2012年9月18日全新升级LP_wizard V10.5 ,自动生成器件封装
2010年07月31日 02:05 发布者:fenghaili
截图就不更新了。10.4版本,9个附件。System Requirements
Microsoft .NET Framework Version 3.5
LP Wizard requires Mircosoft .NET Framework Version 3.5 to function. You must install Microsoft .NET Framework 3.5 before or after installing the LP Wizard software. Later versions of Mircrosoft .NET Framework (v4.0) are not compatible.
Problems Fixed in This Release
This section describes problems fixed for the LP Wizard 10.5 release.
DR 00875188—Via Calculator preview display is wrong, regression from 10.3.2
DR 00887058—Incorrect pad orientation
DR 00883089—The SOT-223 thermal pad rotation is incorrect
DR 00882190—Excessive heel trim on pads on the long side of the thermal pad
DR 00877681—Silkscreen is not generating properly when enabling skill scripts in
LPW 10.4
DR 00906115—LPW 10.4 export of BGA's to PADS 9.4 is missing alphanumeric pin
name control for either Part or Decal
DR 00878639—Print shows incorrect pin numbers
DR 00898311—Mirrored or rotated print output of Shrouded right angle header land
pattern
不知道LP Wizard是啥的,看下边两个帖子
http://www.eechina.com/thread-5719-1-1.html
http://www.eechina.com/thread-979-1-1.html
下载:
88404
88405
88406
88407
88408
88409
88410
88411
88412
破解下载地址:http://www.eechina.com/thread-111500-1-1.html
CAD outputs changed in LP Wizard 10.3.2
A number of LP Wizard tool outputs were changed beginning with the LP Wizard 10.3.2 release.
Users of all the EDA tools listed as having their 'direct' -that is, "named" - CAD Output support removed should determine if the Universal Cad Output, PADS ASCII (PADS or *.d, *.p), can be utilized for their EDA tool going forward.
Below is a breakdown of what is now supported in LPW.
Directly - Tool specific CAD Outputs LPW
* Allegro
* OrCAD PCB Editor
* Board Station
* Expedition
* PADS Layout
* PADS Layout ASCII
Indirectly -These CAD tools use the above PADS Layout and/or PADS Layout ASCII CAD Output in LPW and can import PADS Layout ASCII.
* Altium (PADS ASCII and V5.0 PADS .p & .d files)
* Pulsonix (PADS V5.0 and V2007)
* CADSTAR
* Pantheon
* CR-5000
These LPW CAD Outputs were removed:
* McCAD
* Ultiboard
* OrCAD Layout
* P-CAD
* Eagle
LPW previously had the ability to create CADSTAR .cpa library files, this is no longer available with 10.3.2 and newer. LPW 10.3.1 last had this ability.
dongfanghong 2010年07月31日
好,:victory:
好,:victory:
bleaz 2010年07月31日
谢谢!
谢谢!
zhqiankun 2010年07月31日
顶,狂顶!
顶,狂顶!
whwqm 2010年07月31日
学习学习
学习学习
fanfusuzi 2010年07月31日
非常的需需要,谢谢
非常的需需要,谢谢
libukun 2010年07月31日
好东西要顶
好东西要顶
windmil 2010年08月01日
回复1楼fenghaili: 谢谢楼主
回复1楼fenghaili: 谢谢楼主
szhacker 2010年08月01日
好,支持
好,支持
kevinsz 2010年08月01日
好东东,谢谢楼主
好东东,谢谢楼主
mantis0243 2010年08月01日
thank
thank
OrcadUser 2010年08月01日
Hey !! Thanks
Hey !! Thanks
jian8415 2010年08月01日
自动生成器件封装
自动生成器件封装
larryfarn 2010年08月01日
Good job.:victory: 回复1楼fenghaili:
gsywm 2010年08月02日
这个软件生成pcb封装后导入pads 怎么看不到丝印,只有焊盘?
fenghaili 2010年08月02日
gsywm 发表于 2010-8-2 09:17 http://www.eechina.com/images/common/back.gif
看不到丝印,是因为你设置了丝印的颜色与背景色颜色一样,都是黑色,所以你看不到丝印。
hqqymh 2010年08月02日
好 支持!
好 支持!
hqgboy 2010年08月02日
THANKS
THANKS
jerryonline 2010年08月02日
哇,这个是最新版的吧,楼主真强
哇,这个是最新版的吧,楼主真强
johan 2010年08月02日
好东西, 支持!
好东西, 支持!
试了一下,确实可用,把MGLS.DLL替换后没有日期限制,但是multipart还是用不了,不能一次生成多个封装,只能一个一个生成
haneaton 2010年08月02日
看看啊,好东西
看看啊,好东西
mrzdb2008 2010年08月02日
顶
顶
w1976d 2010年08月03日
非常需要,能用吗
非常需要,能用吗
wugang 2010年08月03日
看看!!
看看!!
Anqi160 2010年08月03日
看看
看看
starlin 2010年08月03日
多谢楼主啊,找了半天了
多谢楼主啊,找了半天了
stefan2005 2010年08月04日
I really want to knwow how can man crack it
ye_song 2010年08月04日
这个是最新版的吧
这个是最新版的吧
bayi255 2010年08月05日
谢谢楼主!
谢谢楼主!
jslynisong 2010年08月05日
好东西,谢谢分享。
好东西,谢谢分享。
lhhuan 2010年08月05日
还能用不?
还能用不?
IFIREFLY 2010年08月06日
谢谢分享!
谢谢分享!
newlife_lyf 2010年08月06日
好,支持
好,支持
tangchanglong 2010年08月06日
自动生成器件封装,不错
自动生成器件封装,不错
keilly 2010年08月07日
support you, very good
jgxouc 2010年08月07日
很好呀
很好呀
elm99 2010年08月07日
xiexie
xiexie
logebb 2010年08月07日
厲害~真牛~
厲害~真牛~
bright 2010年08月07日
頂﹐希望不要讓我希望﹐我可是為了這個才注冊的哦
xdgood 2010年08月07日
好,支持
好,支持
ericnan 2010年08月08日
哇,这个是最新版的吧,楼主真强厉害!THANKS!
munababy 2010年08月08日
这么好的东东,太好了。
这么好的东东,太好了。
xayaya 2010年08月08日
顶顶顶
顶顶顶
lisihai 2010年08月09日
封装?以前都是手工做,改库里面的东西,
看看这个高科技
封装?以前都是手工做,改库里面的东西,
看看这个高科技
LIAOJIANXI123 2010年08月09日
:D
:D
好
好
marschiu2000 2010年08月09日
真的很實用
真的很實用
abswin 2010年08月09日
这个版本好新,Cr是楼主搞的不,好N
这个版本好新,Cr是楼主搞的不,好N
dongfanghong 2010年08月11日
好,:victory:
好,:victory:
fxue 2010年08月11日
支持一下
支持一下
iamhcy 2010年08月11日
vb as;jfda;s f
vb as;jfda;s f
iamhcy 2010年08月11日
我还是没找到下载的地方!FTP已经进去了!
andrejrashnikov 2010年08月12日
thanks
thanks
zls 2010年08月12日
终于找到了,谢谢
终于找到了,谢谢
hwg_LDW 2010年08月12日
很好的工具。
很好的工具。
pwwzlxz 2010年08月12日
谢谢。下载试用一下
谢谢。下载试用一下
zjfeng84 2010年08月12日
thanks
thanks
hb123 2010年08月12日
谢谢!
谢谢!
atianjun 2010年08月13日
怎么样。。。好用吗
怎么样。。。好用吗
mo910 2010年08月13日
LZ很好 很强悍
LZ很好 很强悍
xqzhao206 2010年08月13日
xiexiela
xiexiela
lucky_jeck 2010年08月13日
好東東,謝謝!!!
好東東,謝謝!!!
xiaoweihuacom 2010年08月13日
正到处找了,多谢楼主无私奉献
正到处找了,多谢楼主无私奉献
toplayout 2010年08月14日
真是太好了,可爱的Mentor
真是太好了,可爱的Mentor
qiuqinglin 2010年08月14日
支持下
支持下
ahwei 2010年08月15日
不错,谢谢
不错,谢谢
laber 2010年08月15日
顶啊,感谢分享
顶啊,感谢分享
laber 2010年08月15日
酷啊,再次感谢下`
酷啊,再次感谢下`
feiante 2010年08月15日
好东西,强!
好东西,强!
feiante 2010年08月15日
能不能直接给个下载地址,我这不能用FTP,晕~~~
zswlh 2010年08月15日
哇,这个是最新版的吧,楼主真强
哇,这个是最新版的吧,楼主真强
xieancn 2010年08月16日
很好,看看再说。。。
回复1楼fenghaili:
很好,看看再说。。。
回复1楼fenghaili:
laber 2010年08月16日
如何破解呢?
如何破解呢?
sl961102 2010年08月18日
是好东西啊。
是好东西啊。
不过有没有视频 啊,学习一下。
不过有没有视频 啊,学习一下。
SZVIOLET 2010年08月18日
好东西啊,找了很久
好东西啊,找了很久
为什么看不到啊
为什么看不到啊
怎么破解啊
怎么破解啊
怎么破解啊
怎么破解啊
zlq6585 2010年08月18日
绝对支持!精品哈。。
绝对支持!精品哈。。
lix212121 2010年08月18日
hutusheng 2010年08月19日
我还真不知道是干啥嘞,嘻嘻
我还真不知道是干啥嘞,嘻嘻
gfzlc 2010年08月19日
正寻觅中,谢谢LZ
正寻觅中,谢谢LZ
tercel8888 2010年08月20日
这个东东好哟
这个东东好哟
Anqi160 2010年08月20日
为啥装了后不能wizard呢?
为啥装了后不能wizard呢?
Anqi160 2010年08月20日
我用的是pads9.0破解的
我用的是pads9.0破解的
dreambird 2010年08月21日
楼主 我不是马甲 但我爱你
楼主 我不是马甲 但我爱你
楼主我爱你爱的发疯
楼主我爱你爱的发疯
楼主太好了
楼主太好了
晕 还得继续灌水呀,要不没法子虾子啊
晕 还得继续灌水呀,要不没法子虾子啊
支持楼主
支持楼主
Thank U 楼主
Thank U 楼主
tyqtyq1 2010年08月21日
那么快
那么快
simhfc 2010年08月21日
最新版~~
谢谢!
最新版~~
谢谢!
dreambird 2010年08月22日
好 支持!!!
好 支持!!!
mengzhuhao 2010年08月22日
xue xie xia
xue xie xia
xugq 2010年08月23日
好棒啊.狂支持楼主.
好棒啊.狂支持楼主.
westlife_0829 2010年08月23日
好东西要顶
好东西要顶
kun9766 2010年08月24日
正常破解=免费?
正常破解=免费?
371340158 2010年08月25日
好东西,顶LZ,新人,多多关注
好东西,顶LZ,新人,多多关注
cmos2345 2010年08月27日
谢谢正在找呢
谢谢正在找呢
xwr213 2010年08月28日
看看好用吗?
看看好用吗?
ordman10 2010年08月28日
才发现有这么好的软件。
才发现有这么好的软件。
weixiaojian 2010年08月29日
回复20楼jerryonline:
回复20楼jerryonline:
zhuochaoer 2010年08月29日
好东西,看看能用不
好东西,看看能用不
softchip 2010年08月30日
很好用
很好用
wxd 2010年08月31日
好贴,可找到了。
好贴,可找到了。
lqf785435771 2010年08月31日
顶,高手
顶,高手
xiaoqian0501 2010年08月31日
谢谢,正在学习呢
谢谢,正在学习呢
endemb 2010年08月31日
謝謝分享,正想試用看看^^
謝謝分享,正想試用看看^^
lyq8863540 2010年08月31日
好东西啊
好东西啊
fymbl 2010年08月31日
正需要。
正需要。
sir911 2010年09月01日
震撼
震撼
shilingwork 2010年09月01日
好用吗。
好用吗。
lwd_lr 2010年09月02日
自动生成器件封装
自动生成器件封装
embcom010 2010年09月03日
没用过。
没用过。
a300su37f22 2010年09月03日
好东东
好东东
jjbb 2010年09月03日
xiexiexiexie
xiexiexiexie
BLUEKINGXQ 2010年09月03日
收购以后破解太简单了
收购以后破解太简单了
sirxx 2010年09月05日
正在找这个软件,还是最新版的,楼主很牛,
fymbl 2010年09月05日
看看。
看看。
danny0314a 2010年09月05日
謝謝大大的分享。
謝謝大大的分享。
wgzwmtwk 2010年09月06日
看看
看看
a407154061 2010年09月06日
找了很长时间了,谢谢了~~
找了很长时间了,谢谢了~~
dzliujiang 2010年09月07日
跟下面鏈接的那兩個有什麼不同?
跟下面鏈接的那兩個有什麼不同?
wangjd0819 2010年09月08日
谢谢,非常需要
谢谢,非常需要
zhaolightlee 2010年09月09日
好东西,顶顶
好东西,顶顶
294821050yw 2010年09月11日
好东东,谢谢楼主
好东东,谢谢楼主
anxue49 2010年09月11日
正好这几天在做封装,爽啊
正好这几天在做封装,爽啊
wannago 2010年09月11日
是10.1.1的吗?
是10.1.1的吗?
violet701 2010年09月11日
好,支持
好,支持
gillin 2010年09月13日
頂下,好東西
頂下,好東西
六月的雪 2010年09月13日
感谢楼主分享。。。。。
感谢楼主分享。。。。。
雨下枫 2010年09月14日
谢谢
谢谢
skyflyzheng 2010年09月14日
需要这个东西啊
需要这个东西啊
mqxc 2010年09月15日
谢谢楼主
谢谢楼主
easydesigner 2010年09月16日
xiexie
xiexie
liushushu 2010年09月17日
非常的需需要,谢谢
非常的需需要,谢谢
ZLUNTAN 2010年09月19日
THANKS!!!!!!!!!!!!!!!!!!!
lin431 2010年09月19日
好东西要顶
好东西要顶
hhmickey 2010年09月20日
好资料,这个一定要顶!
好资料,这个一定要顶!
qq365576292 2010年09月20日
强力支持~!
强力支持~!
Yoran 2010年09月21日
good
good
wuzylong 2010年09月21日
:victory:好东西
:victory:好东西
unique09 2010年09月22日
谢谢分享,以前下了个试用版的
谢谢分享,以前下了个试用版的
csest 2010年09月24日
rinimama
rinimama
vagabondzzz 2010年09月25日
破解有啦?
破解有啦?
qiuzhang 2010年09月25日
非常的需需要
非常的需需要
kinlin 2010年09月27日
好,为国人提供方便
好,为国人提供方便
lijiamin 2010年09月27日
很好
很好
xiaojj2005 2010年09月27日
楼主真强
楼主真强
xyz750304 2010年09月27日
值得研究的软件
值得研究的软件
minger2008 2010年09月27日
学习学习
学习学习
Higher 2010年09月28日
这个我用过了,挺好用,很强大
这个我用过了,挺好用,很强大
bradley 2010年09月28日
谢谢分享啊!
学习一下,这个东西应该还是很好用的
19673
19674
下载与破解
**** 本内容被作者隐藏 ****
fenghaili 发表于 2010-7-31 02:05 http://www.eechina.com/images/common/back.gif
谢谢分享啊!
学习一下,这个东西应该还是很好用的
19673
19674
下载与破解
**** 本内容被作者隐藏 ****
tpbl 2010年09月29日
支持
支持
anxue49 2010年09月29日
正需要这个,这几天做封装累啊
正需要这个,这几天做封装累啊
zhuhs2000 2010年09月29日
qqqqqqqqqqqqqqqqqqqqqqqqqqqqq
zym0805 2010年09月30日
好东西
好东西
kankanxinwen 2010年10月01日
好好学习能提高工作效率。谢谢楼主
好好学习能提高工作效率。谢谢楼主
zcg10129 2010年10月02日
相当不错的软件
相当不错的软件
yuanyuan0205 2010年10月02日
谢谢斑竹分享!
谢谢斑竹分享!
onecrazy 2010年10月04日
:victory:
:victory:
walkrain 2010年10月04日
谢谢楼主分享!
