ET3159带快速放电的带反向关断功能的3A开关芯片,提供技术支持
2020年07月15日 11:01    发布者:LIJINTAO123
授权代理无锡力芯微ET3159 advanced load management switches target applications requiring a highly integrated solution.深圳锦宏世纪科技 李生 189:kiss:38047300
It disconnects loads powered from DC Power Rail (<6V) with stringent off-state current targets and high load
capacitances (up to 200μF). Each switch consists of slew-rate controlled low-impedance MOSFET Switch (29mΩ
Typ) and other integrated analog features. The slew-rate controlled turn-on characteristic prevents inrush-current
and the resulting excessive voltage droop on power rails.
The ET3159 has exceptionally low off-state current drain (<1μA max) which facilitate compliance in very
low stand-by power applications. The input voltage range operates from 1.5V to 6.0V DC to fulfill a wide range
of applications in consumer, optical, medical, storage, portable, and industrial device power management. Switch
control is managed by a logic input (Active HIGH) capable of interfacing directly with low voltage control
signal/GPIO with no external pull-down resistor required. In ET3159, 90Ω on-chip load resistor is added for
output quick discharge when switch is turned off (EN=0V)
ET3159 is in TDFN4 package of 1.2mm by 1.6mm.
产品特点:
 1.5V to 6 V operation voltage range
 Slew Rate/Inrush Control with tR:0.8ms (Typ)
 Typical RDS(ON):
30mΩ at VIN=5V
33mΩ at VIN=4.3V
38mΩ at VIN=3.6V
 Low quiescent current < 1 μA
 ESD Protected: Above 8kV (contact) IEC (IN with 2.2uF cap), 4kV HBM, 1.5kV CDM
产品应用:
 PDAs/smart phones
 Notebook/netbook computers
 Tablet PC
 Portable media players
 Digital camera
 GPS navigation devices
 Data storage devices
 Optical, industrial, medical, and healthcare devices
该文章有附件资料,如需下载请访问 电脑版
