cpld与8051的总线接口vhdl设计源码
2009年11月13日 12:03 发布者:诸葛孔明
8051工作频率为11.0592MHZ CPLD(EPM7128SLC15)的工作频率为16.0000MHZ(有源晶振)library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.std_logic_unsigned.all;
entity cpldbus51 is
port (
Clk: in STD_LOGIC; --Clock 16MHZ
Clr: in STD_LOGIC; --Clear high
P0: inout STD_LOGIC_VECTOR (7 downto 0); --8052 Port 0
P2: in STD_LOGIC_VECTOR (7 downto 0); --8052 Port 2
ALE: in STD_LOGIC; --8052 ALE
-- PSEN: in STD_LOGIC; --8052'Psen
-- INT0:out STD_LOGIC; --8052 INT0
Wr: in STD_LOGIC; --8052'Wr
Rd: in STD_LOGIC; --8052'Rd
Pina:out STD_LOGIC; ---output
nCS8255: out STD_LOGIC; --select 8255
RamBank: out STD_LOGIC_VECTOR (1 downto 0);--Ram68128a bank switch A15 A16
nCsFlashRam: out STD_LOGIC; --select Flash Rom CE
FlashRomBank: out STD_LOGIC_VECTOR (2 downto 0) --Flash Rom switch A14 A15 A16
end cpldbus51;
architecture cpldbus51 of cpldbus51 is
signal Addr: std_logic_vector(15 downto 0); --16bit address
signal ALE_Sample:STD_LOGIC;
signal RamBankReg: STD_LOGIC_VECTOR (1 downto 0);--Ram bank switch reg, 4 banks, 4*32K=128k bytes
signal FlashRomBankReg: STD_LOGIC_VECTOR (2 downto 0);--Flash Rom bank switch reg, 8 banks, 8*16K=128k bytes
--Rd Sample
signal RdSample:std_logic; --for Rd Sample
--WR Sample
signal WrSample0:std_logic; --Wr for Sample
signal WrSample1:std_logic;
signal WrSample2:std_logic;
signal WrSample3:std_logic;
signal WrSample4:std_logic;
signal WrSample5:std_logic;
--Wr Sample output
signal Wr_en:std_logic;
--Clr Sample
signal ClrSample0:std_logic; -- for Clr Sample
signal ClrSample1:std_logic;
signal ClrSample2:std_logic;
signal ClrSample3:std_logic;
signal ClrSample4:std_logic;
signal ClrSample5:std_logic;
signal ClrSample6:std_logic;
signal ClrSample7:std_logic;
signal ClrSample8:std_logic;
signal ClrSample9:std_logic;
--Clr Sample output
signal Clr_en:std_logic;
--output Reg
signal PinaReg:std_logic;
begin
--Sample Clr signal
ClrSample_p:process(Clk)
begin
if Clk'event and Clk='1' then
ClrSample0<=Clr;
ClrSample1<=ClrSample0;
ClrSample2<=ClrSample1;
ClrSample3<=ClrSample2;
ClrSample4<=ClrSample3;
ClrSample5<=ClrSample4;
ClrSample6<=ClrSample5;
ClrSample7<=ClrSample6;
ClrSample8<=ClrSample7;
ClrSample9<=ClrSample8;
end if;
end process;
--Clr Enable Signal
Clr_en_p:process(Clk)
begin
if ClrSample0='1' and ClrSample1='1'
and ClrSample2='1' and ClrSample3='1'
and ClrSample4='1' and ClrSample5='1'
and ClrSample6='1' and ClrSample7='1'
and ClrSample8='1' and ClrSample9='1' then
Clr_en<='1';
else
Clr_en<='0';
end if;
end if;
end process;
--sample ALE signal
ALE_p:process(Clk)
begin
if Clr_en='1' then
ALE_Sample<='0';
else
ALE_Sample<=ALE;
end if;
end if;
end process;
--Address Latch
Address_p:process(Clk)
begin
if Clr_en='1' then
Addr<="0000000000000000";
elsif ALE_Sample='1' then
Addr<=P2&P0;
end if;
end if;
end process;
--Sample Wr
WrSample_p:process(Clk)
begin
if Clr_en='1' then
WrSample0<='1';
WrSample1<='1';
WrSample2<='1';
WrSample3<='1';
WrSample4<='1';
WrSample5<='1';
else
WrSample0<=Wr;
WrSample1<=WrSample0;
WrSample2<=WrSample1;
WrSample3<=WrSample2;
WrSample4<=WrSample3;
WrSample5<=WrSample4;
end if;
end if;
end process;
--internal Wr enable signal
WrEn_p:process(WrSample0,WrSample1,WrSample2,WrSample3,WrSample4,WrSample5)
begin
if (WrSample0='0' and WrSample1='0'
and WrSample2='0' and WrSample3='0'
and WrSample4='1'and WrSample5='1')then
Wr_en<='1';
else
Wr_en<='0';
end if;
end process;
--Rd Sample
RdSample_p:process(Clk)
begin
if Clr_en='1' then
RdSample<='1';
else
RdSample<=Rd;
end if;
end if;
end process;
--Flash Rom Chip select signal
CS_Flash_p:process(Addr)
begin
if Addr(15 downto 14)="10" then --Address:8000h--BFFFh
nCsFlashRam<='0';
else
nCsFlashRam<='1';
end if;
end process;
-- 8255 Chip select signal
cs8255_p:process(Addr)
begin
if Addr(15 downto 2)="11000000000000" then --C000h--C003h
nCS8255<='0';
else
nCS8255<='1';
end if;
end process;
-- Ram Bank Switch Reg
Ram_bank_p:process(Clk)
begin
if Clr_en='1' then
RamBankReg<="00";
elsif Addr="1100000000000100" and Wr_en='1' then --Address:C004h
RamBankReg<=P0(1 downto 0);
end if;
end if;
end process;
RamBank<=RamBankReg;
--Flash Rom Switch Reg
Flash_bank_p:process(Clk)
begin
if Clr_en='1' then
FlashRomBankReg<="000";
elsif Addr="1100000000000101" and Wr_en='1' then --Address:C005h
FlashRomBankReg<=P0(2 downto 0);
end if;
end if;
end process;
FlashRomBank<=FlashRomBankReg;
--Rd process
-- now just two in-builde register
Rd_p:process(RdSample,Addr,RamBankReg,FlashRomBankReg)
begin
if Addr="1100000000000100" and RdSample='0' then --C004h
P0<="000000"&RamBankReg;
elsif Addr="1100000000000101" and RdSample='0' then --C005h
P0<="00000"&FlashRomBankReg;
else
P0<="ZZZZZZZZ";
end if;
end process;
Pina_p:process(Clk)
begin
if Clr_en='1' then
PinaReg<='0';
elsif Addr="1100000000000110" and Wr_en='1' then --C006h
PinaReg<=P0(0);
end if;
end if;
end process;
Pina<=PinaReg;
end cpldbus51;
lising 2010年09月26日
学习学习
学习学习
应该有用,谢谢。:)