谢谢楼主分享!
xhymsg 2010年10月04日
绝对好东西
绝对好东西
neu_csz 2010年10月04日
看看,厉害
看看,厉害
xhymsg 2010年10月04日
在哪个目录啊
在哪个目录啊
lattice2008 2010年10月06日
回复1楼fenghaili:
回复1楼fenghaili:
OK
OK
goooog 2010年10月07日
:lol,太强打了
:lol,太强打了
honghuineng 2010年10月07日
KAN KAN KAN IKAN KA
KAN KAN KAN IKAN KA
xujunmsn 2010年10月08日
看一下,很需要这个软件哦
看一下,很需要这个软件哦
shincozxf 2010年10月08日
sadfasdfasdfsadfasdfasdfasf
84796509 2010年10月09日
顶
顶
daverong 2010年10月09日
自动生成器件封装
自动生成器件封装
chaplin1999 2010年10月09日
非常的需需要,谢谢
非常的需需要,谢谢
gwlionnet 2010年10月09日
good have a look
good have a look
rainbow371 2010年10月10日
想试试看
想试试看
guojun0718 2010年10月10日
iskey 2010年10月11日
看看
看看
sunnycode 2010年10月12日
回复1楼fenghaili:
回复1楼fenghaili:
jinsihu2005 2010年10月13日
支持
支持
innorx 2010年10月13日
好,东西,看看,谢谢啦
好,东西,看看,谢谢啦
rainman.cn 2010年10月13日
是新版的吗,
是新版的吗,
super 2010年10月13日
谢谢楼主,看看
谢谢楼主,看看
sunxiaosheng 2010年10月13日
学习以下
学习以下
weiyaohui 2010年10月13日
good
good
gonboy 2010年10月14日
sdfgasgsgwefasdf
sdfgasgsgwefasdf
blue 2010年10月14日
很好,学习!
很好,学习!
dilong212 2010年10月14日
下载个看看!我刚下载个7.02比较一下那个好用呢!!!
chenlei8 2010年10月14日
学习下
学习下
chenzy1985 2010年10月14日
有发现一个好东西,谢谢楼主
有发现一个好东西,谢谢楼主
zlq0416 2010年10月15日
很好很强大
很好很强大
songjialiu 2010年10月16日
nice
nice
楼望峪 2010年10月16日
好像见过
好像见过
rsjcqr 2010年10月18日
正要找这个,真不错。谢谢
正要找这个,真不错。谢谢
rsjcqr 2010年10月18日
下来用一下看这个破解好用不。
下来用一下看这个破解好用不。
sl961102 2010年10月18日
哪位把自动生成原件库的那个用起来了,用了半天,不能导入DXP,郁闷。
jonson69 2010年10月18日
Thank you!
Thank you!
hcf830716 2010年10月19日
看看
看看
caishang 2010年10月20日
谢谢,看看
谢谢,看看
tigerdill 2010年10月20日
学习 支持 收下了
学习 支持 收下了
fclever 2010年10月21日
好东西要顶
好东西要顶
fzu_csc 2010年10月21日
支持
支持
hbnd2008 2010年10月22日
好用吗
好用吗
protell 99se 能用吗
protell 99se 能用吗
shijiezhiai 2010年10月23日
急需啊,谢谢分享啊
急需啊,谢谢分享啊
seekabc 2010年10月24日
看一看先
看一看先
tottionly 2010年10月25日
好东西 谢谢
好东西 谢谢
gofront 2010年10月26日
个人空间 空间 发短消息 发消息
这个是最新版的吧,楼主真强
个人空间 空间 发短消息 发消息
这个是最新版的吧,楼主真强
kevincy 2010年10月26日
支持
支持
kevincy 2010年10月26日
支持
支持
gongjian32 2010年10月29日
,这个是最新版的吧,楼主真强
,这个是最新版的吧,楼主真强
xq200809 2010年10月29日
楼主 真的能破解LP wizard吗??我安装了,但说我的licence有问题
这样能行吗??
这样能行吗??
scsunjia 2010年10月29日
非常好的工具
非常好的工具
mrzdb2008 2010年10月30日
thanks
thanks
gyj82117 2010年10月31日
ffffffffffffffffffffffffffffffffffff
12yu3 2010年10月31日
hao
hao
shiningciomp 2010年11月01日
找了很久!!!
找了很久!!!
gyj82117 2010年11月01日
liuweiping1122 2010年11月01日
看看
看看
molinchz 2010年11月01日
好,支持
好,支持
yanhao_xj 2010年11月02日
顶啊。
顶啊。
youvega 2010年11月02日
顶一个
顶一个
tigerp 2010年11月03日
正好需要,谢谢了
正好需要,谢谢了
392331751 2010年11月04日
支持~~~
支持~~~
zhoujin0 2010年11月04日
很好,很强大!
很好,很强大!
brian.tian 2010年11月05日
太好了 终于找到了 谢谢啊!
太好了 终于找到了 谢谢啊!
找不到啊?!
找不到啊?!
zhoujin0 2010年11月05日
感谢贡献!
感谢贡献!
lynyeah 2010年11月07日
zhao le hen jiu
zhao le hen jiu
杜木土 2010年11月07日
好东西
好东西
大道至公 2010年11月07日
最新版?你太猛了,我刚下了链接的那个软件
lsh222 2010年11月08日
看看!!!!!!!!!!!!
看看!!!!!!!!!!!!
wgj_king 2010年11月08日
这个是好东西,必须要顶。
这个是好东西,必须要顶。
mac0227 2010年11月08日
好東西正好派上用場,感謝!
好東西正好派上用場,感謝!
lan_tian88 2010年11月08日
顶,楼主啊
顶,楼主啊
si1024 2010年11月08日
牛
牛
flexcore 2010年11月08日
thanks for LP wizard V10.1.1 !
leoliu2009 2010年11月09日
好东西,谢谢楼主了!
好东西,谢谢楼主了!
baxk 2010年11月10日
楼主真强.............
楼主真强.............
kkh1985 2010年11月10日
好东西~~~
好东西~~~
bluesky_jian 2010年11月10日
have a look ! thank you !
zxjpcb 2010年11月11日
感谢楼主,好东西大家分享!
感谢楼主,好东西大家分享!
jinfangwang 2010年11月11日
好东东,谢谢楼主
好东东,谢谢楼主
liufayu 2010年11月11日
多谢分享了!
多谢分享了!
monkze 2010年11月12日
哇,这个是最新版的吧,楼主真强
哇,这个是最新版的吧,楼主真强
zheshiwo 2010年11月13日
好,谢谢!
好,谢谢!
wuchenchen1217 2010年11月13日
我要看。
我要看。
cqnorman 2010年11月13日
不会吧!这么牛!
不会吧!这么牛!
david_xtd 2010年11月14日
一直在查Ultra Librarian的下载地址,没想到还有更专业的,非常感谢
thinklone 2010年11月14日
太好了,支持啊。
太好了,支持啊。
chinaweg 2010年11月14日
好东西,谢谢!:victory:
好东西,谢谢!:victory:
yangwla 2010年11月14日
好东西,看看!谢谢
好东西,看看!谢谢
rui22 2010年11月15日
MENTOR_LP_wizard_V10.1.1
suh520 2010年11月15日
谢谢分享
谢谢分享
52313864 2010年11月16日
我也看看
我也看看
zml322 2010年11月16日
学习了,很需要这个啊,谢谢了!
学习了,很需要这个啊,谢谢了!
chaoloveai120 2010年11月16日
hen hao hen qiang da
liyongliang916 2010年11月16日
谢谢
谢谢
daoyue 2010年11月18日
Thanks a lot.
Thanks a lot.
0458 2010年11月18日
学习学习
学习学习
0458 2010年11月18日
学习学习
学习学习
LiubeibeiLIu 2010年11月18日
19673
19674
下载与破解
**** 本内容被作者隐藏 ****
谢谢谢谢
19673
19674
下载与破解
**** 本内容被作者隐藏 ****
谢谢谢谢
mchen 2010年11月19日
谢谢
谢谢
wpjack 2010年11月19日
最新版有破解了,真不错,穷人的福音啊
最新版有破解了,真不错,穷人的福音啊
dubu 2010年11月20日
支持
支持
wen198111 2010年11月21日
看能不能用啊。。下载下
看能不能用啊。。下载下
z880819 2010年11月21日
谢谢啦,真的很好吧
谢谢啦,真的很好吧
braveboys 2010年11月22日
对mentor输出有问题
对mentor输出有问题
sirenshiva 2010年11月22日
多谢分享
多谢分享
guoshaojun 2010年11月22日
好,支持
好,支持
jmw7912 2010年11月22日
不错,正需要呢
不错,正需要呢
dl3826 2010年11月22日
谢谢分享,太感谢了!
谢谢分享,太感谢了!
qwea 2010年11月22日
好东西要顶
好东西要顶
jlf188 2010年11月23日
狂顶!!!1
狂顶!!!1
zhangwb 2010年11月23日
看看到底是什么东西
看看到底是什么东西
embalvin 2010年11月24日
好东西啊,分享是一种品格。
好东西啊,分享是一种品格。
fzx1018 2010年11月24日
谢谢楼主
谢谢楼主
kinggink888 2010年11月24日
劲好的软件
劲好的软件
kanerier 2010年11月24日
很好,很强大,生成的标准封装
很好,很强大,生成的标准封装
daru2008 2010年11月25日
lianlian2911 2010年11月26日
支持,现在版本是10.2不知道能不能破解
suifeng0498 2010年11月26日
也不知道能不能生成库文件
也不知道能不能生成库文件
NCLucifer 2010年11月27日
太牛了 支持LZ!
太牛了 支持LZ!
eecwy 2010年11月28日
斑竹强人!我用上个版本的就觉得很爽了,!!试一试这个,哈哈
lipyu 2010年11月29日
希望能有新的发现,多谢楼主!
希望能有新的发现,多谢楼主!
cythina_ma 2010年11月30日
回复1楼fenghaili:
回复1楼fenghaili:
想知道咋破解了?
想知道咋破解了?
weichaozhou 2010年11月30日
学习一下
学习一下
连天白云pcb 2010年11月30日
ding
ding
stec1 2010年11月30日
支持
支持
z383775409 2010年12月01日
非常的需需要,谢谢
非常的需需要,谢谢
goldmusic 2010年12月01日
强!向楼主致敬!
强!向楼主致敬!
非南飞 2010年12月01日
感谢楼主!!!!!
感谢楼主!!!!!
微雨萦心 2010年12月02日
神马`好东西啊`
神马`好东西啊`
zhaoshan413 2010年12月02日
谢谢分享
谢谢分享
nrj2010 2010年12月03日
顶一下
顶一下
nrj2010 2010年12月03日
支持一下啊
支持一下啊
ch89118 2010年12月03日
好,支持
好,支持
xiaxiankun 2010年12月04日
好!东西!强悍!
好!东西!强悍!
bray 2010年12月04日
感谢楼主
感谢楼主
xuezhile 2010年12月06日
正在找这个东西~1O(∩_∩)O谢谢
正在找这个东西~1O(∩_∩)O谢谢
ccm119110 2010年12月06日
很不错....
很不错....
hbnd2008 2010年12月07日
好用吗
好用吗
liyonghe 2010年12月07日
kankan !!!!!!!!!!!!!!!!!
rederzhang 2010年12月07日
下来看看是不是最新版本。Thanks!
下来看看是不是最新版本。Thanks!
dragonserver 2010年12月08日
自动生成器件封装,LP wizard V10.1.1 被MENTOR收购,正常破解
lnhuangxin 2010年12月08日
支持
支持
arle 2010年12月11日
学习,试试看
学习,试试看
dabieshan 2010年12月13日
该顶起来啊,好东东
该顶起来啊,好东东
alaryt 2010年12月13日
哇,这个是最新版的吧,楼主真强
哇,这个是最新版的吧,楼主真强
anlinanlin 2010年12月14日
看下
看下
M333333M 2010年12月15日
正需要中~~~~~謝謝~~~~~~~~~~~~~~~~~~~~~~~~~
welenlee 2010年12月15日
学习下
学习下
tractorsai 2010年12月16日
谢谢啊!!!!!!!!:lol
谢谢啊!!!!!!!!:lol
谢谢啊
谢谢啊
hoikeung 2010年12月17日
很不错的东西,下载来看看!
很不错的东西,下载来看看!
阿南 2010年12月17日
look
look
smilan 2010年12月18日
呃
呃
lyjee 2010年12月18日
顶一个
顶一个
iampxj 2010年12月18日
dfsdysdhsjfjsjs
dfsdysdhsjfjsjs
chenlong0119 2010年12月19日
顶,楼主是小强
顶,楼主是小强
mm1327 2010年12月20日
非常需要
非常需要
swuhang 2010年12月23日
谢谢!!!
谢谢!!!
wcabcd 2010年12月23日
支持楼主
支持楼主
ycpcb 2010年12月24日
找你好久了!
找你好久了!
romexw 2010年12月24日
ok
ok
onlyonline 2010年12月24日
thanks
thanks
第一次来这上网站就看到了这么好的Tool,顺便拿下分
zong 2010年12月25日
谢谢
谢谢
lishengping 2010年12月25日
很需要这个东东
很需要这个东东
xivisi 2010年12月25日
哇,这个是最新版的吧,楼主真强
哇,这个是最新版的吧,楼主真强
ts10606 2010年12月25日
支持楼主!
支持楼主!
bpcsungod 2010年12月26日
这个软件的确不错哈
这个软件的确不错哈
come_on 2010年12月26日
thank you ,谢谢!
thank you ,谢谢!
fantj 2010年12月27日
谢谢楼主分享 我找了很久 很多都不能用
谢谢楼主分享 我找了很久 很多都不能用
iversn 2010年12月27日
是好东西,谢谢
是好东西,谢谢
HUANGKAILE 2010年12月27日
ok???
ok???
yzl624358 2010年12月27日
好啊,支持!
好啊,支持!
net_roar 2010年12月27日
看看
看看
aerofox 2010年12月27日
多谢多谢
多谢多谢
cheng66120 2010年12月27日
:victory:楼主强人
:victory:楼主强人
cheng66120 2010年12月28日
楼主怎么使用啊!焊盘怎么改成自己想要的尺寸.....
roy_2000 2010年12月28日
下载看看,谢谢
下载看看,谢谢
zjg02d2 2010年12月29日
收了,好东西
收了,好东西
mengqch 2010年12月30日
kan
kan
innorx 2010年12月30日
ding,下来看看能不能用
ding,下来看看能不能用
zhoulinshijie 2010年12月31日
谢谢
谢谢
lanbo 2010年12月31日
有完整下载的不?
有完整下载的不?
towerme 2011年01月01日
拿来研究一下
拿来研究一下
zouzhexiaozhe 2011年01月01日
要呢
要呢
bigtower 2011年01月02日
哇,这个是最新版的吧,楼主真强
哇,这个是最新版的吧,楼主真强
weiyuya 2011年01月02日
好帮帮
好帮帮
crb8 2011年01月03日
以前下了一个没破解,不知这个好用吗
以前下了一个没破解,不知这个好用吗
crb8 2011年01月03日
强烈支持楼主,顶!
强烈支持楼主,顶!
阿蛆哥 2011年01月04日
谢谢共享!感动。
谢谢共享!感动。
f2001fcn 2011年01月04日
找了好久的这款软件
找了好久的这款软件
pxfish 2011年01月05日
好东东,看看!!!!!
好东东,看看!!!!!
admiralghost 2011年01月07日
哇,这个是最新版的吧,楼主真强
哇,这个是最新版的吧,楼主真强
newintel 2011年01月08日
很好用的软件,支持
很好用的软件,支持
liaojiededepan 2011年01月09日
我要回复,看看是什么
我要回复,看看是什么
yuhongbo 2011年01月10日
ikankan,感谢分享
ikankan,感谢分享
fpga126 2011年01月11日
不知道LP Wizard是啥的
不知道LP Wizard是啥的
helsin 2011年01月12日
不错啊。
不错啊。
helsin 2011年01月12日
不错啊
不错啊
wang_fc 2011年01月13日
hao:)
hao:)
xfjembed 2011年01月13日
回复1楼fenghaili: 顶一个
回复1楼fenghaili: 顶一个
oppop 2011年01月13日
非常感谢,正在找新版的。
非常感谢,正在找新版的。
cyber211 2011年01月13日
顶,真强,只支持mentor吗?
