MY-IMX6-EK200 Linux-4.1.15 测试手册 v2.0(5)
2019年05月08日 11:13 发布者:myzr123
【接上一章节MY-IMX6-EK200 Linux-4.1.15测试手册v2.0(4)】4 第四部分 扩展模块功能演示
4.1 RTL8188 模块功能演示(WIFI Client)
【测试说明】:使用RTL8188作为无线网卡连接到WIFI AP。
【接口标识】:WIFI、WIFI_ANT
【系统设备】:wlan0
测试操作
1. 确定“WIFI”标识处有贴上WIFI模块,否则无需进行测试。
2. 把WIFI天线连接到“WIFI_ANT”标识的接口上。
3. 生成 SSID 的 WPA PSK 文件
命令格式: wpa_passphrase
=====> 输入指令:
wpa_passphrase MY-TEST-AP myzr2012 > /etc/wpa_supplicant.conf
pkill wpa_supplicant
4. 连接
=====> 输入指令:
wpa_supplicant -B -i wlan0 -c /etc/wpa_supplicant.conf
=====> 输出信息:
Successfully initialized wpa_supplicant
rfkill: Cannot open RFKILL control device
==> rtl8188e_iol_efuse_patch
IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
5. 获取 IP
=====> 输入指令:
udhcpc -i wlan0
=====> 输出信息:
udhcpc (v1.23.1) started
Sending discover...
Sending select for 192.168.43.121...
Lease of 192.168.43.121 obtained, lease time 3600
/etc/udhcpc.d/50default: Adding DNS 192.168.43.1
6. 测试连接
=====> 输入指令:
ping -I wlan0 192.168.43.1 -c 2 -w 4
=====> 输出信息:
PING 192.168.43.1 (192.168.43.1) from 192.168.43.130 wlan0: 56(84) bytes of data.
64 bytes from 192.168.43.1: icmp_seq=1 ttl=64 time=5.66 ms
64 bytes from 192.168.43.1: icmp_seq=2 ttl=64 time=9.22 ms
--- 192.168.43.1 ping statistics ---
2 packets transmitted, 2 received, 0% packet loss, time 1000ms
rtt min/avg/max/mdev = 5.663/7.444/9.226/1.783 ms
测试结果
“0% packet loss”表示WIFI连接正常。
4.2 RTL8188 模块功能演示(WIFI AP mode)
【测试说明】:使用RTL8188作为WIFI AP,并把手机连接到此AP。
【系统设备】:wlan0
测试操作
3. 为 wlan0 配置 IP:
=====> 输入指令:
ifconfig wlan0 192.168.99.1
=====> 输出信息:
4. 为 wlan0 启用 DHCP 服务:
=====> 输入指令:
touch /var/lib/misc/udhcpd.leases
udhcpd -f /etc/my_udhcpd.conf &
=====> 输出信息:
469
udhcpd (v1.23.1) started
5. 为 wlan0 启用 Host-AP 功能
=====> 输入指令:
hostapd /etc/my_hostapd.conf -B
=====> 输出信息:
Configuration file: /etc/my_hostapd.conf
Using interface wlan0 with hwaddr e0:b9:4d:7f:e4:40 and ssid "MY_HOSTAP_V25"
RTL871X: set group key camid:1, addr:00:00:00:00:00:00, kid:1, type:AES
wlan0: interface state UNINITIALIZED->ENABLED
wlan0: AP-ENABLED
6. 客户端设备连接到 Host-AP
至此,开发板的 Host-AP 功能已启用,客户端设备可搜索“MY_HOSTAP_V25”,通过密码“myzr2012”连接到此AP。
测试结果
1. 设备连接成功时产生的信息
=====> 输出信息:
Sending OFFER of 192.168.12.20
Sending ACK to 192.168.12.20
2. 设备断开连接时产生的信息
=====> 输出信息:
RTL871X: OnDeAuth(wlan0) reason=3, ta=b4:0b:44:f5:64:2f
RTL871X: clear key for addr:b4:0b:44:f5:64:2f, camid:4
4.3 EC20 模块测试
【测试说明】:4G连接成功后,开发板向外网发送ICMP报文来验证连接正常。
【接口标识】:MINI_PCIE
【系统设备】:eth2
测试操作
1. 开发板断电,接上4G模块,接上天线并插入SIM卡后启动评估板。
2. 使用指令进行网络连接:
=====> 输入指令:
/my-demo/gcc-linaro-5.3-arm/quectel-CM &
=====> 输出信息:
540
WCDMA<E_QConnectManager_Linux&Android_V1.1.34
/my-demo/gcc-linaro-5.3-arm/quectel-CM profile = (null)/(null)/(null)/0, pincode = (null)
Find /sys/bus/usb/devices/1-1.2 idVendor=2c7c idProduct=0125
Find /sys/bus/usb/devices/1-1.2:1.4/net/eth2
Find usbnet_adapter = eth2
Find /sys/bus/usb/devices/1-1.2:1.4/GobiQMI/qcqmi2
Find qmichannel = /dev/qcqmi2
Get clientWDS = 7
Get clientDMS = 8
Get clientNAS = 9
Get clientUIM = 10
Get clientWDA = 11
requestBaseBandVersion EC20CEFAR02A10M4G
requestGetSIMStatus SIMStatus: SIM_READY
requestGetProfile cmnet///0
requestRegistrationState2 MCC: 460, MNC: 0, PS: Attached, DataCap: LTE
requestQueryDataCall IPv4ConnectionStatus: DISCONNECTED
requestSetupDataCall WdsConnectionIPv4Handle: 0x8777e7a0
requestQueryDataCall IPv4ConnectionStatus: CONNECTED
ifconfig eth2 up
busybox udhcpc -f -n -q -t 5 -i eth2
Sending discover...
Sending select for 10.25.154.46...
Lease of 10.25.154.46 obtained, lease time 7200
/etc/udhcpc.d/50default: Adding DNS 211.136.17.107
/etc/udhcpc.d/50default: Adding DNS 211.136.20.203
3. 测试连接
=====> 输入指令:
ping -I eth2 www.baidu.com -c 2 -w 4
=====> 输出信息:
PING www.baidu.com (14.215.177.38): 56 data bytes
64 bytes from 14.215.177.38: seq=0 ttl=49 time=15.753 ms
64 bytes from 14.215.177.38: seq=1 ttl=49 time=11.835 ms
--- www.baidu.com ping statistics ---
2 packets transmitted, 2 packets received, 0% packet loss
round-trip min/avg/max = 11.835/13.794/15.753 ms
测试结果
