MSP430口线模拟I2C总线
2008年11月04日 21:08 发布者:MSP430
MSP430口线模拟I2C总线
/**********************************************************************************************功能: 实现MSP430口线模拟I2C总线协议与24C04通信. *
* 描述: 主系统工作时钟为12MHz,I2C工作时钟频率为1MHz.给某地址写入一个数据 *
* 再读出来,如写入前和读出后的数据一致,则P1.0输出高电平,否则输出低电 *
* 平. *
* MSP430x22x4 10k 10k ATMEL 24c04 *
* master | | slave *
* -|XIN P3.1/UCB0SDA|<-|----+>|SDA | *
* 32kHz | | | | | *
* -|XOUT | | | | *
* | P3.2/UCB0SCL|<-+-----> |SCL | *
* 作者: Singel *
* 时间: 2008年10月17日22时35分 *
* 此例在 IAR Embedded Workbench IDE for MSP430 v3.42a 调试通过 . *
#include <MSP430x22x4.h>
#define SlaveWriteAddress 0xa0
#define SlaveReadAddress 0xa1
#define OwnAddress 0xee
#define I2CSDA BIT1
#define I2CSCL BIT2
#define I2CSDA_SET_1 P3OUT |= I2CSDA
#define I2CSDA_SET_0 P3OUT &=~ I2CSDA
#define I2CSCL_SET_1 P3OUT |= I2CSCL
#define I2CSCL_SET_0 P3OUT &=~ I2CSCL
#define I2CSDA_INPUT_IN P3IN&I2CSDA
unsigned char READI2CBUF;
void delay5us( void )
unsigned char count=8;
while(count--);
void Delay_MS( unsigned int m )
unsigned int i,j;
for(i=0;i<m;i++)
for(j=0;j<125;j++);
void Setting_System_Clock_For_On_Chip_RC( char Frequency )
switch (Frequency)
case 1 :DCOCTL = BCSCTL1 = CALBC1_1MHZ;break;
case 8 :DCOCTL = BCSCTL1 = CALBC1_8MHZ;break;
case 12:DCOCTL = BCSCTL1 = CALBC1_12MHZ;break;
case 16:DCOCTL = BCSCTL1 = CALBC1_16MHZ;break;
void I2C_Pins_DIR_Setting ( unsigned char SDADIR )
P3DIR |= I2CSDA + I2CSCL;
if(SDADIR==1)
P3DIR &=~ I2CSDA;
P3OUT &=~ I2CSDA;
void Engender_I2C_start_signal(void)
I2CSCL_SET_1; delay5us();
I2CSDA_SET_1; delay5us();
I2CSDA_SET_0; delay5us();
void Engender_I2C_stop_signal(void)
void Engender_I2C_ack_signal(void)
I2CSCL_SET_0; delay5us();
void Engender_I2C_noack_signal(void)
void WRITE_BYTE_TO_24C04( unsigned char BytEDAta )
unsigned char count;
for(count=0;count<8;count++)
I2CSCL_SET_0;
delay5us();
if(BytEDAta&0x80)I2CSDA_SET_1;
else I2CSDA_SET_0;
delay5us();
I2CSCL_SET_1;
delay5us();
BytEDAta<<=1;
unsigned char READ_BYTE_TO_24C04( void )
unsigned char count,readbyte=0;
I2CSCL_SET_0;
readbyte=readbyte<<1;
I2CSCL_SET_1;
delay5us();
if(I2CSDA_INPUT_IN)readbyte=readbyte|0x01;
else readbyte=readbyte&0xfe;
delay5us();
I2CSCL_SET_0;
delay5us();
I2CSCL_SET_0;
return readbyte;
void WRITE_DATA_TO_24C04( unsigned char Address,unsigned char Date )
Setting_System_Clock_For_On_Chip_RC(1);
I2C_Pins_DIR_Setting(0);
Engender_I2C_start_signal();
WRITE_BYTE_TO_24C04(SlaveWriteAddress);
Engender_I2C_ack_signal();
WRITE_BYTE_TO_24C04(Address);
WRITE_BYTE_TO_24C04(Date);
Engender_I2C_stop_signal();
Delay_MS(15);
I2CSCL_SET_0;
I2CSDA_SET_0;
Setting_System_Clock_For_On_Chip_RC(12);
unsigned char READ_DATA_FROM_24C04( unsigned char Address )
unsigned char readdate;
Delay_MS(15);
WRITE_BYTE_TO_24C04(SlaveReadAddress);
I2C_Pins_DIR_Setting(1);
readdate=READ_BYTE_TO_24C04();
Engender_I2C_noack_signal();
I2CSCL_SET_0;
I2CSDA_SET_0;
return (readdate);
void main( void )
unsigned char Data=0x59;
WDTCTL = WDTPW+WDTHOLD;
P1DIR |= BIT0;
while(1)
WRITE_DATA_TO_24C04(0X00,Data);
READI2CBUF=READ_DATA_FROM_24C04(0x00);
if(Data == READI2CBUF)
P1OUT |= BIT0;
else
P1OUT &=~ BIT0;
Delay_MS(15);
maanzhenhow 2011年04月13日
太谢谢了
太谢谢了
谢谢了