顶,真强,只支持mentor吗?
yenan311 2011年01月13日
正愁没破解得,谢谢楼主了
正愁没破解得,谢谢楼主了
Aimarl0 2011年01月14日
想知道怎么破解的
想知道怎么破解的
wang_fc 2011年01月14日
急急急~~请问怎么把封装和符号链接在一起~~~新手不懂~~
阿南 2011年01月14日
这个能生成Allegro的封装吗?
这个能生成Allegro的封装吗?
hjunmin 2011年01月14日
绝对支持!
绝对支持!
fanxiaoqing 2011年01月15日
支持支持支持!!
支持支持支持!!
laikelang 2011年01月15日
好东西啊,感谢分享。
好东西啊,感谢分享。
begehau 2011年01月16日
好东西
好东西
syflx 2011年01月17日
真的好用吗,下来试一试
真的好用吗,下来试一试
zhaozhi0810 2011年01月18日
谢谢楼主
谢谢楼主
suchangqing 2011年01月18日
ddddddddddddddddddddddddddddddddd
hglhgl021 2011年01月20日
好谢谢楼主//
好谢谢楼主//
vbboy1025 2011年01月20日
能下载吗?
能下载吗?
jimmy9042 2011年01月21日
谢谢分享
谢谢分享
谢谢分享
谢谢分享
zzz2603 2011年01月21日
顶
顶
zd305 2011年01月21日
这个要顶!
这个要顶!
lgood 2011年01月21日
看看,谢谢分享
看看,谢谢分享
cjf205 2011年01月26日
谢谢楼主
谢谢楼主
fenghaili 2011年01月26日
最新版,修复了不少BUG,支持最新的CAD格式输出
cotterie 2011年01月26日
好东西。谢谢了。
好东西。谢谢了。
braveboys 2011年01月26日
顶楼主,刚刚看到,不过不知道生成exp的库是不是还有问题
fenghaili 2011年01月27日
回复395楼braveboys:
应该是解决了,呵呵
回复395楼braveboys:
应该是解决了,呵呵
zzz2603 2011年01月27日
顶
顶
yueyuan2003 2011年01月27日
真是太好了
真是太好了
好啊
好啊
OrcadUser 2011年01月28日
A Million Thanks !!!!!!!!!!!!!!!!!fenghaili :victory:
yueyuan2003 2011年01月28日
楼主真厉害
楼主真厉害
vagabondzzz 2011年01月29日
多谢,楼主真是好人啊,可惜我的积分呀,刷一下就没了
Ly7 2011年01月29日
实在太好啦
实在太好啦
braveboys 2011年01月29日
这个很不错,谢谢了
这个很不错,谢谢了
亲爹爹 2011年01月30日
最新的,谢谢啦
最新的,谢谢啦
bayi255 2011年01月30日
Thanks!
Thanks!
cxc 2011年01月30日
谢谢大爷!
谢谢大爷!
cxc 2011年01月30日
大爷,我回了N个帖子才把你这东东下完了真不易!!!
lvwx 2011年01月30日
THANKS
THANKS
lvwx 2011年01月31日
谢谢!
谢谢!
lvwx 2011年01月31日
谢谢!
谢谢!
yueyuan2003 2011年02月03日
绝对是好东西
绝对是好东西
zgguoqing 2011年02月05日
为什么分成了那么多部分?每个部分的作用是什么呢?
oceans0618 2011年02月08日
好东西,谢谢楼主
好东西,谢谢楼主
yueyuan2003 2011年02月09日
顶楼主
顶楼主
看了还想在看
看了还想在看
正在使用……真是好东西
正在使用……真是好东西
best_design 2011年02月09日
怎么破解!!
怎么破解!!
bhpeng 2011年02月09日
怎么破解的啊???
怎么破解的啊???
braveboys 2011年02月09日
这个版本对exp支持怎么样,可以直接导出吗
bluesky_jian 2011年02月10日
好东西,谢谢分享!!
好东西,谢谢分享!!
gyj82117 2011年02月10日
哇,这个是最新版的吧,楼主真强
哇,这个是最新版的吧,楼主真强
cdfderew r
cdfderew r
gdsgdsgsg
gdsgdsgsg
dddddddddddddddddd
dddddddddddddddddd
ddddddddddddddd
ddddddddddddddd
cxt668 2011年02月11日
PADS9.3版本里已经自带了这个版本的LP
li123w2 2011年02月12日
这个是最新版的吧,楼主真强
这个是最新版的吧,楼主真强
e123wgz 2011年02月12日
支持啊支持!!!!
支持啊支持!!!!
szm2000 2011年02月12日
谢谢楼主
谢谢楼主
阿明wh 2011年02月12日
太好了,不知以前的问题解决没有?!
太好了,不知以前的问题解决没有?!
hanpei369 2011年02月14日
好东东,谢谢楼主
好东东,谢谢楼主
zntl 2011年02月15日
好,支持:victory:
好,支持:victory:
ns1213 2011年02月15日
谢谢 学习了
谢谢 学习了
ns1213 2011年02月15日
谢谢 学习了 楼主
谢谢 学习了 楼主
ns1213 2011年02月15日
谢谢 学习了
谢谢 学习了
ns1213 2011年02月15日
谢谢 学习了
谢谢 学习了
ns1213 2011年02月15日
谢谢 学习了 楼主
谢谢 学习了 楼主
ns1213 2011年02月15日
谢谢 学习了
谢谢 学习了
ns1213 2011年02月15日
谢谢 学习了
谢谢 学习了
ns1213 2011年02月15日
谢谢 学习了
谢谢 学习了
ns1213 2011年02月15日
谢谢 学习了
谢谢 学习了
alaryt 2011年02月15日
回复1楼fenghaili:
好好好http://www.mentor.com/http://www.mentor.com/
回复1楼fenghaili:
cxyjoe 2011年02月16日
PADS 9.3里集成了
PADS 9.3里集成了
cxyjoe 2011年02月16日
又没有钱了
又没有钱了
cnmzc 2011年02月16日
这是一个伟大的软件
这是一个伟大的软件
plcpro 2011年02月16日
这个生成EE的元件能正常吗>
这个生成EE的元件能正常吗>
jinfangwang 2011年02月17日
顶,狂顶!
顶,狂顶!
laopi_embcom 2011年02月17日
回复1楼fenghaili
这样下载真是痛苦啊,下了一半分没了。。。
回复1楼fenghaili
回复1楼fenghaili: 回复一下,下一个,天啊,还要回复5次
回复1楼fenghaili: 希望楼主不要这样分享软件,痛苦!
回复1楼fenghaili: 继续回复
回复1楼fenghaili: 继续回复
回复1楼fenghaili: 终于快了,唉。。。
z_xping 2011年02月18日
hao dong xi ,ding!
hao dong xi ,ding!
weichaozhou 2011年02月18日
好像没破解,生成时还需要license
好像没破解,生成时还需要license
常春藤 2011年02月18日
回复1楼fenghaili: 速度太慢了,不支持右键下载软件下载
disth 2011年02月19日
绿色版本?
绿色版本?
cjf205 2011年02月20日
好
好
cjf205 2011年02月20日
谢谢
谢谢
cjf205 2011年02月20日
好东西
好东西
cjf205 2011年02月20日
有没有allegro破解的
有没有allegro破解的
cjf205 2011年02月20日
:victory::victory:
:victory::victory:
frog007 2011年02月20日
谢谢楼主!!!!
谢谢楼主!!!!
frog007 2011年02月20日
再次感谢!!!
再次感谢!!!
frog007 2011年02月20日
终于下完了,真不容易
终于下完了,真不容易
yueyuan2003 2011年02月24日
绝对是好玩意啊
绝对是好玩意啊
e123wgz 2011年02月24日
强强强强强强强强强强!!!!!!!!!!!!!
braveboys 2011年02月24日
狂顶以下
狂顶以下
fenghaili 2011年02月24日
已经更新update1
已经更新update1
donny_y 2011年02月25日
好,支持,能在10.1上直接安装吗?
好,支持,能在10.1上直接安装吗?
donny_y 2011年02月25日
天啊,连PDF文件也要扣钱?
天啊,连PDF文件也要扣钱?
bluesky_jian 2011年02月25日
好东西,谢谢分享!!
好东西,谢谢分享!!
mail_zang 2011年02月25日
哇,这个是最新版的吧,楼主真强
jerryonline 发表于 2010-8-2 12:40 http://www.eechina.com/images/common/back.gif
哇,这个是最新版的吧,楼主真强
fenghaili 2011年02月25日
mail_zang 发表于 2011-2-25 14:18 http://www.eechina.com/images/common/back.gif
丝印在silkscreen层,没有在TOP层,之所有看不到丝印,是因为silkscreen层你没有让他显示出来。
好,支持,能在10.1上直接安装吗?
donny_y 发表于 2011-2-25 12:42 http://www.eechina.com/images/common/back.gif
把10,1卸载了,直接装
好,支持,能在10.1上直接安装吗?
把10,1卸载了,直接装
kiewsj 2011年02月27日
非常好的一个工具,官网才10.2版本,这里已经有10.3的了,哈哈
lvwx 2011年02月27日
好,支持
好,支持
yueyuan2003 2011年02月27日
好啊
好啊
xiaoxin770922 2011年03月08日
太好啦^_^
太好啦^_^
tulip_ting 2011年03月09日
:victory:谢谢搂住
:victory:谢谢搂住
feixiangbuluo 2011年03月09日
谢谢,辛苦了!!!
谢谢,辛苦了!!!
再赚个分,不够下载了
再赚个分,不够下载了
OrcadUser 2011年03月10日
Look & Thanks !!!!!!!!!!!!!!!:)
gms02313 2011年03月10日
顶起来 好东西
顶起来 好东西
学习了
学习了
自动生成器件封装
自动生成器件封装
自动生成器件封装
自动生成器件封装
自动生成器件封装
自动生成器件封装
花心刺猬 2011年03月10日
很好,谢谢!
很好,谢谢!
glamour52 2011年03月10日
积分依然不够,没法了。
积分依然不够,没法了。
thinklone 2011年03月11日
多谢了,不过怎么破解
多谢了,不过怎么破解
mk_lm 2011年03月11日
不知道怎么样,下下来看看
不知道怎么样,下下来看看
mk_lm 2011年03月11日
我安装了怎么打不开,有知道的吗
我安装了怎么打不开,有知道的吗
glamour52 2011年03月12日
我的这么用不了?不能生成啊。
我的这么用不了?不能生成啊。
mk_lm 2011年03月12日
打不开啊,郁闷,怎么破解的
打不开啊,郁闷,怎么破解的
befriend 2011年03月14日
好东西,谢谢
好东西,谢谢
transun 2011年03月14日
感谢分享,找了好几个都不是UPDATE1,楼主好人
e123wgz 2011年03月15日
楼主真强
楼主真强
e123wgz 2011年03月15日
好,支持
好,支持
zhaozhij316 2011年03月17日
谢谢!伟大的楼住
谢谢!伟大的楼住
etsen 2011年03月19日
gdgreghrthrthrth
gdgreghrthrthrth
nigx 2011年03月20日
谢谢!
谢谢!
lb0577 2011年03月22日
软件非常好
支持了:D
软件非常好
支持了:D
mypostwww 2011年03月23日
louzutaishuaile
louzutaishuaile
rednoseho 2011年03月23日
Take a look! thanks!
welcomefu 2011年03月24日
好,谢谢楼主
好,谢谢楼主
jacklee7488 2011年03月25日
新手上路,摸索摸索,謝謝!
新手上路,摸索摸索,謝謝!
Thank a lot.
Thank a lot.
Abel 2011年03月26日
楼主,为什么我下的解压不了?
楼主,为什么我下的解压不了?
cashionruoxian 2011年03月26日
Nice and thanks~
Nice and thanks~
rednoseho 2011年03月28日
Take a look! Thanks!
viwang 2011年03月29日
强烈支持,谢谢!
强烈支持,谢谢!
龙之舞者 2011年03月29日
回复1楼fenghaili:
回复1楼fenghaili:
12yu3 2011年04月03日
不错,正需要
不错,正需要
小兔子 2011年04月04日
哇,这个是最新版的吧,楼主真强
哇,这个是最新版的吧,楼主真强
45085608 2011年04月08日
哇,这个是最新版的吧,楼主真强
哇,这个是最新版的吧,楼主真强
jlchen2004 2011年04月09日
好东西,谢谢分享
好东西,谢谢分享
care 2011年04月10日
直接更新可以升级吗
直接更新可以升级吗
care 2011年04月10日
能从10.1。1直接升级吗?
能从10.1。1直接升级吗?
qiusongtang 2011年04月10日
非常感谢您的分享!好人好好梦!
非常感谢您的分享!好人好好梦!
exiaoliuzi 2011年04月10日
好东西,顶起来
好东西,顶起来
congrenh 2011年04月11日
好东西!
好东西!
是最新的版本吧!
是最新的版本吧!
下来看看。
下来看看。
软件好像很大啊。
软件好像很大啊。
没用过,谢谢。
没用过,谢谢。
分数不够。
分数不够。
还要两个没下载。
还要两个没下载。
到时看看。
到时看看。
谢谢了。
谢谢了。
好东西,很实用。
好东西,很实用。
woyaox 2011年04月12日
这东西太大了
这东西太大了
woyaox 2011年04月12日
这东西太大了
这东西太大了
woyaox 2011年04月12日
这东西太好了
这东西太好了
woyaox 2011年04月12日
这东西太好了
这东西太好了
woyaox 2011年04月12日
这东西太好了
这东西太好了
woyaox 2011年04月12日
这东西太好了
这东西太好了
woyaox 2011年04月12日
这东西太好了
这东西太好了
s2005131450 2011年04月12日
好东西!!
好东西!!
bradley 2011年04月13日
谢谢。之前好像下载过,忘了放哪里了,只能重新下一次
jenkin2000 2011年04月13日
haha
haha
好东东,谢谢楼主
好东东,谢谢楼主
alewe 2011年04月15日
支持,感谢。。。
支持,感谢。。。
cvntao 2011年04月16日
终于找到了,呵呵,谢谢楼主了
终于找到了,呵呵,谢谢楼主了
endemb 2011年04月17日
謝謝您的分享,剛好可以試用看看
謝謝您的分享,剛好可以試用看看
wwgs_kies 2011年04月18日
楼主我下的没银子了。。。
楼主我下的没银子了。。。
yueyuan2003 2011年04月18日
好好阿红
好好阿红
曳尾鱼 2011年04月19日
安装完出现“"a problem has been encountered with the license server"”,为什么啊?
zntl 2011年04月19日
非常的需需要,谢谢
非常的需需要,谢谢
zntl 2011年04月19日
非常的需需要,谢谢
没有积分了,我挣
非常的需需要,谢谢
没有积分了,我挣
zntl 2011年04月19日
非常的需需要,谢谢
没有积分了,我挣
非常的需需要,谢谢
没有积分了,我挣
zntl 2011年04月19日
非常的需需要,谢谢
没有积分了,我挣
非常的需需要,谢谢
没有积分了,我挣
Wf_npu 2011年04月20日
做板子很有用
做板子很有用
Wf_npu 2011年04月20日
好软件顶一个
好软件顶一个
Wf_npu 2011年04月20日
下载第二部分,很感谢
下载第二部分,很感谢
Wf_npu 2011年04月20日
第三部分,谢谢分享
第三部分,谢谢分享
Wf_npu 2011年04月20日
第四部分,谢谢
第四部分,谢谢
无怨无悔yyl 2011年04月20日
谢谢分享!!!
谢谢分享!!!
Wf_npu 2011年04月20日
第五部分,谢谢
第五部分,谢谢
Wf_npu 2011年04月20日
第六部分,谢谢
第六部分,谢谢
Wf_npu 2011年04月20日
第七部分,谢谢
第七部分,谢谢
Wf_npu 2011年04月20日
第八部分,谢谢
第八部分,谢谢
无怨无悔yyl 2011年04月21日
谢谢分享!!!
谢谢分享!!!
无怨无悔yyl 2011年04月21日
谢谢分享!!!
