USB免驱摄像头Camera凌阳ES82182/ES8218创新ES7243/ES7243E方案XJ3369MJG+顺芯ADC +P25Q40H
2020年05月13日 19:28 发布者:ES7243
USB免驱摄像头Camera凌阳ES82182/ES8218创新ES7243/ES7243E方案XJ3369MJG+顺芯ADC +P25Q40H单麦克风用ES8218E双麦克风用ES7243E
ES7243支持双麦克风,音频ADC功能24Bit,101DB SNR,-85DB THD+N, 3*3MM,QFN-20
技术样品151 1247 6010 莫工2383960712
ES7210 and ES7243 are our ADC for mic array applications, customers include Baidu, Ali, Tencent, Xiaomi, Huawei, JD, UBTECH, Sunning, China Mobile, Harman, Sony, Lanbao, iFLYTEK, Aispeech, Unisound, SoundAI and so many others. For examples:
FEATURES• High performance multi-bit delta-sigmaaudio ADC• 102 dB signal to noise ratio• -85 dB THD+N• 24-bit, 8 to 200 kHz sampling frequency• I2S/PCM master or slave serial data port• Support TDM• 256/384Fs, USB 12/24 MHz and othernon standard audio system clocks• Low power standby mode
ES7243特性高性能多位delta-sigma音频ADC
谢谢楼主分享,受教了
