Freescale Kinetis K60低功耗MCU TWR-K60N512-KIT开发方案
2011年08月13日 12:04 发布者:Liming
Freescale 公司的Kinetis K60系列是低功耗MCU,工作电压1.71-3.6V,闪存的写电压为1.71-3.6V,采用高达100MHz的ARMRCortex™-M4内核,其性能可达到1.25 Dhrystone MIPS per MHz,同时可选择浮点单元, IEEE 1588以太网,USB 2.0 OTG,加密和篡改检测,具有极好的性能,环境温度为-40 到105°C,主要用在工业如安全照相机, 建筑物自动化控制和电梯控制屏以及医疗电子如心电图(ECG),生命信息监测仪,运程医疗保健系统,心率监视器, 除颤仪, 麻醉监视器, 呼吸机等.本文介绍了K60系列主要特性,方框图, TWR-K60N512-KIT K60系列开发套件主要特性,方框图和电路图.Kinetis K60: Low-Power MCU with optional Floating Point Unit, Ethernet, USB, Encryption and Tamper Detect
Kinetis is the most scalable portfolio of low power, mixedsignal ARMRCortex™-M4 MCUs in the industry. Phase 1 of the portfolio consists of five MCU families with over 200 pin-,peripheral- and software-compatible devices. Each family offers excellent performance, memory and feature scalability with common peripherals, memory maps, and packages providing easy migration both within and between families.
Kinetis MCUs are built from Freescale’s innovative 90nm Thin Film Storage (TFS) flash technology with unique FlexMemory. Kinetis MCU families combine the latest lowpower innovations and high performance, high precision mixed-signal capability with a broad range of connectivity, human-machine interface, and safety & security peripherals.Kinetis MCUs are supported by a market-leading enablement bundle from Freescale and numerous ARM 3rd party ecosystem partners.
The K60 MCU family includes IEEE 1588 Ethernet, full- and high-speed USB 2.0 On-The-Go with device charger detect capability, hardware encryption and tamper detection capabilities. Devices start from 256 KB of flash in 100LQFP packages extending up to 1 MB in a 256MAPBGA package with a rich suite of analog, communication, timing and control peripherals.
High memory density K60 family devices include an optional single precision floating point unit, NAND flash controller and DRAM controller.
K60系列主要特性:
• Operating Characteristics
– Voltage range: 1.71 to 3.6 V
– Flash write voltage range: 1.71 to 3.6 V
– Temperature range (ambient): -40 to 105°C
•Performance
Up to 100 MHz ARM Cortex-M4 core with DSP instructions delivering 1.25 Dhrystone MIPS per MHz
•Memories and memory interfaces
– Up to 512 KB program flash memory on non- FlexMemory devices
– Up to 256 KB program flash memory on FlexMemory devices
– Up to 256 KB FlexNVM on FlexMemory devices
– 4 KB FlexRAM on FlexMemory devices
– Up to 128 KB RAM
– Serial programming interface (EzPort)
– FlexBus external bus interface
•Clocks
– 3 to 32 MHz crystal oscillator
– 32 kHz crystal oscillator
– Multi-purpose clock generator
•System peripherals
– 10 low-power modes to provide power optimization based on application requirements
– Memory protection unit with multi-master protection
– 16-channel DMA controller, supporting up to 64 request sources
– External watchdog monitor
– Software watchdog
– Low-leakage wakeup unit
•Security and integrity modules
– Hardware CRC module to support fast cyclic redundancy checks
– Hardware random-number generator
– Hardware encryption supporting DES, 3DES, AES, MD5, SHA-1, and SHA-256 algorithms
– 128-bit unique identification (ID) number per chip
•Human-machine interface
– Low-power hardware touch sensor interface (TSI)
– General-purpose input/output
•Analog modules
– Two 16-bit SAR ADCs
– Programmable gain amplifier (PGA) (up to x64) integrated into each ADC
– 12-bit DAC
– Three analog comparators (CMP) containing a 6-bit DAC and programmable reference input
– Voltage reference
•Timers
– Programmable delay block
– Eight-channel motor control/general purpose/PWM timer
– Two 2-channel quadrature decoder/general purpose timers
– IEEE 1588 timers
– Periodic interrupt timers
– 16-bit low-power timer
– Carrier modulator transmitter
– Real-time clock
• Communication interfaces
– Ethernet controller with MII and RMII interface to external PHY and hardware IEEE 1588 capability
– USB full-/low-speed On-the-Go controller with on-chip transceiver
– Two Controller Area Network (CAN) modules
– Three SPI modules
– Two I2C modules
– Five UART modules
– Secure Digital host controller (SDHC)
– I2S module
Kinetis K60系列目标应用:
Industrial
Security Cameras
Building Automation Controllers
Control Panels (Elevator)
Medical
Heart Rate Monitors
Telehealth System
Electrocardiograph (ECG)
Anesthesia Unit Monitor
Vital Signs Monitors
Ventilators and Respirators
Defibrillators
图1. Kinetis K60系列方框图
TWR-K60N512-KIT: Development Kit for Kinetis K60 Family
The TWR-K60N512 is a Tower Controller Module compatible with the Freescale Tower System. It can function as a stand-alone, low-cost platform for the evaluation of the Kinetis K10, K20 and K60 family of microcontroller (MCU) devices. The TWR-K60N512 features the Kinetis K60 low-power microcontroller based on the ARM® Cortex™-M4 architecture with USB 2.0 full-speed OTG controller and 10/100 Mbps Ethernet MAC.
The TWR-K60N512 is available as a stand-alone product or as a kit (TWR-K60N512-KIT) with the Tower Elevator Modules (TWR-ELEV) and the Tower Serial Module (TWR-SER). The TWR-K60N512 can also be combined with other Freescale Tower peripheral modules to create development platforms for a wide variety of applications. 0 provides an overview of the Freescale Tower System.
图2. Tower System系统外形图
TWR-K60N512-KIT K60系列开发套件包括:
TWR-K60N512 MCU module
TWR-ELEV – Primary and Secondary Elevator Modules
TWR-SER – Serial module including USB host/device/OTG, Ethernet, CAN, RS232 and RS485
The TWR-K60N512 is a Tower Controller Module featuring the MK60N512VMD100—an ARM Cortex-M4 based microcontroller with segment LCD and USB 2.0 full-speed OTG controllers in a 144 MAPBGA package with a maximum core operating frequency of 100MHz. It is intended for use in the Freescale Tower System but can operate stand-alone. An on-board debug circuit, OSJTAG, provides a JTAG debug interface and a power supply input through a single USB mini-AB connector.
图3. TWR-K60N512外形图(正面)
图4. TWR-K60N512框图
图5. TWR-K60N512电路图(1)
图6. TWR-K60N512电路图(2)
图7. TWR-K60N512电路图(3)
图8. TWR-K60N512电路图(4)
图9. TWR-K60N512电路图(5)
详情请见:
http://cache.freescale.com/files/microcontrollers/doc/data_sheet/K60P100M100SF2.pdf?fpsp=1&WT_TYPE=Data
Sheets&WT_VENDOR=FREESCALE&WT_FILE_FORMAT=pdf&WT_ASSET=Documentation
和
http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=TWR-K40X256-KIT
以及
http://cache.freescale.com/files/32bit/doc/ref_manual/TWR-K60N512-UM.pdf?fpsp=1
