Avago AEAT-6600-T16高分辨率霍耳磁传感器编码方案
2011年07月28日 11:49 发布者:Liming
Avago公司的 AEAT-6600-T16是业界最高分辨率的霍耳磁性编码器,包括霍耳元件,模拟前端和数字信号处理,具有10-16位的分辨率,可精密测量360度旋转的角度.器件的工作电压5V或3.3V,3线或2线SSI接口模式的绝对值输出,增量ABI或UVW以及PWM输出模式,用户可编程的零位置,指向和标志脉宽,主要用在工业自动化和机器人,替代分解器和电位计,无刷DC马达的三相换向等.本文介绍了AEAT-6600-T16主要特性和指标, OTP可编模式电路图, 对准模式电路图, PCB级应用电路图以及HEDS-8937编程器主要特性等.The Avago AEAT-6600 angular magnetic encoder IC is a contact less magnetic rotary encoder for accurate angular measurement over a full turn of 360 degrees.
It is a system-on-chip, combining integrated Hall elements, analog front end and digital signal processing in a single device.
To measure the angle, only a simple two-pole magnet, rotating over the center of the chip, is required. The magnet may be placed above or below the IC.
The absolute angle measurement provides instant indication of the magnet’s angular position with a resolution of 0.005° = 65 536 positions per revolution. This digital data is available as a serial bit stream and as a PWM signal.
An internal voltage regulator allows the AEAT-6600 to operate at either 3.3 V or 5 V supplies.
AEAT-6600-T16主要特性:
5 V or 3.3 V operation
3-wire or 2-wire SSI interface mode for absolute output
Incremental ABI or UVW, and PWM output modes
User-programmable zero position, direction & index pulse width
Easy magnet alignment with magnetic field strength output and alignment mode
Power-down mode to reduce current consumption
TSSOP-16 IC package
RoHS compliant
AEAT-6600-T16指标:
Absolute 10-bits to 16-bits resolution
Incremental output resolutions 8 to 1024 CPR
-40°C to 125°C operating temperature range
AEAT-6600-T16应用:
Industrial automation and robotics
3-phase commutation for brushless DC motor
Resolver and potentiometer replacement
Industrial Automation Applications, such as:
Robotics
- Stepper Motor
- Valve Control
- Textile Machinery
- CNC Machines
- Industrial Control Systems
- Solar panels
图1. 北极星方框图
图2. AEAT-6600-T16 OTP可编模式电路图
图3. AEAT-6600-T16 对准模式电路图
图4. AEAT-6600-T16 PCB级应用电路图
Avago HEDS-8937编程器
This user manual describes the Avago HEDS-8937 programmer kit.
The AEAT-6600-T16 magnetic encoder programming kit features real-time monitoring and programming of the 32-bit OTP memory within the AEAT-6600-T16 magnetic encoder IC. The HEDS-8937 kit includes the IC interface hardware that is supported by PC software. The IC interface hardware is a microcontroller system that links the AEAT-6600-T16 encoder to the PC through a USB cable. This user manual describes the hardware and PC software setup and gives instructions on PC software operation.
Avago HEDS-8937编程器主要特性:
Bus-powered USB device
On-board 6.5 V programming voltage
Auto-power off when the AEAT-6600-T16 is removed from the programming socket
Read and write the 32-bit OTP memory
Real-time monitoring of SSI, PWM, ABI or UVW outputs
Real-time monitoring of MAG_HI and MAG_LOW Signals
Avago HEDS-8937编程器包括:
1. USB cable
2. AEAT-6600-T16 magnetic encoder programmer
3. IC adapter socket
4. 16-pin ribbon cable
5. Installation CD
图5.Avago HEDS-8937编程器外形图
详情请见:
http://www.avagotech.com/docs/AV02-2792EN
和
http://www.avagotech.com/docs/AV02-2791EN
