Site Analyzer BIRD SA-6000EX new U.S. cable and antenna tester
2010年11月20日 10:23 发布者:szjn17
Site Analyzer BIRD SA-6000EX new U.S. cable and antenna tester(Shenzhen) Contact: Mr. Yang Mobile: 13570809426
Miss Tang 13713901971
TEL :86-755-18924661127 27228166 FAX :86-755-27228940
Http: / / www.szjn17.com E-mail/MSN: tosstar17@126.com
QQ: 305636259 747419145
****** SA-6000EX 25M --- 6000MHZ 5 sets of new, original! Special offer!
Product Name: SA-6000EX (SA-2500EX) communication base station Antenna Test System
Product Type: sa_6000ex
Brand: American Bird cards (Bird)
Brief
SA-6000EX (SA-2500EX) communication base station Antenna Test System is the United States Bird cards (BIRD) brand communication base station Antenna Test System.
SA-6000EX (SA-2500EX) communication base station Antenna Test System Details
SA-6000EX (SA-2500EX) is mainly used for various communications base station Antenna system testing. Including clusters, GSM, PCS / DCS, CDMA, GPRS and paging systems. In the days of feeder system installation, testing and routine maintenance tune their conduct standing wave ratio (VSWR), return loss, cable loss, power and fault location and other tests.
SA-6000EX Test frequency: 25 ~ 6000MHz
* For beginners, occasional use and easy to operate commonly caught
* Measurement of high accuracy and reproducibility
* On-line field test inhibition of +13 dBm (± 10kHz) / +22 dBm (± 1MHz) of the interference signal
* High-definition color display
* Fast switching speed
* Measured with the screen display comparison chart
* Unlimited check test report
* Compatibility
Rapid identification of small problems, take preventive measures:
With high directivity and good matching characteristics of the source to ensure matching and fault location testing the accuracy and repeatability
· 60dB dynamic range ensures high positioning of small fault
* High-resolution data tags read SWR, and expensive laboratory equipment with the same precision
? Use the instrument's measurement data on the conversion of existing
* Cable insertion loss measurements can be
Can be measured with a Bird Digital Power Sensor Power
Superior anti-jamming capability, unlimited test conditions:
High level interference signals will affect other similar testers use. The instrument has a high anti-interference ability,
It can suppress up to +13 dBm (± 10kHz) / +22 dBm (± 1MHz) of the interference signal, it can not close the communication set
Prepared in the conduct of on-site day feeder analysis
* Shows the forward and reverse power, VSWR, return loss
* Compatible MODEL 5010B Power Sensor
SA-2500EX:
Altitude: Up to 15,000 feet (4572 m)
Data Transfer: 9 pin-RS-232 (DB9), compatible with serial port
Dimensions: 10.5" x 8.4" x 3.3" (265 mm x 212 mm x 83 mm)
External AC: 90 to 264 Vac @ 45-66 Hz; AC/DC adapter required
External DC: 9-16 VDC fused, <3 A
Frequency Range: 780-2500 MHz
Frequency Resolution: 50 kHz
Humidity: 95% ± 5% max. (non-condensing)
Immunity to Interfering Signals: Rejects on-frequency signals up to +13 dBm
Impedance: 50 Ohms
Internal Time: Rechargable Lithium-Ion batteries, 3 hour minimum operating time. Auto shut-off conserves battery life.
Maximum Input Signal: +22 dBm
Operating Temp.: -10°C to 50°C (14°F to 122°F)
Power Measurement: Yes
Return Loss: 0 to -60 dB
Setup Storage Capacity: 15-Set-Ups/(500) 238 ponit traces
Speed: 1 multi-frequency scan (238 points)/2 seconds; 1 multi-frequency scan (475 points)/3.5 seconds; 1 multi-frequency scan (949 points)/6 seconds
Storage Temperature: -40°C to 80°C (-40°F to 176°F)
Test Port: N-type female connector
Trace Resolution: 238 (default), 475, or 949 per trace
Upgradeable: Yes, SA-6000EX
Weight: 5.5 lbs. (2.5 kg)
SA-6000EX
Frequency Range: 25-6000 MHz
Frequency Resolution: 25 kHz; 25-800 Mhz, 50 kHz; 800-2500 MHz, 100 kHz; 2500-6000 MHz
Impedance: 50 Ohms
Setup Storage Capacity: 15 Set-Ups/(500) 238 point traces
Upgradeable: No