谢谢分享!!!
tjukb 2011年04月24日
狂顶,大哥,恩人啊。
狂顶,大哥,恩人啊。
winston 2011年04月25日
非常感谢
非常感谢
winston 2011年04月25日
非常感谢
非常感谢
winston 2011年04月25日
非常感谢
非常感谢
winston 2011年04月25日
非常感谢
非常感谢
winston 2011年04月25日
非常感谢
非常感谢
winston 2011年04月25日
非常感谢
非常感谢
winston 2011年04月25日
非常感谢
非常感谢
winston 2011年04月25日
非常感谢
非常感谢
winston 2011年04月25日
非常感谢
非常感谢
yuan286 2011年04月25日
怎么没有破解文件啊?
怎么没有破解文件啊?
yuan286 2011年04月25日
怎么没有破解文件啊?
怎么没有破解文件啊?
wpjack 2011年04月25日
非常及时,谢谢了
非常及时,谢谢了
wpjack 2011年04月25日
VERY GOOD,非常好,
VERY GOOD,非常好,
azyp1983 2011年04月25日
又有新版本了,用过的朋友分享一下使用经验吧!
yamaxiao 2011年05月03日
太强了,十分感谢啊
太强了,十分感谢啊
rederzhang 2011年05月05日
回复1楼fenghaili:
谢谢楼主。
回复1楼fenghaili:
谢谢楼主。
gdrdlq 2011年05月05日
希望是可以用
希望是可以用
hhhcc 2011年05月05日
好东西要顶
好东西要顶
leoliu2009 2011年05月07日
好东西,顶一个!
好东西,顶一个!
ligangqiang08 2011年05月12日
谢谢分享 好东西哦
谢谢分享 好东西哦
谢谢分享 好东西哦
谢谢分享 好东西哦
谢谢分享 好东西哦
谢谢分享 好东西哦
谢谢分享 好东西哦
谢谢分享 好东西哦
谢谢分享 好东西哦
谢谢分享 好东西哦
这里的好东西真多,呵呵,谢谢
这里的好东西真多,呵呵,谢谢
bitrenliqi 2011年05月14日
支持,极端需要啊
支持,极端需要啊
szn2xylx 2011年05月15日
谢谢分享 有人成功导入到PROTEL里面去了么?
yueyuan2003 2011年05月22日
好哈哈哦啊
好哈哈哦啊
不知这次update更新了什么
不知这次update更新了什么
确实是个号玩意
确实是个号玩意
没分赚分
没分赚分
没分赚分
没分赚分
没分赚分
没分赚分
没分赚分
没分赚分
没分赚分
没分赚分
没分赚分
没分赚分
jia_beiping 2011年05月24日
厉害啊!!学习!!
厉害啊!!学习!!
dyjanna 2011年05月30日
不知道怎么用,而且感觉麻烦,习惯了用游标卡尺来量
yanxuex 2011年06月01日
RE: 2月16日全新升级LP wizard_V10.3_update1,自动生成器件封装,破解和以前一样 [修改]
huiyanhuishi 2011年06月02日
:D楼主威武啊!!!
:D楼主威武啊!!!
yueyuan2003 2011年06月03日
请问lz,如何把时间更改为2010 7 1,multipart怎么个用法
star530 2011年06月04日
非常的需需要,谢谢
非常的需需要,谢谢
star530 2011年06月04日
顶,狂顶!
顶,狂顶!
iamfzm 2011年06月07日
学习一下
学习一下
zhkuang 2011年06月08日
没分赚分
没分赚分
longfan 2011年06月11日
好东西 还差几分
好东西 还差几分
huaq019 2011年06月18日
膜拜
膜拜
ccduyujian 2011年06月24日
感谢楼主
感谢楼主
陈豪俊 2011年07月05日
谢谢楼主无私分享
谢谢楼主无私分享
阿明wh 2011年07月05日
感谢分享!!!
感谢分享!!!
zhuzheng2006 2011年07月05日
谢谢分享
谢谢分享
biglin 2011年07月06日
一次共扣了24個積分.好貴..不過還是感謝.
lsh222 2011年07月06日
看看!!!!!!!!!!!!!!
看看!!!!!!!!!!!!!!
text108 2011年07月06日
好东东,谢谢楼主
好东东,谢谢楼主
ryan80 2011年07月06日
Thanks!!!!!
Thanks!!!!!
nigx 2011年07月06日
好,
好,
hswqs 2011年07月06日
太感谢了!!
太感谢了!!
yulizi 2011年07月06日
谢谢楼主分享资源
谢谢楼主分享资源
yulizi 2011年07月06日
谢谢楼主分享资源
谢谢楼主分享资源
yulizi 2011年07月06日
下载完还真难
下载完还真难
cotterie 2011年07月06日
谢谢了!!!!!!
谢谢了!!!!!!
阿明wh 2011年07月06日
终于不用改时间了!!!
终于不用改时间了!!!
philhou 2011年07月07日
好东西,一定要顶的!
好东西,一定要顶的!
bravejt 2011年07月07日
这个是好,支持楼主!!
这个是好,支持楼主!!
Phonse 2011年07月07日
先顶一下,后面再来下载更新。。
先顶一下,后面再来下载更新。。
wyl 2011年07月07日
谢谢!支持!好东西要顶
谢谢!支持!好东西要顶
disth 2011年07月07日
做个网盘下载吧,这样太麻烦了,,
做个网盘下载吧,这样太麻烦了,,
goldensea 2011年07月07日
顶,狂顶!
顶,狂顶!
忒感谢了啊!
忒感谢了啊!
xuser 2011年07月07日
试一试,谢谢分享。
试一试,谢谢分享。
Phonse 2011年07月07日
下了前面的4个。。还有四个呢
下了前面的4个。。还有四个呢
Phonse 2011年07月07日
还有三个呢。。加油
还有三个呢。。加油
Phonse 2011年07月07日
还有两个呢,哈哈
还有两个呢,哈哈
Phonse 2011年07月07日
最后一个啦。。。
最后一个啦。。。
eecwy 2011年07月07日
thanks
thanks
fenghaili 2011年07月07日
做个网盘下载吧,这样太麻烦了,,
disth 发表于 2011-7-7 10:45 http://www.eechina.com/images/common/back.gif呵呵,这个值得你麻烦
做个网盘下载吧,这样太麻烦了,,
yzhu 2011年07月07日
谢谢楼主共享,确实是个好软件!
谢谢楼主共享,确实是个好软件!
simhfc 2011年07月07日
最新版~
Thanks.
最新版~
Thanks.
simhfc 2011年07月07日
非常的需需要,谢谢。
非常的需需要,谢谢。
simhfc 2011年07月07日
非常的需需要,谢谢。
非常的需需要,谢谢。
jacklee7488 2011年07月08日
須要學習學習,Thanks.
須要學習學習,Thanks.
yth0 2011年07月08日
听说这个输出Expedition PCB格式的日期文件解决了?下来看看,谢谢斑竹。
yth0 2011年07月09日
奇怪的是这个的PJ用那个Mentor_KeyGen V11.4不行,还得用原来的手工替换MGLS.DLL的那种。
yth0 2011年07月09日
又试了一下,用KeyGen V11.4需要加上-patch 参数才行啊。还把我在这个目录下备份的MGLS.DLL.bck也给patch了,真晕,现在都找不到安装程序原始的MGLS.DLL了,呵呵。
奇怪为啥ee2007.9.2能自动寻找MGLS.DLL并patch,LP Wizard 10.3.1却需要自己指定目录?
fenghaili 2011年07月10日
奇怪为啥ee2007.9.2能自动寻找MGLS.DLL并 ...
yth0 发表于 2011-7-9 10:32 http://www.eechina.com/images/common/back.gif
其实 -patch 参数用不用都行。但是不知道是哪里的问题,反正感觉这个kegen不太好用。但是一旦能用了,就很完美的。
打比方,没有用-patch参数,可能不能用,留下这个不能用的license。
然后用-patch 参数,可能能用了。
然后删除能用的license,更换为那个不能用的license
哈哈,居然也能用了。。
这个情况很怪异的。
然后用-patch 参数,可能能用了。
哈哈,居然也能用了。。
这个情况很怪异的。
yth0 2011年07月11日
然后用-patch 参数, ...
fenghaili 发表于 2011-7-10 10:53 http://www.eechina.com/images/common/back.gif
其实不是生成的license的问题,现在Ment0r的东西都需要修改MGLS.DLL才能用的。以前有的PJ是自己手工替换MGLS.DLL,现在这个V11.4是自动寻找并修改MGLS.DLL。你第一次不加-patch,MGLS.DLL和MGLS64.DLL没有被修改过,所以不能用,第二次加上-patch,MGLS.DLL和MGLS64.DLL被修改过,所以无论用第一次还是第二次的license都没问题,加不加-patch对生成的license没有什么影响。-patch参数,他的意思是修改指定位置的MGLS.DLL和MGLS64.DLL,你可以比较一下加-patch后MGLS.DLL和MGLS64.DLL是不是被修改过了。
我奇怪的是为啥ee2oo7.9.2能自动寻找MGLS.DLL并patch,LP 10.3.1却需要自己指定目录?
然后用-patch 参数, ...
yth0 2011年07月11日
Mentor Graphics MGCLD License KeyGen V11.4
?2011 by Team EFA (Eda For All).
usage: MentorKG [-options]
licensefile(s) is(are) the file(s) to recrypt
options:
-i infile , defines the INPUT file.
-o outfile , defines the OUTPUT file.
-e errfile , defines the ERROR file otherwise goes to stdout.
-h HostID , default is one of your Network Cards
X-YYYYYYYY gives HOSTID=FLEXID=X-YYYYYYYY
XXXXXXXXXXXX gives HOSTID=XXXXXXXXXXXX
-hn , uses the NETWORK CARD as HostID
-hd , uses the DISK_SERIAL_NUM as HostID
-h7 , uses the FlexID=7-xxxxxxxx as HostID
-h6 , uses the FlexID=6-xxxxxxxx as HostID
-n , forces the license to be Nodelocked (Default).
-f , forces the license to be FLOATING.
-f , uses (a)tomic,(e)xtended and (c)omposite features
in any combination: -fa, -fac, -fec, -faec, etc.
The (s)trip option cleans all unnecessary features.
Using only -f will render license to FLOATING.
Default is -fs.
-u , number of users in case of floating Defaults to 99.
-sn , serial number to be used in license
-all , uses ALL known features
-chk , Disables feature checkout
-perm , makes a PERMANENT license
-exp mm/yyyy, license expiration date, default is 4 years (30 max)
-notice str , Changes NOTICE= to str, if null clears or "st ri ng"
-issuer str , Changes ISSUER= to str, same as notice
-ck , Enables checksum of license
-none , Disables NOTICE,ISSUER and ck
-maxlen n , limits line length for continuation, -1 for unlimited.
-patch , checks all the required files in .
if not given will try the default Mentor installation.
-dll folder , which folder\mgls.dll to use.
-pkg folder , which folder\mgc.pkginfo to use.
If no arguments, generates LICENSE.TXT on temporary folder
and opens it in Notepad so you can edit or save it to a known place.
Examples:
MentorKG -o TEST.DAT ; Makes a default TEST.DAT
MentorKG License.dat -maxlen -1 ; Recrypts License.dat no warp lines
options:
Default is -fs.
Examples:
nuaalu 2011年07月12日
好资料,谢谢
好资料,谢谢
sxzscn 2011年07月13日
好,支持
好,支持
sccdxy 2011年07月13日
好东西,顶 !
好东西,顶 !
sccdxy 2011年07月13日
谢谢!
谢谢!
sccdxy 2011年07月13日
支持
支持
sccdxy 2011年07月13日
正需要!
正需要!
zhuvery 2011年07月14日
牛啊!!
牛啊!!
jacklee7488 2011年07月14日
感謝分享!!!
感謝分享!!!
lisly 2011年07月15日
这个东西很强大。感谢
这个东西很强大。感谢
Shyoung 2011年07月15日
又更新啦!
又更新啦!
hfwyk 2011年07月17日
学习学习
学习学习
yueyuan2003 2011年07月17日
楼主好人啊,我一直在跟你的这个帖子走
楼主好人啊,我一直在跟你的这个帖子走
楼主,请问这个还用以前的破解还行吗
楼主,请问这个还用以前的破解还行吗
哇,楼主啊,我的钱啊,花花的扣啊
哇,楼主啊,我的钱啊,花花的扣啊
顶,再回复,我要赚回来
顶,再回复,我要赚回来
在此顶起
在此顶起
id1563662788 2011年07月19日
好东西啊,是不是真的啊。。。
好东西啊,是不是真的啊。。。
竟然少下了一个,晕。。。
竟然少下了一个,晕。。。
cp0610231102 2011年07月20日
谢谢
谢谢
谢谢
谢谢
谢谢
谢谢
IFIREFLY 2011年07月23日
楼主真强
楼主真强
lix212121 2011年07月23日
支持下
支持下
chenyaw 2011年07月26日
非常感谢,找了好大一圈!!!!!!!!!!!!!!!!
chenyaw 2011年07月26日
Good。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。
rabbitpan0317 2011年07月27日
实在很强大,感谢楼主
实在很强大,感谢楼主
royhunter 2011年08月05日
多谢楼主分享啊,这两天正在做封装,累坏了,分享快乐!
abswin 2011年08月07日
楼主你不是一般的强,就是分卷太多,下得手软啊!
809384540 2011年08月08日
要破解不?
要破解不?
tony345 2011年08月17日
很好,谢谢了!
很好,谢谢了!
tony345 2011年08月17日
很好,谢谢了!
很好,谢谢了!
无怨无悔yyl 2011年08月20日
谢谢了,这个耗费积分啊 。。。。
谢谢了,这个耗费积分啊 。。。。
chaochao_AVR 2011年08月23日
谢谢 您的无私分享
谢谢 您的无私分享
langyy1998 2011年08月24日
兄弟多谢了,这个可是好东西
兄弟多谢了,这个可是好东西
我使用IE自带的下载器下载的,希望能下完,不然我的积分就白花了
seraph1001 2011年08月24日
好东西帮你顶一下,谢谢分享
好东西帮你顶一下,谢谢分享
sjs1 2011年08月26日
thanks
thanks
sjs1 2011年08月26日
Hey !! Thanks
Hey !! Thanks
sjs1 2011年08月26日
http://www.eechina.com/thread-18118-1-1.html
sjs1 2011年08月26日
Thanks
Thanks
sjs1 2011年08月26日
Thanks
Thanks
sjs1 2011年08月26日
thanks
thanks
sjs1 2011年08月26日
支持
支持
sjs1 2011年08月26日
顶,狂顶!
顶,狂顶!
hejc06 2011年08月29日
多谢Lz了,正在找这个呢
多谢Lz了,正在找这个呢
zzz2603 2011年08月29日
ding
ding
zzz2603 2011年08月29日
谢谢分享
谢谢分享
zzz2603 2011年08月29日
thinks
thinks
ssjemail 2011年09月06日
非常感谢楼主无私奉献的精神!!!!!!!!!!!!!!!1
xxqmcu 2011年09月13日
终于找到这个工具了,谢谢了!
终于找到这个工具了,谢谢了!
charles.l 2011年09月15日
积分下的很快啊……谢谢分享!省了到处找了。
log8384 2011年09月17日
这东东能与mentor lmc整合吗?!
sadou 2011年09月17日
多谢冯总:)
多谢冯总:)
bgasky 2011年09月17日
呵呵,最新版本,谢谢分享!
呵呵,最新版本,谢谢分享!
star530 2011年09月19日
非常的需需要,谢谢
非常的需需要,谢谢
star530 2011年09月19日
下来试试,以前的都 不理想
下来试试,以前的都 不理想
baifanshuishou 2011年09月20日
多谢,看下。
多谢,看下。
看下。多谢。
看下。多谢。
看下。多谢。
看下。多谢。
非常感谢楼主无私奉献的精神
非常感谢楼主无私奉献的精神
非常感谢楼主无私奉献的精神
非常感谢楼主无私奉献的精神
非常感谢楼主无私奉献的精神
非常感谢楼主无私奉献的精神
非常感谢楼主无私奉献的精神
非常感谢楼主无私奉献的精神
非常感谢楼主无私奉献的精神
非常感谢楼主无私奉献的精神
shilingwork 2011年09月21日
好东西要顶
好东西要顶
york_feng 2011年09月24日
好东西,楼主辛苦了
好东西,楼主辛苦了
夜莺 2011年09月27日
顶,积分不够呀
顶,积分不够呀
夜莺 2011年09月27日
夜莺 2011年09月27日
谢谢楼主
谢谢楼主
zxg1113 2011年09月27日
哇,这个是最新版的吧,楼主真强
哇,这个是最新版的吧,楼主真强
gshaoguang 2011年09月30日
顶
顶
岑村020 2011年10月04日
怎么破解?怎么破解?怎么破解?
