very high ESD protection, of up to ±15kV on display inputs not only saves cost and board area, but also increases application reliability.
The three devices have an ambient operating temperature range of -40°C to +85°C, and are offered in both a 4mm x 4mm, 20-lead QFN package and 2.07mm x 2.07mm 19-lead CSP package for spaceconscious applications.
SX865x系列主要特性:
Low Voltage Operation
2.3V to 3.6V Supply
Integrated Low Drop Out (LDO) Regulator
Low Power Consumption
30uA@2.3V 8ksps (ESR)
0.4uA Shut-Down Current
4/5-Wire Touchscreen Interface
Precision, Ratiometric 12-bit ADC
Up to 5000 (X-Y) coordinates/second (c/s)
Programmable Digital Filtering/Averaging
Touch Pressure Measurement (4-Wire)
Programmable Operating Mode (Manual,Pen Detect, Pen Trigger)
Capacitive Proximity Sensing (SX8654/56)
No Additional Components Required
Uses Resistive Touchscreen or a Simple Conductive Area as the Sensor
>5 cm Detection Distance
8uA @ 200ms Scan Period
Fully Programmable (Sensitivity, etc)
Haptics Driver for LRA and ERM (SX8654/55)
Haptics Waveform Generation Control (I2C or PWM Input)
Short Circuit Protection
Early Warning and Over-Temperature Monitoring and Protection
400kHz I2C Serial Interface
Several Host Operating Modes Available
Maskable Interrupt Output (NIRQ)
Real-time Events Monitoring (AUX1-3)
Polling (I2C)
Hardware, Software, and Power-On Reset
-40°C to +85°C Operating Temperature Range
15kV HBM & IEC ESD Protection
Small Footprint Packages
Pb & Halogen Free, RoHS/WEEE compliant
SX865x系列应用:
Game Machines, Portable Music Players
Mobile Phones
DSC, DVR, Phones
POS/POI Terminals
Touch-Screen Monitors
图1.SX8654 方框图
图2.SX8655方框图
图3.SX8656方框图
图4.SX8654应用框图
图5.SX8654/5/6接近检测接口框图
图6.SX8654模拟前端(AFE)框图
图7.SX8654/5/6触摸接口框图
图8.SX8654典型应用电路框图
推荐外接元件数值表:
详情请见:
http://www.semtech.com/images/datasheet/sx8654.pdf
