PIC24菜鸟毕业留念---GPS串口2接收中断服务程序
2009年04月02日 22:59 发布者:hotpower
PIC24菜鸟毕业留念---GPS串口2接收中断服务程序/*------------------------------------------------------------------------
GPS串口2接收中断服务程序(接收GPS数据)
菜农HotPower之PIC24菜鸟毕业留念 2007.12.20 2:40 于菜地留念
void __attribute__((interrupt, no_auto_psv)) _U2RXInterrupt( void )
static unsigned char cData = 0, cPosition;
unsigned char ch;
if (IFS1bits.U2RXIF)//确实是GPS串口2接收中断
if (IEC1bits.U2RXIE)//GPS串口2接收中断已被允许
ch = U2RXREG;//读取串口GPS数据
if (ch == '$')//是GPS引导字符
cData = ch;//记录引导字符
cPosition = GPSRxWriteCount;//引导字符位置记录
GPSRxBuffers = ch;//存入数据
else if (cData == '$')//收到引导字符
if (ch >= ' ')//可能是有效数据
else if (ch == '*')//GPS校验引导字符
else if ((ch == '\r') && (GPSRxBuffers == '*'))//回车字符校验
else
if ((ch == '\n') && (GPSRxBuffers == '\r'))//换行字符校验
{//只取GPRMC语句
if (GPSGPRMCTest((char *)&GPSRxBuffers))
GPSbits.RXFlag = 1;//激活GPS接收成功解码程序(在“零耗时键盘OS”的空闲任务内细加工处理)
cData = 0;//结束或出错
else
cData = 0;//出错
IFS1bits.U2RXIF = 0;//清除RX2中断标志
GPS串口2初始化程序
void Uart2Init(void)
TRIS_TX2 = PORTOUTMODE;//设置TX2为输出IO
TRIS_RX2 = PORTINPUTMODE;//设置RX2为输入IO
U2MODE = 0;
// U2MODEbits.STSEL = 0;// 1-stop bit
// U2MODEbits.PDSEL = 0;// No Parity, 8-data bits
// U2MODEbits.ABAUD = 0;// Autobaud Disabled
U2STA = 0;
// U2STAbits.UTXISEL0 = 0; // Interrupt after one Tx character is transmitted
// U2STAbits.UTXISEL1 = 0;
// U2STAbits.URXISEL = 3; // Interrupt after one RX character is received
U2BRG = BRGVAL2;//BAUD Rate Setting for 19200
U2MODEbits.WAKE = 1;//启动位时唤醒使能位
U2MODEbits.UARTEN = 1; // Enable UART
U2STAbits.UTXEN = 1; // Enable UART Tx
定义GPS串口2中断优先级位1111)
IPC7bits.U2RXIP0 = 1;
IPC7bits.U2RXIP1 = 1;
IPC7bits.U2RXIP2 = 1;
IEC1bits.U2RXIE = 1;
IFS1bits.U2RXIF = 0;//清除RX1中断标志
IEC1bits.U2TXIE = 1;
IFS1bits.U2TXIF = 0;//清除TX1中断标志