怎么破解?怎么破解?怎么破解?
zjdsll 2011年10月06日
楼主破解发的是PADS9.3的吗?两个一样吗
fenghaili 2011年10月07日
zjdsll 发表于 2011-10-6 21:47 http://www.eechina.com/images/common/back.gif
一样
一样
怎么破解?怎么破解?怎么破解?
岑村020 发表于 2011-10-4 11:18 http://www.eechina.com/images/common/back.gif
参看PADS 9.3 破解
怎么破解?怎么破解?怎么破解?
参看PADS 9.3 破解
xingshuang 2011年10月09日
xiex xie
xiex xie
xieixe
xieixe
000xxxx
000xxxx
222xxxxx
222xxxxx
000222zzz
000222zzz
txqtomton 2011年10月13日
Hey !!!! Thanks
Hey !!!! Thanks
wlj2yxn 2011年10月13日
感谢LZ
感谢LZ
llllll3002 2011年10月14日
回复1楼fenghaili:
要积分?
回复1楼fenghaili:
要积分?
回复1楼fenghaili:
谢谢楼主!
回复1楼fenghaili:
谢谢楼主!
回复1楼fenghaili:
非常感谢楼主!为了下载,得多回复几个!
回复1楼fenghaili:
非常感谢楼主!为了下载,得多回复几个!
回复1楼fenghaili:
非常感谢楼主!为了下载,得多回复几个!
回复1楼fenghaili:
非常感谢楼主!为了下载,得多回复几个!
回复2楼dongfanghong:
非常感谢楼主!为了下载,得多回复几个!
回复2楼dongfanghong:
非常感谢楼主!为了下载,得多回复几个!
回复1楼fenghaili:
非常感谢楼主!为了下载,得多回复几个!
回复1楼fenghaili:
非常感谢楼主!为了下载,得多回复几个!
回复1楼fenghaili:
非常感谢楼主!为了下载,得多回复几个!
回复1楼fenghaili:
非常感谢楼主!为了下载,得多回复几个!
回复2楼dongfanghong:
非常感谢楼主!为了下载,得多回复几个!
回复2楼dongfanghong:
非常感谢楼主!为了下载,得多回复几个!
回复1楼fenghaili:
下载了,谢谢!
回复1楼fenghaili:
下载了,谢谢!
oscill 2011年10月18日
楼主太强,顶!
楼主太强,顶!
jsh163 2011年10月20日
高科技啊,下了试试先。。。
高科技啊,下了试试先。。。
spdrdrsp 2011年10月21日
学习一下
学习一下
kbhf518 2011年11月03日
kbhf518 2011年11月03日
我安装了怎么还是出现了license not found,LP wizard will run in‘calculator’mode,请问怎么回事啊?
eleczj 2011年11月07日
:lol。。。。。。。。。。。。。很不错的软件
eleczj 2011年11月07日
好烧积分啊:L
好烧积分啊:L
zb2000zbzb 2011年11月08日
很好很好!
很好很好!
yungold 2011年11月08日
ding
ding
kunpeng666 2011年11月11日
支持!
支持!
dzkcool 2011年11月11日
哇,这个是最新版的吧,楼主真强。
哇,这个是最新版的吧,楼主真强。
duanguohe 2011年11月12日
谢谢分享,太不容易了
谢谢分享,太不容易了
cxyjoe 2011年11月13日
好东西要顶
好东西要顶
eleven 2011年11月13日
该版本增加了对部分插装器件的支持。但是破解并不完美,现在已经不推荐使用。。
7.02版本很完美!推荐
或者10.3.1 强烈推荐。http://www.eechina.com/thread-18118-1-1.html
使用方法,可参考V7.02版本我前一个帖子的说明。
7.02版本很完美!推荐
OrcadUser 2011年11月14日
Thank you for your sharing and take time to upload. Appreciated what you did ... :victory:
cotterie 2011年11月14日
谢谢了,又有最新的了。
谢谢了,又有最新的了。
bayi255 2011年11月15日
thanks!
thanks!
surken 2011年11月15日
最新版
最新版
kmjlz 2011年11月15日
good!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
kmjlz 2011年11月15日
kmjlz 2011年11月15日
kmjlz 2011年11月15日
kmjlz 2011年11月15日
kmjlz 2011年11月15日
kmjlz 2011年11月15日
kmjlz 2011年11月15日
kmjlz 2011年11月15日
ajin303 2011年11月16日
正需要,谢谢
正需要,谢谢
yxj4366 2011年11月17日
有完整包吗?
有完整包吗?
hokage2009 2011年11月18日
顶一个
顶一个
hhhcc 2011年11月19日
好,支持
好,支持
hhhcc 2011年11月19日
好,支持
好,支持
hhhcc 2011年11月19日
好,支持
好,支持
hhhcc 2011年11月19日
好,支持
好,支持
hhhcc 2011年11月19日
好,支持
好,支持
hhhcc 2011年11月19日
好,支持
好,支持
hhhcc 2011年11月19日
好,支持
好,支持
hhhcc 2011年11月19日
好,支持
好,支持
hhhcc 2011年11月19日
好,支持
好,支持
chenyaw 2011年11月21日
Thanks ,正急需!!非常感谢!!
Thanks ,正急需!!非常感谢!!
chenyaw 2011年11月21日
Thanks ,正急需!!非常感谢!!
Thanks ,正急需!!非常感谢!!
Phonse 2011年11月21日
谢谢。。下来看看哈。。
好像钱不够的。。
谢谢。。下来看看哈。。
好像钱不够的。。
Phonse 2011年11月21日
银子太少了。。如果能存到某个网盘就好了啊。。或者传到论坛的FTP上,哈哈
hzqydq 2011年11月22日
谢谢楼主,这个软件太好了。
谢谢楼主,这个软件太好了。
hzqydq 2011年11月22日
谢谢楼主,强悍
谢谢楼主,强悍
hzqydq 2011年11月22日
我来啦!!!!!
我来啦!!!!!
hzqydq 2011年11月22日
收藏!
收藏!
hzqydq 2011年11月22日
支持楼主·
支持楼主·
hzqydq 2011年11月22日
继续挣钱,来收藏此资料
继续挣钱,来收藏此资料
sue_shi501 2011年11月23日
真好!!谢谢!
真好!!谢谢!
支持!
支持!
zhichi
zhichi
good
good
thank
thank
djs3933 2011年11月23日
谢谢分享,这个很有意义~~
谢谢分享,这个很有意义~~
Phonse 2011年11月23日
多回复几次。。把钱赚到手再下载哈
多回复几次。。把钱赚到手再下载哈
bossyjin 2011年11月23日
好贴啊,多谢楼主
好贴啊,多谢楼主
一直在寻找,多谢啊
一直在寻找,多谢啊
GOOD
GOOD
yueyuan2003 2011年11月23日
此贴为楼主发家致富之贴啊
此贴为楼主发家致富之贴啊
fenghaili 2011年11月24日
此贴为楼主发家致富之贴啊
yueyuan2003 发表于 2011-11-23 20:53 http://www.eechina.com/images/common/back.gif
高,被您发现了
此贴为楼主发家致富之贴啊
高,被您发现了
yth0 2011年11月24日
谢谢版主!
谢谢版主!
chinajiagege 2011年11月24日
:victory:
:victory:
好东西就要支持下哈。谢谢:victory:
这个真能破?
这个真能破?
llmao 2011年11月25日
谁发明的破解方法,都是牛人啊
谁发明的破解方法,都是牛人啊
p89c51 2011年11月25日
好东西啊
好东西啊
jack_ben 2011年11月27日
牛呀,呵呵 ,谢谢
牛呀,呵呵 ,谢谢
楼主牛呀,呵呵 ,谢谢
楼主牛呀,呵呵 ,谢谢
sersd 2011年11月28日
非常的需需要,谢谢
非常的需需要,谢谢
sersd 2011年11月28日
是否支持altium design
是否支持altium design
wzzw 2011年11月28日
再次感谢版主!!!
再次感谢版主!!!
soliton 2011年11月29日
不行啊~显示 no license was found for feature lpeexpedition
坐椅待币 2011年12月01日
谢谢!!!!!!!
谢谢!!!!!!!
mush 2011年12月01日
开眼界开眼界啊
开眼界开眼界啊
Phonse 2011年12月01日
认真回复一下。。好下载
认真回复一下。。好下载
Phonse 2011年12月01日
再次回复。。下完需要的钱太多太多了呀。。
Phonse 2011年12月01日
下第一个。。谢谢
下第一个。。谢谢
Phonse 2011年12月01日
第三个了。。哈哈
第三个了。。哈哈
Phonse 2011年12月01日
好了。。第十个了。。差不多了。。嘿嘿
好了。。第十个了。。差不多了。。嘿嘿
godwind 2011年12月04日
太好了啊
太好了啊
godwind 2011年12月04日
太牛了逼了
太牛了逼了
godwind 2011年12月04日
喜欢啊
喜欢啊
godwind 2011年12月04日
分高啊
分高啊
godwind 2011年12月04日
太好了了
太好了了
godwind 2011年12月04日
很好
很好
godwind 2011年12月04日
喜欢
喜欢
godwind 2011年12月04日
想要
想要
godwind 2011年12月04日
太好了啊
太好了啊
godwind 2011年12月04日
喜欢啊 啊啊
喜欢啊 啊啊
阿明wh 2011年12月06日
斑竹总有这些好东东,无条件支持!!!!
斑竹总有这些好东东,无条件支持!!!!
小木子 2011年12月06日
感谢分享!!!
感谢分享!!!
阿明wh 2011年12月11日
支持的版本确实少了不少。
支持的版本确实少了不少。
lgood 2011年12月12日
不错,就是积分不足啊
不错,就是积分不足啊
lgood 2011年12月12日
不错,就是积分不足啊
不错,就是积分不足啊
lgood 2011年12月12日
比pads 9.3里自带的新啊
比pads 9.3里自带的新啊
liuchaotx 2011年12月13日
f非常感谢楼主!
f非常感谢楼主!
lmyyjx 2011年12月13日
痛苦
没有积分
痛苦
没有积分
lmyyjx 2011年12月13日
有用完了
能免费
有用完了
能免费
lmyyjx 2011年12月13日
幸运
回复
就有积分
幸运
回复
就有积分
lmyyjx 2011年12月13日
要继续努力
要继续努力
lmyyjx 2011年12月13日
回复是弄点积分好下载
回复是弄点积分好下载
lmyyjx 2011年12月13日
回复是弄点积分好下载
回复是弄点积分好下载
huiyanhuishi 2011年12月14日
感谢楼主分享!!!
感谢楼主分享!!!
kevinjz2010 2011年12月17日
64bit能用吗~
64bit能用吗~
myhz 2011年12月17日
hoo
hoo
myhz 2011年12月17日
hhhh
hhhh
myhz 2011年12月17日
jjjjjjjj
jjjjjjjj
myhz 2011年12月17日
fffffffffffffff
fffffffffffffff
myhz 2011年12月17日
llllllllllllllllll
llllllllllllllllll
myhz 2011年12月17日
aaaaaaaaaaaaa
aaaaaaaaaaaaa
myhz 2011年12月17日
bbbbbbbbbbbbbbbbbbbbbbbbb
myhz 2011年12月17日
ccccccccccccccccccc
ccccccccccccccccccc
myhz 2011年12月17日
myhz 2011年12月17日
eeeeeeeeeeeeeeeee
eeeeeeeeeeeeeeeee
myhz 2011年12月17日
myhz 2011年12月17日
qqqqqqqqqqqq
qqqqqqqqqqqq
myhz 2011年12月17日
ggggggggggggggggggg
ggggggggggggggggggg
myhz 2011年12月17日
hhhhhhhhhhhhh
hhhhhhhhhhhhh
myhz 2011年12月17日
iiiiiiiiiiiiiiiiiiiiiiiii
ic2003 2011年12月18日
谢谢,下来看看
谢谢,下来看看
ic2003 2011年12月18日
谢谢,下来看看
谢谢,下来看看
ic2003 2011年12月18日
谢谢,下来看看
谢谢,下来看看
bjgaofei 2011年12月19日
楼主真好
楼主真好
Hey !! Thanks
Hey !! Thanks
是最新版的吧
是最新版的吧
最新版
最新版
好东西要顶
好东西要顶
bittergrass 2011年12月20日
support
support
:loveliness:
:loveliness:
JohnThomas_LH 2011年12月22日
非常非常感谢!话说我用 LP Wizard 10.3.1 生成封装导出到 Allegro 16.5 有BUG,不能生成非标准焊盘,而且丝印的位置也不对。
anflower 2011年12月22日
谢谢,分享!
谢谢,分享!
谢谢,分享!
谢谢,分享!
谢谢,分享!
谢谢,分享!
谢谢,分享!
谢谢,分享!
谢谢,分享!
谢谢,分享!
谢谢,分享!
谢谢,分享!
谢谢,分享!
谢谢,分享!
Haier201112
Haier201112
谢谢,分享!
谢谢,分享!
谢谢,分享!
谢谢,分享!
SoarphysYan 2011年12月22日
xie谢谢!:victory:
xie谢谢!:victory:
fclever 2011年12月22日
感谢楼主分享
感谢楼主分享
fclever 2011年12月22日
感谢楼主分享
感谢楼主分享
ieheker 2011年12月31日
多谢楼主啊,又可以升级了
多谢楼主啊,又可以升级了
陈豪俊 2012年01月03日
谢谢分享,没想到更新如此快,还在用V7
谢谢分享,没想到更新如此快,还在用V7
ttlasong 2012年01月04日
LP Wizard Release Highlights
Software Version LP10.3.2
simam 2012年01月04日
Hey !! Thanks
Hey !! Thanks
lwseed 2012年01月06日
感谢LZ无私分享啊
感谢LZ无私分享啊
jjjson 2012年01月07日
很好,谢谢
很好,谢谢
shilingwork 2012年01月10日
谢谢分享,
谢谢分享,
five5s 2012年01月12日
谢谢老大的分享
谢谢老大的分享
five5s 2012年01月12日
找了好久 终于找到了
找了好久 终于找到了
rei1984 2012年01月16日
h5hre3g3reg
h5hre3g3reg
rei1984 2012年01月16日
rhwhethtw
rhwhethtw
beldking 2012年01月18日
开始弄错了一个字母,变成了LICENSE,环境变量和C盘根目录下名字对不起来了。改好后用起来了。谢谢
wa00mm5200 2012年01月27日
谢谢楼主 谢谢
谢谢楼主 谢谢
redlake 2012年01月28日
thank you very much.
jonestven 2012年01月30日
正好需要!谢谢楼主!!!
正好需要!谢谢楼主!!!
cotterie 2012年01月30日
多谢了。
多谢了。
thw01 2012年01月31日
没积分了,希望能下载,谢谢!
没积分了,希望能下载,谢谢!
thw01 2012年01月31日
没积分了,希望能下载,谢谢!
没积分了,希望能下载,谢谢!
thw01 2012年01月31日
一次下载3分,可真不少啊!
一次下载3分,可真不少啊!
anming 2012年01月31日
一直没找到好用的版本,希望这个好用
一直没找到好用的版本,希望这个好用
sdew 2012年02月02日
需要好多钱阿,哭死了
需要好多钱阿,哭死了
lovemini 2012年02月02日
支持10.3.2up1
支持10.3.2up1
gwj221 2012年02月03日
谢谢LZ
谢谢LZ
leonqin 2012年02月03日
回复1楼fenghaili:
这么好的软件还没用过,惭愧
回复1楼fenghaili:
这么好的软件还没用过,惭愧
gygang 2012年02月03日
没钱了啊
没钱了啊
gygang 2012年02月03日
挣钱挣钱
挣钱挣钱
tf928 2012年02月03日
好,支持
好,支持
阿明wh 2012年02月03日
感谢分享!!1
感谢分享!!1
zwg73 2012年02月03日
感谢楼主的无私分享。
就是分的压缩包太多了,有4--5个就足够了。
感谢楼主的无私分享。
lsh222 2012年02月04日
下来看看!!!!!!!!!!!!!
