艾默生PH电极396P-01-10-55
2019年07月26日 11:50 发布者:a13307119923
艾默生PH电极396P-01-10-55罗斯蒙特ph电极3900-01-12
3900-02-10艾默生ph玻璃电极
功能
使用双液接参比电极抵抗毒离子,延长了传感器的使用寿命
使用防裂玻璃,可增强性能并延长使用寿命
坚固的聚苯硫醚本体结构可提供强的抗化学腐蚀能力
工作温度可低至零下,低可达 -10°C (14°F)
内置溶液接地功能,可执行高级诊断
传感器主体为单件式结构,同时带有前向和后向过程螺纹
1” MNPT 过程连接件可满足多种应用的安装需求
Variopol (VP8) 电缆连接件选项可快速将电缆与传感器断开,消除电缆扭结
可使用 SMART 特性进行 pH 测量
Rosemount? 3900 General Purpose pH/ORP Sensors
The Rosemount 3900 pH/ORP combination sensor's double junction reference aids in the sensor's resistance to harsh environments and helps prolong sensor life. The double junction protects the reference element from poisoning ions-such as ammonia, chlorine, cyanides, and sulfides. Both sensors are made with a porous Teflon? junction. The robust sensor design makes the 3900 reliable in a wide range of aqueous solutions found in pipelines, open tanks or ponds.
规格
Operating Temperature –10° to 100°C (14° to 212°F)
Pressure Port/Fitting Maximum Pressure: 790 kPa (100 psig) at 100°C (212°F)
Materials of Construction Stainless steel, glass, Teflon?, polyphenylene sulfide (PPS), EPDM and silicone
ORP: Platinum
Integral Cable: 32 ft (10m) cable with integral SMART preamp; 15 ft (4.7m) cable without preamp sensor
VP8 Cable: use 24281-XX, 2.5 ft (.8m) to 100 ft (31m)
Process Connection Front facing: 3?4" and 1" MNPT; Rear facing: 1" MNPT
功能
Extended sensor life and protection against poisoning ions using a double junction reference
Enhanced performance and increased life with cracking resistant glass
Maximum chemical resistance provided by a rugged polyphenylene sulfide body
Operates in sub-zero temperatures down to -10°C (14°F)
Built-in solution ground for advanced diagnostics
The sensor body features a one-piece construction with both front facing and rear facing process threads
?” and 1” MNPT process connections to meet a variety of application installation requirements
Variopol (VP8) cable connection option, for quick cable-to-sensor release, eliminates cable twisting
SMART enabled for pH measurements
罗斯蒙特分析仪变送器5081P-HT-20-73
艾默生气体分析仪X-STREAM C
艾默生分析仪396P-02-10
艾默生分析仪1066-P-HT-60
罗斯蒙特分析仪电缆24281-00
艾默生分析仪1056-01-21-38-AN
艾默生分析仪228-02-21-54-61
艾默生分析仪23242-02
艾默生分析仪389-02-11-55
艾默生分析仪1066-T-AN-60
罗斯蒙特浊度仪T1056-01-10-20-30-71浊度分析仪
艾默生PH分析仪1056-01-22-38-AN
艾默生PH分析仪1056-01-20-38-AN
艾默生PH分析仪1056-02-25-32-AN
罗斯蒙特分析仪1056-02-22-38-AN
艾默生双检测电导分析仪1055-01-10-20-30
艾默生分析仪PH变送器1066-T-HT-60
艾默生分析仪1056-02-20-AN
艾默生分析仪1056-01-21-31-AN
罗斯蒙特分析仪1066-P-AN-60
艾默生分析仪1055-01-10-22
罗斯蒙特分析仪1056-03-21-38-HT
艾默生分析仪1056-02-22-32-AN
艾默生分析仪1056-03-24-34-AN
罗斯蒙特分析仪1056-01-24-38-HT
罗斯蒙特分析仪1056-02-22-38-HT
罗斯蒙特分析仪1056-03-20-38-AN
艾默生分析仪1056-01-24-32-AN
艾默生分析仪1056-01-22-30-AN
艾默生分析仪499AOZ-54
罗斯蒙特分析仪1066-DO-HT-60
艾默生分析仪1056-02-20-31-AN
艾默生分析仪5081-T-HT-21-67
罗斯蒙特分析仪1056-01-20-30-AN
艾默生分析仪Oxymitter 4000:OXT4A-1-4-0-0-14-3-1-00-02-13
罗斯蒙特分析仪3200HP-02
罗斯蒙特分析仪400VP-11
罗斯蒙特分析仪1056-03-22-38-AN
艾默生分析仪3500P-HT-02-10-21-30
罗斯蒙特分析仪1056-01-22-30-DP
罗斯蒙特分析仪3900-02-12
艾默生罗斯蒙特PR6426传感器
罗斯蒙特电导率传感器403-11-20-50
罗斯蒙特浊度计传感器探头8-0108-002-EPA RevI
罗斯蒙特传感器150-03-54
罗斯蒙特浊度仪传感器8-0108-0003-ISO
罗斯蒙特浊度仪传感器8-0101-003-ISO
罗斯蒙特传感器404-12-17-50
艾默生Emerson电导率传感器400-11
罗斯蒙特PH传感器400-11-60
艾默生传感器3400HT-10-25-30-62
罗斯蒙特PH传感器396P-02-12-55
罗斯蒙特PH传感器396P-01-13-55-41
艾默生传感器402-11
罗斯蒙特传感器499ADO-54
罗斯蒙特浊度仪传感器T1056-02-10-20-32-71
艾默生传感器499ATRDO-54-70
艾默生传感器3400HT-10-21-32-62
罗斯蒙特PH计传感器3300HT-10-31
罗斯蒙特传感器396R-12-21-54
