嵌入式开发,避免不了要看芯片手册,Datasheet常用英文单词及缩写总结
2018年08月13日 14:29 发布者:xyd521
做嵌入式开发,避免不了要看芯片手册(包括参考手册、用户手册等),通常在开头的章节会有“Documentation conventions”,意思就是编写文档时的一些约定规则,其中就包括很多半导体行业的专业术语及其英文缩写。因此,为了看明白相关文档,我们最好还是记一下这些常用的专业词汇以及它们的缩写吧。英文缩写
ARM:Advanced RISC Machine
AAPCS:ARM Architecture Process call standard ARM体系结构过程调用标准
RISC: Reduced Instruction Set Computer 精简指令集计算机
RTOS:Real Time Operating System 实时操作系统
DMA:Direct Memory Access 存储器直接访问
EXTI: External Interrupts 外部中断
FSMC: Flexible static memory controller 可变静态存储控制器
FPB:flash patch and breakpoint FLASH 转换及断电单元
HSE:Hign speed external
HSI: High speed internal
LSE: Low Speed external
LSI: Low Speed Internal
LSU: load store unit 存取单元
PFU: prefetch unit 预取单元
DPU:Dataflow Processing Unit,数据流处理单元
FPU:Floating Processing Unit,浮点计算单元
ISR:Interrupt Service Routines,中断服务程序
NMI:Nonmaskable Interrupt,不可屏蔽中断
NVIC:Nested Vectored Interrupt Controller,嵌套向量中断控制器
MPU:Memory Protection Unit,内存保护单元
MMU:Memory Management Unit,内存管理单元
MIPS:million instructions per second 每秒能执行的百万条指令的条数
RCC:Reset and clock control 复位和时钟控制
RTC: Real-Time Clock 实时时钟
IWDG: independent watchdog 独立看门狗
WWDG:Window watchdog 窗口看门狗
TIM:timer 定时器
GAL:generic array logic 通用阵列逻辑
PAL:programmable array logic 可编程阵列逻辑
ASIC:Application Specific Integrated Circuit 专用集成电路
FPGA:Field-Programmable Gate Array 现场可编程门阵列
CPLD:Complex Programmable Logic Device 可编程逻辑器件
IAP:即 in-application programming,IAP is the ability to re-program the Flash memory of a microcontroller while the user program is running.
ICP:即 in-circuit programming,ICP is the ability to program the Flash memory of a microcontroller using the JTAG protocol, the SWD protocol or the bootloader while the device is mounted on the user application board.
Option bytes:product configuration bits stored in the Flash memory.
ITCM:Instruction Tighly Coupled Memory.
DTCM:Data Tighly Coupled Memory.
端口
AFIO:alternate function IO 复用IO端口
GPIO:general purpose input/output 通用IO端口
IOP(A-G):IO port A - IO port G (例如:IOPA:IO port A)
CAN:Controller area network 控制器局域网
FLITF:The Flash memory interface 闪存存储器接口
I2C: Inter-integrated circuit 微集成电路
IIS: integrate interface of sound 集成音频接口
JTAG:joint test action group 联合测试行动小组
SPI:Serial Peripheral Interface 串行外围设备接口
SDIO: SD I/O
UART: Universal Synchr./Asynch. Receiver Transmitter 通用异步接收/发送装置
USB: Universal Serial Bus 通用串行总线
寄存器相关
CPSP: Current Program Status Register 当c前程序状态寄存器
SPSP: saved program status register 程序状态备份寄存器
CSR:clock control/status register 时钟控制状态寄存器
LR: link register 链接寄存器
SP: stack pointer 堆栈指针
MSP: main stack pointer 主堆栈指针
PSP:process stack pointer 进程堆栈指针
PC: program counter 程序计数器
调试相关
ICE:in circuit emulator 在线仿真
ICE Breaker 嵌入式在线仿真单元
DBG:debug 调试
IDE:integrated development environment 集成开发环境
DWT: data watchpoint and trace 数据观测与跟踪单元
ITM: instrumentation trace macrocell测量跟踪单元
ETM: embedded trace macrocell嵌入式追踪宏单元
TPIU:trace port interface unit 跟踪端口接口单元
TAP: test access port 测试访问端口
DAP: debug access prot调试访问端口
TP: trace port 跟踪端口
DP:debug port 调试端口
SWJ-DP: serial wire JTAG debug port 串行-JTAG 调试接口
SW-DP: serial wire debug port 串行调试接口
JTAG-DP:JTAG debug port JTAG 调试接口
系统类
IRQ: interrupt request 中断请求
FIQ: fast interrupt request 快速中断请求
SW:software 软件
SWI: software interrupt 软中断
RO:read only 只读(部分)
RW:read write 读写(部分)
ZI:zero initial 零初始化(部分)
BSS:Block Started by Symbol 以符号开始的块(未初始化数据段)
总线
Bus Matrix 总线矩阵
Bus Splitter 总线分割
AHB-AP:advanced High-preformance Bus-access port
APB:advanced peripheral busAPB1: low speed APB
APB2: high speed APB
PPB: Private Peripheral Bus 专用外设总线
AHB:advanced high-performance bus.
AHBS:AHB Slave bus.
AXIM:AXI master bus.
杂类
ALU:Arithmetic Logical Unit,算术逻辑单元
CLZ: count leading zero,前导零计数(指令)
SIMD: single instruction stream multiple data stream,单指令流,多数据流
VFP: vector floating point,矢量浮点运算
DFU:Device Firmware Upgrade,设备固件升级
ICU:Instruction Cache Unit,指令缓冲存储单元
DCU:Data Cache Unit,数据缓冲存储单元
词汇/词组
Big Endian 大端存储模式
Little Endian 小端存储模式
context switch 任务切换(上下文切换)(CPU寄存器内容的切换)
task switch 任务切换
literal pool 数据缓冲池
词汇类/单词
arbitration 仲裁
access 访问
assembler 汇编器
disassembly 反汇编
binutils连接器
bit-banding 位段(技术)
bit-band alias 位段别名
bit-band region 位段区域
banked 分组
buffer 缓存/
ceramic 陶瓷
fetch 取指
decode 译码
execute 执行
Harvard 哈佛(架构)
handler 处理者
heap 堆
stack 栈
latency 延时
load (LDR) 加载(存储器内容加载到寄存器Rn)
store (STR) 存储(寄存器Rn内容存储到存储器)
Loader 装载器
optimization 优化
process 进程/过程
thread 线程
prescaler预分频器
prefetch预读/预取指
perform 执行
pre-emption 抢占
tail-chaining 尾链
late-arriving 迟到
resonator 共振器
指令相关
instructions 指令
pseudo-instruction 伪指令
directive 伪操作
comments 注释
FA full ascending 满栈递增(方式)
EA empty ascending 空栈递增(方式)
FD full desending满栈递减(方式)
ED empty desending空栈递减(方式)
更多嵌入式学习,欢迎咨询余工Q 二八五九七八零二零三