下来看看!!!!!!!!!!!!!
lsh222 2012年02月04日
下来看看!!!!!!!!!!!!!
下来看看!!!!!!!!!!!!!
OrcadUser 2012年02月04日
Thanks for your sharing !!!!!!!!!:lol
lam007 2012年02月07日
这么大啊,感谢!
这么大啊,感谢!
zkme 2012年02月08日
希望可以使用,谢谢了。
希望可以使用,谢谢了。
gaozhen 2012年02月09日
好,学习一下!!!
好,学习一下!!!
苏醒 2012年02月09日
thanks,楼主好人
thanks,楼主好人
telantan 2012年02月10日
需要这个东西,多谢。
需要这个东西,多谢。
anflex 2012年02月10日
刚开始学,谢谢楼主
刚开始学,谢谢楼主
06010601 2012年02月11日
这个是最新版的吧,楼主真强
这个是最新版的吧,楼主真强
kinlin 2012年02月12日
版主资料是蛮好的,可惜下载很耗费金币
版主资料是蛮好的,可惜下载很耗费金币
kinlin 2012年02月12日
多多啰嗦一下,因为资料太好啦,过灌水几次望楼主给予理解
kinlin 2012年02月12日
freemanz 2012年02月14日
是不错的,能否正常使用?谢谢
是不错的,能否正常使用?谢谢
是不错的,能否正常使用?谢谢
是不错的,能否正常使用?谢谢
allengoo 2012年02月15日
真是好东西,正需要
真是好东西,正需要
Phonse 2012年02月15日
谢谢。。看看有什么更新哈。。
谢谢。。看看有什么更新哈。。
Phonse 2012年02月15日
需要太多分了,回复赚下。。
需要太多分了,回复赚下。。
Phonse 2012年02月15日
第三个啦。。谢谢
第三个啦。。谢谢
Phonse 2012年02月15日
第四个,哈哈。。
第四个,哈哈。。
Phonse 2012年02月15日
第七个啦。。
第七个啦。。
rabbitpan0317 2012年02月15日
谢谢楼主分享!
谢谢楼主分享!
hjf2002 2012年02月15日
Thanks for share!
Thanks for share!
icdiscovery 2012年02月17日
几分不足,刷频挣积分 回复1楼fenghaili:
这个是我最需要的东西 回复1楼fenghaili:
目前用的版本是10.1 回复1楼fenghaili:
东西是好东西,不过分的块太多了,要恢复好多次才够积分 回复1楼fenghaili:
谢谢楼主的慷慨 回复1楼fenghaili:
楼主少分几个块不行吗? 回复1楼fenghaili:
顶楼主,下次少分几块啊! 回复1楼fenghaili:
才下到第七个块,哎! 回复1楼fenghaili:
坚持就是胜利 回复1楼fenghaili:
知识就是力量 回复1楼fenghaili:
破解就是王道 回复1楼fenghaili:
lgl2466 2012年02月17日
好东西
好东西
lgl2466 2012年02月17日
好东西啊
好东西啊
pikaqiu_qiu 2012年02月17日
谢谢楼主,正在学习cadence,用得到这个。
missonly 2012年02月18日
很实用的东西。谢谢。
很实用的东西。谢谢。
yth0 2012年02月20日
谢谢版主!
谢谢版主!
asdlmo 2012年02月20日
刷啊刷啊 刷积分
刷啊刷啊 刷积分
asdlmo 2012年02月20日
刷啊刷啊 刷积分 积分
刷啊刷啊 刷积分 积分
szm2000 2012年02月20日
非常感谢啊
非常感谢啊
szm2000 2012年02月20日
非常感谢啊,楼主真强
非常感谢啊,楼主真强
szm2000 2012年02月20日
好用吗?能用?
好用吗?能用?
xileito 2012年02月21日
这个是最新版的吧,楼主真强
这个是最新版的吧,楼主真强
xileito 2012年02月21日
谢谢 积分不够了
谢谢 积分不够了
liufeng2193 2012年02月21日
没积分了
没积分了
agent24 2012年02月22日
支持
支持
zuoyamvp 2012年02月23日
请问至此allegro16.5吗?
请问至此allegro16.5吗?
leinfly 2012年02月23日
非常感谢
非常感谢
ymz000 2012年02月23日
呵呵呵 我想下载啊
呵呵呵 我想下载啊
plcpro 2012年02月23日
有用呀,但积分没了
有用呀,但积分没了
plcpro 2012年02月23日
不知加了没?
不知加了没?
plcpro 2012年02月23日
这么好的东西一定要顶
这么好的东西一定要顶
plcpro 2012年02月23日
还有多少分呢。好东西
还有多少分呢。好东西
plcpro 2012年02月23日
能制作各种格式的PCB封装
能制作各种格式的PCB封装
plcpro 2012年02月23日
能制作各种格式的PCB封装能制作各种格式的PCB封装
plcpro 2012年02月23日
加油加油
加油加油
plcpro 2012年02月23日
再加油,还差一点点
再加油,还差一点点
plcpro 2012年02月23日
还有一个
还有一个
plcpro 2012年02月23日
真是好东西
真是好东西
hbwh2012 2012年02月24日
非常好的软件,学习了!!!!
非常好的软件,学习了!!!!
非常好的软件,学习了!!!!
非常好的软件,学习了!!!!
非常好的软件,学习了!!!!
非常好的软件,学习了!!!!
非常好的软件,学习了!!!!
非常好的软件,学习了!!!!
liuliul2001 2012年02月24日
一定要顶
一定要顶
eargle 2012年02月24日
这个是最新版的吧,楼主真强
这个是最新版的吧,楼主真强
山之彼端 2012年02月25日
好东西,支持下
好东西,支持下
bb69 2012年02月25日
哇,这个是最新版的吧,楼主真强
哇,这个是最新版的吧,楼主真强
taomo 2012年02月26日
好东西啊,谢谢啊
好东西啊,谢谢啊
qqsky 2012年02月27日
非常的需需要,谢谢
非常的需需要,谢谢
qqsky 2012年02月27日
这个是最新版的吧
这个是最新版的吧
qqsky 2012年02月27日
拷贝MentorKg.exe到C盘根目录
qqsky 2012年02月27日
好 支持!
好 支持!
xhj0358 2012年03月01日
非常感谢,找了一上午了。
非常感谢,找了一上午了。
sccdxy 2012年03月02日
正准备用这个,谢谢楼主!
正准备用这个,谢谢楼主!
cotterie 2012年03月02日
谢谢了!
谢谢了!
cxt668 2012年03月03日
PADS9.4什么时候出?
PADS9.4什么时候出?
ugvfire 2012年03月03日
3Q,
3Q,
kkfy888 2012年03月03日
好,又更新了,收下了
好,又更新了,收下了
cxyjoe 2012年03月03日
好东西要顶
好东西要顶
leinfly 2012年03月04日
又出更新了,感谢分享
又出更新了,感谢分享
simhfc 2012年03月04日
刚下好10.3 sp,呵呵……
刚下好10.3 sp,呵呵……
gygang 2012年03月04日
无钱啊!!!!
无钱啊!!!!
阿明wh 2012年03月04日
更新的真快
更新的真快
qvbetgguh 2012年03月05日
回复1楼fenghaili:
好帖,好资源
回复1楼fenghaili:
好帖,好资源
下载了这个资料,耗费了我27分呀!
下载了这个资料,耗费了我27分呀!
psl_87 2012年03月05日
给力啊,楼主辛苦了!
给力啊,楼主辛苦了!
nobeller 2012年03月07日
的确是好东西
的确是好东西
bjgaofei 2012年03月10日
学习学习
学习学习
学习学习
学习学习
学习学习
学习学习
chinajiagege 2012年03月12日
这个是最新版的吧,楼主真强
这个是最新版的吧,楼主真强
gabmyd 2012年03月13日
好东西 支持~~已经使用了~
好东西 支持~~已经使用了~
xuser 2012年03月13日
不能直接输出altium的库。
不能直接输出altium的库。
Leisure 2012年03月13日
楼主是牛人。。。你们看他的积分
楼主是牛人。。。你们看他的积分
rogerzrj 2012年03月13日
支持,最新版了。。。
支持,最新版了。。。
lgood 2012年03月15日
这软件更新挺频繁啊
这软件更新挺频繁啊
feng0305010303 2012年03月20日
楼主给力 支持
楼主给力 支持
530991163 2012年03月31日
xiexie~~~
xiexie~~~
gunqiang 2012年03月31日
好东西啊 不甚感激,特别是对于初学者来说,能多一些资源就少走一些弯路了
xiaoxiexmc 2012年04月05日
不知道有没有用啊,缺少了好多的软件的支持
jingjisong 2012年04月05日
good, very good
good, very good
8023 2012年04月08日
学习学习
学习学习
jerryaaa 2012年04月08日
好,
好,
liangxiaojun214 2012年04月09日
不知道这个版本有什么好的改进啊!
不知道这个版本有什么好的改进啊!
zhwzjf 2012年04月11日
谢谢楼主,学习学习!
谢谢楼主,学习学习!
xidgli 2012年04月11日
十二万分的感谢,正需要呢!谢谢!
十二万分的感谢,正需要呢!谢谢!
luckhare 2012年04月11日
:victory
先支持一下。。。
:victory:
:victory
先支持一下。。。
:victory:
elm99 2012年04月24日
谢谢lz共享!
谢谢lz共享!
elm99 2012年04月24日
积分太少,那里能挣积分呀!
积分太少,那里能挣积分呀!
ssff 2012年04月25日
非常感谢!
非常感谢!
toplayout 2012年04月26日
速度真快,谢谢!
速度真快,谢谢!
hebei_vip 2012年04月28日
学习正需要。
学习正需要。
OrcadUser 2012年04月28日
Thanks !!!!!!!!!:lol
feiguohai517 2012年05月01日
好东西,支持!
好东西,支持!
ggsmiling 2012年05月07日
好,支持
好,支持
OrcadUser 2012年05月10日
Thanks !!!!!!!!!!:handshake
binggpp 2012年05月11日
thanks
thanks
szsxdkj 2012年05月12日
谢谢楼主
谢谢楼主
gokuson 2012年05月12日
只能默认路径啊
只能默认路径啊
han_leimin 2012年05月13日
楼主太好了,谢谢
楼主太好了,谢谢
scfhcx 2012年05月14日
scfhcx 2012年05月14日
顶
顶
scfhcx 2012年05月14日
好,支持
好,支持
scfhcx 2012年05月14日
谢谢!
谢谢!
scfhcx 2012年05月14日
好,支持
好,支持
scfhcx 2012年05月14日
学习中
学习中
scfhcx 2012年05月14日
加油
加油
wilsonhe 2012年05月15日
这个是最新版的吧,楼主真强
这个是最新版的吧,楼主真强
llllll3002 2012年05月18日
强烈支持,真牛楼主@!
强烈支持,真牛楼主@!
帖子是随时更新的吗?
帖子是随时更新的吗?
网速不好,损失我无数积分!
网速不好,损失我无数积分!
mumuyang 2012年05月20日
好东西 谢谢
好东西 谢谢
liqing0308 2012年05月21日
太好了,正是需要的
太好了,正是需要的
楼主,太强了。顶了
楼主,太强了。顶了
lq801001 2012年05月21日
这么好的帖子。正需要
这么好的帖子。正需要
这么好的帖子。正需要
这么好的帖子。正需要
这么好的帖子。正需要这么好的帖子。正需要这么好的帖子。正需要这么好的帖子。正需要这么好的帖子。正需要
guhcun 2012年05月28日
刚下了,谢谢
刚下了,谢谢
seantang 2012年06月05日
好!
好!
hzqydq 2012年06月06日
高手请指教,10.4的怎么破解?
高手请指教,10.4的怎么破解?
tigerdill 2012年06月07日
谢谢了
谢谢了
pigedong 2012年06月14日
刚下了,谢谢
刚下了,谢谢
sdretel84 2012年06月19日
我装完破解完之后,运行程序出现错误,不知道怎么解决!
jingjisong 2012年06月21日
要收费阿,太不够意思了
要收费阿,太不够意思了
dl3826 2012年06月21日
谢谢分享!!!!!!!!!!
谢谢分享!!!!!!!!!!
myxkd88 2012年06月29日
安装文件给的10.4版本的,破解方法是10.3.2版本的,怎么回事?
afeionline 2012年07月06日
破解方法都一样,所以一直沿用了
回复1067楼myxkd88:
破解方法都一样,所以一直沿用了
回复1067楼myxkd88:
回复22楼jerryonline:
那是因为生成multipart需要在editor模式下进行,我上传了一个视频,注意看他拖选的时候是从哪里开始拖选的,如果方法不对也不能同时生成多个part!
回复22楼jerryonline:
xingkunpeng 2012年07月13日
回复1楼fenghaili:
我再第六步等了半天也没有弹出TXT文档啊????
回复1楼fenghaili:
jisay 2012年07月17日
感谢分享!
感谢分享!
cwq1026_e 2012年07月20日
thanks a lot
thanks a lot
zhaozhij316 2012年07月22日
xiexie谢谢!!!!
xiexie谢谢!!!!
sibada001 2012年07月26日
为了积分回复帖子......
为了积分回复帖子......
为了积分回复帖子......
为了积分回复帖子......
不知道好不好用 下了再说
不知道好不好用 下了再说
下了五个了:)、。。。
下了五个了:)、。。。
继续顶贴。。。。。。。。
继续顶贴。。。。。。。。
fancy_wangf 2012年07月26日
顶贴下载。。。。。。
顶贴下载。。。。。。
hx594693278 2012年07月29日
正需要,非常感谢!
正需要,非常感谢!
yushuizi 2012年07月31日
下载不了,怎么办呀!真是个好东东!
下载不了,怎么办呀!真是个好东东!
好东东
好东东
这个是最新版的吧,谢谢楼主分享!
这个是最新版的吧,谢谢楼主分享!
准备下载!
准备下载!
这么现实,少一分都下载不了!
这么现实,少一分都下载不了!
bitiwindy 2012年08月04日
谢谢楼主分享
谢谢楼主分享
atianjun 2012年08月06日
:)最新版
:)最新版
longfan 2012年08月08日
真是太感谢了 好东西啊 这个
真是太感谢了 好东西啊 这个
longfan 2012年08月08日
破解好像还是老版本的是不
破解好像还是老版本的是不
haijenny 2012年08月13日
动生成器件封装
动生成器件封装
2805101015 2012年08月16日
好东西,顶楼主
好东西,顶楼主
miaoguoqiang 2012年08月17日
有什么感想,您也来说说吧!
有什么感想,您也来说说吧!
roylee08 2012年08月17日
好不容易找到这个东东。不错~
好不容易找到这个东东。不错~
dzhvip 2012年08月20日
多谢分享..........
多谢分享..........
jqpcb 2012年08月20日
路过,分享下,制板请找--佳庆电路,服务、价格、质量、速度你满意的选择!!!!
njxixi 2012年08月22日
口渴来了个大鸭梨,谢谢楼主分享!
口渴来了个大鸭梨,谢谢楼主分享!
echun 2012年08月24日
网速不给力,下不动
网速不给力,下不动
fubaojun 2012年08月25日
我安装了怎么还是出现了license not found,LP wizard will run in‘calculator’mode,请问怎么回事啊?我用的是Cadence16.5的版本 不知道行不行啊?还有 右键我的电脑->属性->高级->环境变量 在 系统变量 中创建变量 MGLS_LICENSE_FILE , 变量值为 C:\LICENSE.dat就能进入 但是显示上述英文~求回复 常来看 谢谢谢谢~
lpstar 2012年08月31日
似乎要很多钱的,55555555555
似乎要很多钱的,55555555555
wolf343105 2012年09月01日
Thanks,Hey !!
Thanks,Hey !!
feiyuneiio 2012年09月08日
哇,这个是最新版的吧,楼主真强
哇,这个是最新版的吧,楼主真强
weiwei_electro 2012年09月09日
2012年3月1日全新升级LP_wizard V10.4 ,自动生成器件封装。
看看。学习一下。:P
看看。学习一下。:P
jisay 2012年09月10日
Thanks:lol
Thanks:lol
huashi801 2012年09月11日
谢楼主
谢楼主
depv 2012年09月17日
Thanks for sharing!
