ads1258接收过来的数据跑乱了
2010年12月11日 17:24 发布者:yao1314520shi
哪位高手大侠指导指导啊 从ads1258读过来的数据跑乱,不正常,是不是设置错了。用DRDY做外部中断触发写的程序如下: 初始化void ads1258_init(void){
cs = 1;
cs = 0;
spi_send_byte(0xc0); //reset command
START = 0;
spi_send_byte(0x70); //write registers/MUL=1¡£
spi_send_byte(0x06); //wait for 4096fclk then SPI reset/chopping = 1 /enable status
spi_send_byte(0x33); //standby mode/delay us/data rate
spi_send_byte(0x00);
spi_send_byte(0x00); spi_send_byte(0x5a); //single input 1.3.4.6
spi_send_byte(0x55); //single input 8.10.12.14
spi_send_byte(0xff);
spi_send_byte(0x8b);
START = 1;
} DRDY低电平触发中断到接收数据服务程序void int1_isr(void) interrupt 2
unsigned char status;
spi_send_byte(0x30); //register form
status = spi_send_byte(0xee) ; XBYTE = spi_send_byte(0xee); XBYTE = spi_send_byte(0xee); XBYTE = spi_send_byte(0xee);
} 程序运行起来后,通道数据和状态字节会混淆跑乱
