普玛斯胶带permacel玻璃布胶带P-212胶带
2018年06月29日 10:53    发布者:kingdayscom
深圳市君达电子有限公司    力达海外有限公司Tel:0755-86173511      Fax:0755-86173512      宋先生13691895131    美国生产,“君达”一级代理,常备库存,各种宽度可裁切,特意为亲定做的宽度不能退货哟。全新原装正品 NITTO高温玻璃纤维胶带P-212 一级代理 PERMACEL因未向淘宝交1000元保证金,所以只能显示“二手”P-212 GLASS CLOTHELECTRICAL INSULATING TAPE美国高温玻璃纤维布胶带P-212APPLICATIONOur highest thermal-rated glass cloth tape.Premium tape for use wherever superior solvent resistance and flameretardancy are required.Used for insulating coil connections and coil ends,and as terminal board pads and coil outer wraps.Also,for holding coilleads and anchoring terminal boards;for sealing and enclosing hermetically-packaged components;and,for making motorlead and internal connections,slot cell edge taping,and cable harness wrapping.Recommended for general-purpose insulating and holding applications involving heavy-gauge wire and/or high temperatures.FEATURES AND BENEFITS• High thermal rating,flame retardancy and superior conformability make P-212 ideal in high temperature cable harnesses and connection insulating applications.• Excellent edge tear resistance.• Offers superior solvent resistance.TECHNICAL DATAInsulation classBacking materialAdhesiveColorTotal tape thicknessAdhesion to steelTensile strengthDielectric strengthElongationFlammability ratingUL component recog.Gov’t specificationNote:The above are typical values and should not be used in writing specifications.STOCK SIZESRefer to current Electrical Division Price List.200 ° C Glass clothSiliconeWhite7.5 mils/0.191 mm40 oz.per in./445 gm per cm190 lbs.per in./34.2 kg per cm3,500 volts7%Passes UL 510 Flame TestGuide OANZ2,File E20392Fungus resistance MIL-I-4053;MIL-I-19166C,7 MIL¥3千以上,可帮亲开发票的。需提供营业执照、国税登记证、开票资料。快递首重¥12,广东续重加收¥1/kg,省外加收¥6/kg。大约0.01kg/mm宽。 https://img.alicdn.com/imgextra/i4/103368107/T2UuT1Xj8XXXXXXXXX_!!103368107.jpg
金额不足¥500需增加5mm上机修边损耗。任意宽度均可裁切,一旦裁切不可退货。
JLCS 2018年06月29日
谢谢分享