Thanks for sharing!
depv 2012年09月17日
Thanks for sharing!
Thanks for sharing!
wzzw 2012年09月19日
再次感谢版主!!!
再次感谢版主!!!
Phonse 2012年09月19日
分数太少了。。回复赚分中。。
分数太少了。。回复赚分中。。
Phonse 2012年09月19日
先下载三个。。回复
先下载三个。。回复
Phonse 2012年09月19日
第四个中。。
第四个中。。
Phonse 2012年09月19日
五个中。。谢谢
五个中。。谢谢
Phonse 2012年09月19日
第六个下载中。。谢谢
第六个下载中。。谢谢
Phonse 2012年09月19日
第七个哈。。
第七个哈。。
Phonse 2012年09月19日
八个中。。谢谢
八个中。。谢谢
Phonse 2012年09月19日
最后一个
最后一个
pdd083051 2012年09月20日
嗯 支持一个~~感谢分享~~
嗯 支持一个~~感谢分享~~
wwdzaefd 2012年09月21日
好东西要顶
好东西要顶
lzscan 2012年09月21日
thank you,话说生成license的时候是不是应该改为10.5LPW
fenghaili 2012年09月21日
lzscan 发表于 2012-9-21 13:05 static/image/common/back.gif
我想你知道答案的。嘿嘿
我想你知道答案的。嘿嘿
zmg2007 2012年09月21日
谢谢提供!
谢谢提供!
hcliang 2012年09月24日
谢谢楼主~~~
谢谢楼主~~~
jorison 2012年09月24日
版主威武!
版主威武!
hcliang 2012年09月25日
我安装了也是出现license not found,LP wizard will run in‘calculator’mode,楼主怎么解决的啊?:Q
佳庆电路 2012年09月25日
快速PCB制作,抄板、改板、1-30层-样品、小批量。 PCB制造厂商--佳庆电路--QQ:1085935000
fenghaili 2012年09月25日
hcliang 发表于 2012-9-25 10:23 static/image/common/back.gif
仔细检查License的步骤,重新来一遍。
hcliang 2012年09月25日
fenghaili 发表于 2012-9-25 11:46 static/image/common/back.gif
谢谢版主~果然是license有点问题~现在ok了
X_LOVE_ELEC 2012年09月26日
:lol好东西
:lol好东西
sun2955 2012年09月27日
谢谢
谢谢
gonglex 2012年09月29日
好人啊 谢谢楼主 找了好久了
好人啊 谢谢楼主 找了好久了
dinglujie 2012年10月02日
感谢好人楼主啊。很好用。
感谢好人楼主啊。很好用。
chainwell 2012年10月02日
非常感谢啊,找的累死我了
非常感谢啊,找的累死我了
haolip 2012年10月03日
谢谢分享,好东西!
谢谢分享,好东西!
haolip 2012年10月03日
好慢呀,,,
好慢呀,,,
sswadrn 2012年10月03日
怎么解决呢 我把license 按照说明 弄了好几遍了 还是不行呢
xiexiaohui85 2012年10月05日
谢谢分享!!
谢谢分享!!
fenghaili 2012年10月06日
sswadrn 发表于 2012-10-3 12:07 static/image/common/back.gif
怎么解决呢 我把license 按照说明 弄 ...
还是不够仔细。。。。。
还是不够仔细。。。。。
huamiai 2012年10月07日
载下来了,但无法解压。
载下来了,但无法解压。
humenghua123 2012年10月10日
听说这个很好用,先下再说。谢谢楼主!
听说这个很好用,先下再说。谢谢楼主!
ydyuhu 2012年10月10日
thank you very much
thank you very much
OrcadUser 2012年10月10日
Thanks fenghaili for your sharing :lol
myh800717 2012年10月12日
很不错的软件,我正在学习!
很不错的软件,我正在学习!
newstarqu 2012年10月13日
装了一下午终于弄好了,谢楼主!
装了一下午终于弄好了,谢楼主!
IFIREFLY 2012年10月16日
好东西要顶!
好东西要顶!
rchsc 2012年10月21日
貌似不支持DXP。不过正在学cadence还是很有用处的。。
songxb001 2012年10月22日
正在用这个软件,真是太感谢了!
正在用这个软件,真是太感谢了!
twobomb 2012年10月31日
真强。有了这个做封装就方便了。
真强。有了这个做封装就方便了。
kisswumi 2012年11月04日
好东西,顶顶
好东西,顶顶
zhangwb 2012年11月06日
能破解吗?
能破解吗?
佳庆电路 2012年11月06日
快速PCB制作,抄板、改板、1-30层-样品、小批量。 PCB制造厂商--佳庆电路--Mobile:13923864385 QQ:1085935000 曾生
ecbios 2012年11月06日
非常感谢,已经下载用着不错
非常感谢,已经下载用着不错
james001 2012年11月08日
Thanks
Thanks
chin5984 2012年11月08日
謝謝大大無私的公享
謝謝大大無私的公享
selok 2012年11月12日
谢谢分享
谢谢分享
fanspeed 2012年11月14日
版本很新额
版本很新额
再顶一顶 赚点积分
再顶一顶 赚点积分
yyliang 2012年11月18日
非常感谢分享这么好东东
非常感谢分享这么好东东
yyliang 2012年11月18日
正在下载,希望能正常破解使用,呵呵
正在下载,希望能正常破解使用,呵呵
psl_87 2012年11月19日
都更新到10.5了,给力
都更新到10.5了,给力
j306808088 2012年11月21日
不知道老办法能破解否 10.4 真没搞定呀 不知道咋办
braveboys 2012年11月23日
赞,顶楼主了
赞,顶楼主了
feiante 2012年11月24日
没有看出多了些什么新功能
没有看出多了些什么新功能
xuser 2012年11月28日
下来看看,谢谢楼主分享。
下来看看,谢谢楼主分享。
qizhihui628 2012年11月28日
不错,谢谢。
不错,谢谢。
zbmzy 2012年12月01日
支持!
支持!
zbmzy 2012年12月01日
好,谢了
好,谢了
guetcw 2012年12月02日
正需要啊
正需要啊
qiyong 2012年12月12日
好资料,真想下载,可惜没有积分:'(
好资料,真想下载,可惜没有积分:'(
qiyong 2012年12月12日
安装成功了,感谢楼主:victory:
安装成功了,感谢楼主:victory:
shulan 2012年12月14日
顶了,下载完毕,等待马上安装,试试看了
顶了,下载完毕,等待马上安装,试试看了
freelsen 2012年12月14日
非常感谢。:D:lol
非常感谢。:D:lol
riscsystem 2012年12月18日
thanks for shairng
thanks for shairng
yuzhoushenchu 2012年12月24日
谢谢分享啊!!!
谢谢分享啊!!!
f126054488 2012年12月26日
好東西唷,快來下載
好東西唷,快來下載
xuzhiping_123 2012年12月27日
支持下
支持下
xmbonny 2012年12月29日
好东西,需要呀
好东西,需要呀
xmbonny 2012年12月29日
再次感谢楼主
再次感谢楼主
beiji1984 2012年12月31日
好极了,破解成功,谢谢了。:lol
好极了,破解成功,谢谢了。:lol
wdsm 2013年01月03日
谢谢了,这是个好东西
谢谢了,这是个好东西
rainbowII 2013年01月03日
谢谢分享
谢谢分享
lzgjxh 2013年01月04日
谢谢了,非常喜欢的软件
谢谢了,非常喜欢的软件
lzgjxh 2013年01月04日
有机会偶再来,我会关注新的版本的
有机会偶再来,我会关注新的版本的
elm99 2013年01月15日
谢谢lz!
谢谢lz!
elm99 2013年01月15日
要很多分呐!
要很多分呐!
elm99 2013年01月15日
再次感谢lz!附带挣点积分
再次感谢lz!附带挣点积分
gwj221 2013年01月16日
哇,这个是最新版的吧,楼主真强
哇,这个是最新版的吧,楼主真强
jingjisong 2013年01月18日
good, i need it:lol
good, i need it:lol
jerryaaa 2013年01月19日
非常需要,谢谢!!!
:victory:
非常需要,谢谢!!!
:victory:
xuqiangzjg 2013年01月23日
谢谢分享
谢谢分享
fjzbf 2013年01月23日
升级一下
升级一下
fjzbf 2013年01月23日
不够积分........
不够积分........
fjzbf 2013年01月23日
感谢楼主分享,试用能破解!!
感谢楼主分享,试用能破解!!
udolf 2013年01月26日
谢楼主。:victory:
谢楼主。:victory:
yuanqing17 2013年01月26日
dongfanghong 发表于 2010-7-31 09:52 static/image/common/back.gif
好,支持
:victory:
好,支持
:victory:
ggyygy 2013年01月27日
看來不錯
看來不錯
qizhihui628 2013年01月29日
Thank you Very Much, It is a good tool.
shiy 2013年01月31日
不错,看看
不错,看看
shiy 2013年01月31日
很好,正式我想要的东西
很好,正式我想要的东西
shiy 2013年01月31日
不错,收藏
不错,收藏
fanricker 2013年01月31日
支持EECHINA,感谢分享!
支持EECHINA,感谢分享!
wori 2013年02月06日
一下就9个积分没了:'(
一下就9个积分没了:'(
cooltalk 2013年02月11日
非常感谢楼主分享
非常感谢楼主分享
lz_study 2013年02月12日
可以使用。谢谢分享。
可以使用。谢谢分享。
astwish 2013年02月25日
thank you very much !
yuazhang 2013年02月25日
下来看看
下来看看
好
好
支持一下
支持一下
安装一下用用
安装一下用用
安装好慢啊
安装好慢啊
好慢,现在才34%
好慢,现在才34%
pcb_86 2013年02月27日
谢谢分享,太好了,DD更好。
谢谢分享,太好了,DD更好。
chinaweg 2013年03月01日
非常感谢楼主无私的提供:)
非常感谢楼主无私的提供:)
杀鸡的蝎子 2013年03月05日
好东西!
好东西!
lcptw 2013年03月07日
没积分了,怎么办?:L
没积分了,怎么办?:L
ali668 2013年03月21日
谢谢分享
谢谢分享
lq801001 2013年04月07日
哇,这个是最新版的吧,楼主真强
哇,这个是最新版的吧,楼主真强
lq801001 2013年04月08日
顶,谢谢楼主分享
顶,谢谢楼主分享
shangyu7 2013年04月11日
支持一下啊
支持一下啊
13yeying 2013年04月12日
楼主,我电脑WIN7 64位的,安装需要netframework 3.5.如何下载到啊
qboy 2013年04月13日
10.是不是pads自带的?
10.是不是pads自带的?
qboy 2013年04月13日
顶顶。求积分。。。。
顶顶。求积分。。。。
qboy 2013年04月13日
多谢分享!
多谢分享!
spdrdrsp 2013年04月13日
好 支持!
好 支持!
哇,这个是最新版的吧,楼主真强
哇,这个是最新版的吧,楼主真强
mitower 2013年04月17日
多謝分享!
多謝分享!
seraph1001 2013年04月18日
太抠门了吧,一个文件直接扣9分啊
太抠门了吧,一个文件直接扣9分啊
panminghui 2013年04月19日
受教育了!!!!!!!!!!!!!!!!!!!!!!!!!!!!
kevinjz2010 2013年04月19日
谢谢 正需要~
谢谢 正需要~
adigita 2013年04月26日
楼主真是好人啊
楼主真是好人啊
kjq999 2013年04月27日
多谢楼主无私
多谢楼主无私
dave889887 2013年04月27日
刚刚下完,谢谢楼主分享了!
刚刚下完,谢谢楼主分享了!
222zhumingming 2013年04月28日
谢谢了!!!!!!!
谢谢了!!!!!!!
谢谢了,学习一下!!!!!!
谢谢了,学习一下!!!!!!
CHINATEABOY 2013年05月06日
太:lol强了~~
太:lol强了~~
无敌 2013年05月07日
越来越专业化,越来越庞大
越来越专业化,越来越庞大
mangoxm 2013年05月11日
非常好 谢谢
非常好 谢谢
txqtomton 2013年05月16日
非常需要
非常需要
好东西要顶
好东西要顶
好东东 学习了
好东东 学习了
mhemara 2013年05月22日
哇,这个是最新版的吧,楼主真强
哇,这个是最新版的吧,楼主真强
weichaozhou 2013年05月24日
好东西,谢谢
好东西,谢谢
linkzhang 2013年05月30日
谢谢lz分享,这软件很有用。
谢谢lz分享,这软件很有用。
jfls 2013年06月10日
非常好:)
非常好:)
jackliuwenli 2013年06月12日
试试,先谢谢LZ,无私大爱。
试试,先谢谢LZ,无私大爱。
guyefeng 2013年06月17日
好,,,,,,,,,,谢谢
好,,,,,,,,,,谢谢
wccembcom 2013年06月19日
十分感谢~~~~
十分感谢~~~~
aqiao_a2001 2013年06月25日
积分不够,穷啊
积分不够,穷啊
kuka_555 2013年06月26日
感谢楼主哟:lol
感谢楼主哟:lol
prince_yu 2013年07月10日
谢谢楼主的分享
谢谢楼主的分享
dlfeng 2013年07月19日
好,多谢
好,多谢
ziv051035 2013年07月26日
用着试试,谢谢楼主。
用着试试,谢谢楼主。
小驹德尔驾 2013年08月05日
解压报错,为何呀
解压报错,为何呀
流光飞絮间 2013年08月05日
顶一个,下载来看看。谢谢LZ分享。
顶一个,下载来看看。谢谢LZ分享。
gpslon 2013年08月06日
听说很不错 是中文的不:victory:
gpslon 2013年08月06日
分够不够哦 看看
分够不够哦 看看
henrei 2013年08月09日
非常感激楼主分享
非常感激楼主分享
MXPMCU 2013年08月16日
顶!顶!
顶!顶!
zhwzjf 2013年08月22日
顶楼主,谢谢!
顶楼主,谢谢!
ciciendi 2013年09月03日
牛逼的人哪
牛逼的人哪
peace7530036 2013年09月08日
点扣了,下不了。唬人。
点扣了,下不了。唬人。
ttyinghero 2013年09月11日
希望能好用,谢谢
希望能好用,谢谢
huke08 2013年10月07日
支持一下
支持一下
liujijun 2013年10月10日
多谢分享!
多谢分享!
Aries 2013年10月22日
虽然看不大明白 还是学习了 哈哈
虽然看不大明白 还是学习了 哈哈
lhx000 2013年10月28日
支持一下,谢谢,,,,,,,,
支持一下,谢谢,,,,,,,,
lhx000 2013年10月28日
谢谢奉献,,,,,,,
谢谢奉献,,,,,,,
zwc58 2013年11月10日
好东西,谢谢
好东西,谢谢
whtristan 2013年12月04日
感谢楼主分享
感谢楼主分享
onioncjj 2013年12月13日
找了好久,先顶在下:victory:
找了好久,先顶在下:victory:
meiyaolei 2013年12月16日
谢谢分享。顶了
谢谢分享。顶了
adongzhu 2013年12月24日
谢谢分享
谢谢分享
bossdun 2014年02月19日
感谢。不错的软件
感谢。不错的软件
yhchu 2014年02月20日
好东西一定要顶
好东西一定要顶
phjxt 2014年02月20日
已经下载了,先安装试试 ,听说很好用的。
backtoworld 2014年03月14日
要扣多少分数哦?
要扣多少分数哦?
风火连天 2014年03月26日
好,支持楼主分享
好,支持楼主分享
wxsl711 2014年04月04日
创建封装Thermal relief没有正确创建,allegro 16.6 lp10.5,是设置不正确吗
cisilian 2014年04月27日
bleaz 发表于 2010-7-31 11:18 static/image/common/back.gif
谢谢!
我生成的封装 焊盘没加进到封装中去。什么原因?allegro.jrl,1记录中出现错误提示。
\i (00:00:06) pick -3.55 5.715
\t (00:00:06) last pick: -3.5500 5.7150
\e (00:00:06) ERROR(SPMHAP-2): No padstack specified.
allegro.jrl,1全文记录如下:
\t (00:00:01) allegro 16.5 P003 (v16-5-13C) i86
\t (00:00:01) Journal start - Sun Apr 27 14:06:36 2014
\t (00:00:01) Host=WINDOWS-PC User=windows Pid=5456 CPUs=4
\t (00:00:01)
\t (00:00:04) Starting new design...
\i (00:00:04) trapsize 955
\i (00:00:04) trapsize 929
\i (00:00:04) trapsize 959
\i (00:00:04) trapsize 971
\i (00:00:04) trapsize 1728
\i (00:00:04) replay soj127p866x356-20n.scr
\i (00:00:04) version 16.5
\t (00:00:04) Script version: 16.5
\i (00:00:04) setwindow pcb
\i (00:00:04) new
\i (00:00:04) newdrawfillin soj127p866x356-20n.dra 'Package Symbol'
\t (00:00:05) Starting new design...
\i (00:00:05) trapsize 971
\i (00:00:05) trapsize 929
\i (00:00:05) trapsize 959
\i (00:00:05) trapsize 986
\i (00:00:05) trapsize 1728
\i (00:00:05) setwindow Form.vf_vis
\i (00:00:05) FORM vf_vis 1 all_colorvisible YES
\i (00:00:05) FORM vf_vis 2 all_colorvisible YES
\i (00:00:05) setwindow pcb
\i (00:00:05) Color
\i (00:00:05) setwindow form.cvf_main
\i (00:00:05) FORM cvf_main class_list Geometry
\i (00:00:05) setwindow Form.cvf_main
\i (00:00:05) FORM cvf_main class_list Components
\i (00:00:05) FORM cvf_main all_visible1 YES
\i (00:00:05) FORM cvf_main all_visible2 YES
\i (00:00:05) FORM cvf_main all_visible3 YES
\i (00:00:05) FORM cvf_main all_visible5 YES
\i (00:00:05) FORM cvf_main package_geometry/pin_number/visible NO
\i (00:00:05) FORM cvf_main class_list Stack-Up
\i (00:00:05) FORM cvf_main ok
\i (00:00:05) generaledit
\i (00:00:05) prmed
\i (00:00:05) setwindow Form.prmedit
\i (00:00:05) FORM prmedit design
\i (00:00:05) FORM prmedit units Millimeter
\e (00:00:05) Change may cause round-off; run dbcheck.
\i (00:00:05) FORM prmedit accuracy 4
\i (00:00:05) FORM prmedit size Other
\i (00:00:05) FORM prmedit x -5
\i (00:00:05) FORM prmedit y -5
\i (00:00:05) FORM prmedit width 32
\i (00:00:05) FORM prmedit height 32
\i (00:00:05) FORM prmedit x -16
\i (00:00:05) FORM prmedit y -16
\i (00:00:05) FORM prmedit done
\w (00:00:06) WARNING(SPMHUT-48): Scaled value has been rounded off.
\i (00:00:06) trapsize 3252
\t (00:00:06) Performing DRC...
\t (00:00:06) No DRC errors detected.
\i (00:00:06) setwindow pcb
\i (00:00:06) add pin
\i (00:00:06) setwindow Form.mini
\i (00:00:06) FORM mini pad_name b245_65
\e (00:00:06) ERROR(SPMHAP-3): Problem loading 'b245_65.pad'.
\e (00:00:06) ERROR(SPMHA1-161): Cannot open the design database file ... run standalone dbdoctor on the file.
\i (00:00:06) FORM mini next_pin_number 1
\i (00:00:06) rotate
\t (00:00:06) Pin rotated by '0.000' degrees.
\i (00:00:06) iangle 0
\t (00:00:06) last pick: 0.0000 0.0000
\i (00:00:06) FORM mini pintype_mechanical NO
\i (00:00:06) FORM mini offsetx 0
\i (00:00:06) FORM mini offsety 0
\i (00:00:06) pick -3.55 4.445
\t (00:00:06) last pick: -3.5500 4.4450
\i (00:00:06) pick -3.55 3.175
\t (00:00:06) last pick: -3.5500 3.1750
\i (00:00:06) pick -3.55 1.905
\t (00:00:06) last pick: -3.5500 1.9050
\i (00:00:06) pick -3.55 0.635
\t (00:00:06) last pick: -3.5500 0.6350
\i (00:00:06) pick -3.55 -0.635
\t (00:00:06) last pick: -3.5500 -0.6350
\i (00:00:06) pick -3.55 -1.905
\t (00:00:06) last pick: -3.5500 -1.9050
\i (00:00:06) pick -3.55 -3.175
\t (00:00:06) last pick: -3.5500 -3.1750
\i (00:00:06) pick -3.55 -4.445
\t (00:00:06) last pick: -3.5500 -4.4450
\i (00:00:06) pick -3.55 -5.715
\t (00:00:06) last pick: -3.5500 -5.7150
\i (00:00:06) pick 3.55 -5.715
\t (00:00:06) last pick: 3.5500 -5.7150
\i (00:00:06) pick 3.55 -4.445
\t (00:00:06) last pick: 3.5500 -4.4450
\i (00:00:06) pick 3.55 -3.175
\t (00:00:06) last pick: 3.5500 -3.1750
\i (00:00:06) pick 3.55 -1.905
\t (00:00:06) last pick: 3.5500 -1.9050
\i (00:00:06) pick 3.55 -0.635
\t (00:00:06) last pick: 3.5500 -0.6350
\i (00:00:06) pick 3.55 0.635
\t (00:00:06) last pick: 3.5500 0.6350
\i (00:00:06) pick 3.55 1.905
\t (00:00:06) last pick: 3.5500 1.9050
\i (00:00:06) pick 3.55 3.175
\t (00:00:06) last pick: 3.5500 3.1750
\i (00:00:06) pick 3.55 4.445
\t (00:00:06) last pick: 3.5500 4.4450
\i (00:00:06) pick 3.55 5.715
\t (00:00:06) last pick: 3.5500 5.7150
\i (00:00:06) done
\t (00:00:06) Exiting from Add Pin.
\i (00:00:06) add line
\i (00:00:06) FORM mini class PACKAGE GEOMETRY
\i (00:00:06) FORM mini subclass DISPLAY_TOP
\i (00:00:06) FORM mini line_width 0.001
\i (00:00:06) pick -3.81 -6.5
\t (00:00:06) last pick: -3.8100 -6.5000
\i (00:00:06) pick -3.81 6.5
\t (00:00:06) last pick: -3.8100 6.5000
\i (00:00:06) pick 3.81 6.5
\t (00:00:06) last pick: 3.8100 6.5000
\i (00:00:06) pick 3.81 -6.5
\t (00:00:06) last pick: 3.8100 -6.5000
\i (00:00:06) done
\i (00:00:06) shape add
\i (00:00:06) FORM mini subclass DFA_BOUND_TOP
\i (00:00:06) FORM mini dyns_fill_type Static solid
\i (00:00:06) FORM mini dyns_grid None
\i (00:00:06) FORM mini dyns_lock_mode Line
\i (00:00:06) pick -5.05 -6.75
\t (00:00:06) last pick: -5.0500 -6.7500
\i (00:00:06) pick -5.05 6.75
\t (00:00:06) last pick: -5.0500 6.7500
\i (00:00:06) pick 5.05 6.75
\t (00:00:06) last pick: 5.0500 6.7500
\i (00:00:06) pick 5.05 -6.75
\t (00:00:06) last pick: 5.0500 -6.7500
\i (00:00:06) done
\i (00:00:06) FORM mini subclass PLACE_BOUND_TOP
\i (00:00:06) done
\i (00:00:06) add circle
\t (00:00:06) Pick center point of the circle.
\i (00:00:06) FORM mini line_width 0.05
\i (00:00:06) pick 0 0
\t (00:00:06) Pick a perimeter point on the circle.
\i (00:00:06) pick 0.35 0
\t (00:00:06) last pick: 0.3500 0.0000
\i (00:00:06) done
\i (00:00:06) pick 0 -0.5
\t (00:00:06) last pick: 0.0000 -0.5000
\i (00:00:06) pick 0 0.5
\t (00:00:06) last pick: 0.0000 0.5000
\i (00:00:06) done
\i (00:00:06) pick -0.5 0
\t (00:00:06) last pick: -0.5000 0.0000
\i (00:00:06) pick 0.5 0
\t (00:00:06) last pick: 0.5000 0.0000
\i (00:00:06) done
\i (00:00:06) FORM mini subclass ASSEMBLY_TOP
\i (00:00:06) FORM mini line_width 0.1
\i (00:00:06) pick -1.325 5.4
\t (00:00:06) last pick: -1.3250 5.4000
\i (00:00:06) pick -0.825 5.4
\t (00:00:06) last pick: -0.8250 5.4000
\i (00:00:06) done
\i (00:00:06) pick -3.76 -6.4
\t (00:00:06) last pick: -3.7600 -6.4000
\i (00:00:06) pick -3.76 6.4
\t (00:00:06) last pick: -3.7600 6.4000
\i (00:00:06) pick 3.76 6.4
\t (00:00:06) last pick: 3.7600 6.4000
\i (00:00:06) pick 3.76 -6.4
\t (00:00:06) last pick: 3.7600 -6.4000
\i (00:00:06) done
\i (00:00:06) FORM mini subclass SILKSCREEN_TOP
\i (00:00:06) FORM mini line_width 0.2
\i (00:00:06) pick -2 -6.4
\t (00:00:06) last pick: -2.0000 -6.4000
\i (00:00:06) pick -2 6.4
\t (00:00:06) last pick: -2.0000 6.4000
\i (00:00:06) pick 2 6.4
\t (00:00:06) last pick: 2.0000 6.4000
\i (00:00:06) pick 2 -6.4
\t (00:00:06) last pick: 2.0000 -6.4000
\i (00:00:06) done
\i (00:00:06) FORM mini line_width 0.5
\i (00:00:06) pick -1 5.4
\t (00:00:06) last pick: -1.0000 5.4000
\i (00:00:06) pick -0.75 5.4
\t (00:00:06) last pick: -0.7500 5.4000
\i (00:00:06) done
\i (00:00:06) FORM mini line_width 0.25
\i (00:00:06) pick -4.5 6.55
\t (00:00:06) last pick: -4.5000 6.5500
\i (00:00:06) pick -4.375 6.55
\t (00:00:06) last pick: -4.3750 6.5500
\i (00:00:06) done
\i (00:00:06) package_height
\i (00:00:06) pick grid 0 0
\i (00:00:06) FORM mini height_max 3.56mm
\i (00:00:06) done
\e (00:00:06) Form field label not found
\i (00:00:06) Label refdes
\t (00:00:07) Pick text location.
\i (00:00:07) setwindow Form.mini
\i (00:00:07) FORM mini text_block 3
\i (00:00:07) FORM mini angle 90
\i (00:00:07) FORM mini mirror NO
\i (00:00:07) FORM mini text_justification Center
\i (00:00:07) FORM mini class REF DES
\i (00:00:07) FORM mini subclass ASSEMBLY_TOP
\i (00:00:07) setwindow pcb
\i (00:00:07) pick 0 0.75
\t (00:00:07) last pick: 0.0000 0.7500
\t (00:00:07) Enter text string.
\i (00:00:07) Text REF
\i (00:00:07) done
\i (00:00:07) Label refdes
\i (00:00:07) FORM mini subclass SILKSCREEN_TOP
\i (00:00:07) done
\i (00:00:07) Label device
\i (00:00:07) FORM mini class DEVICE TYPE
\i (00:00:07) Text DEV
\i (00:00:07) done
\i (00:00:07) save
\t (00:00:07) Symbol 'soj127p866x356-20n.psm' created.
\i (00:00:07) exit
\t (00:00:07) Journal end - Sun Apr 27 14:06:42 2014
谢谢!
\t (00:00:01)
\i (00:00:04) new
\i (00:00:05) Color
\i (00:00:05) prmed
\i (00:00:06) done
\i (00:00:06) done
\i (00:00:06) done
\i (00:00:06) done
\i (00:00:06) done
\i (00:00:06) done
\i (00:00:06) done
\i (00:00:06) done
\i (00:00:06) done
\i (00:00:06) done
\i (00:00:06) done
\i (00:00:06) done
\i (00:00:06) done
\i (00:00:07) done
\i (00:00:07) done
\i (00:00:07) done
\i (00:00:07) save
\i (00:00:07) exit
zdcxp 2014年05月17日
需要9分 不知道有没有
需要9分 不知道有没有
游在云间 2014年06月02日
下载下来看一下,回复赚积分
下载下来看一下,回复赚积分
SkyBlue 2014年06月10日
感谢!
感谢!
cygnushan 2014年06月23日
不错,不知道相比10.3增加了哪些功能
不错,不知道相比10.3增加了哪些功能
1072978274 2014年06月25日
最新版的,更新一下
最新版的,更新一下
auky29 2014年07月13日
好软件,就是下载扣分有点多啊!
好软件,就是下载扣分有点多啊!
wuwenhao1991 2014年07月23日
感谢LZ
感谢LZ
xcron 2014年07月28日
可以使用,多谢!
可以使用,多谢!
小飞飞 2014年08月04日
好东西~~
好东西~~
2356444 2014年08月07日
感谢分享 楼主很帅
感谢分享 楼主很帅
aileensha520 2014年08月11日
好东西,多谢多谢
好东西,多谢多谢
liangyunsong 2014年08月30日
很需要这个
很需要这个
zpkingwell 2014年09月08日
感谢分享!
感谢分享!
z84297979 2014年09月10日
先下载看看,听说很不错!
先下载看看,听说很不错!
jsyc123 2014年10月26日
分了好多包,积分表示压力很大……
分了好多包,积分表示压力很大……
HAWK_2 2014年12月09日
谢谢楼主了。辛苦了
谢谢楼主了。辛苦了
gaowg 2014年12月19日
感谢楼主的无私奉献!
感谢楼主的无私奉献!
艾菲 2014年12月22日
多谢楼主,上一个下的没有破解好,不能wizard,试一下这个版本。
cczmzm 2014年12月28日
感谢楼主的无私奉献
感谢楼主的无私奉献
s147852 2015年01月27日
先收藏
先收藏
pcbkey 2015年01月31日
先拜山头
先拜山头
zhengjiwu1 2015年02月09日
真的有点贵
真的有点贵
3058 2015年02月12日
感谢楼主!!!
感谢楼主!!!
cyrs 2015年02月23日
谢谢分享
谢谢分享
pigy 2015年03月06日
谢谢分享
谢谢分享
pigy 2015年03月06日
谢谢分享,为了下载
谢谢分享,为了下载
pigy 2015年03月06日
再次感谢!
再次感谢!
pigy 2015年03月06日
再来一次
再来一次
lzjtao 2015年03月11日
很好的资料:victory::victory:
shanju 2015年04月23日
感謝樓主分享
感謝樓主分享
青蛙王子 2015年05月05日
好东东,谢谢楼主:lol
好东东,谢谢楼主:lol
simen5320 2015年05月18日
感谢分享。。。
感谢分享。。。
terry_yung 2015年07月06日
谢谢分享 好东西
谢谢分享 好东西
36597736 2015年07月20日
虽然还没用,但是还得说句楼主辛苦了
虽然还没用,但是还得说句楼主辛苦了
happylifelsc 2015年08月23日
我安装了也是出现license not found,LP wizard will run in‘calculator’mode,毫无解决办法,文件有问题大家就别试了!!!
yjb3469 2015年10月02日
很好很方便的软件,但我用DXP这么也导入错误,郁闷啊!
hellenho 2015年11月27日
LP_WINZARD10.2/10.3软件
自动生成器件封装
自动生成器件封装
lw0302 2015年12月15日
谢谢楼主分享,下载学习下!
谢谢楼主分享,下载学习下!
yuhuikeji 2015年12月22日
好像不太好用!!!!!!!!!!
好像不太好用!!!!!!!!!!
zzxydedu118 2016年01月17日
深圳信盈达专注于嵌入式开发、单片机培训,包学会,包高薪就业。报名学习电话: 袁老师13083712301QQ483059208:)
华强快捷电路板 2016年08月05日
大家好 我们公司专业生产电路板打样30元起 批量生产300元一平米 价格从优 品质保证 联系Q275001532 如有打扰之处请谅解
ThinkPad545 2017年08月05日
好东西
好东西
战神战神 2019年05月25日
最新版是什么版本了呀
最新版是什么版本了呀
好,支持
