关于ARM2440中断源个数的一点想法
2016年08月09日 10:03 发布者:designapp
S3c2440支持多达36个内部中断源和24个外部中断源,分别使用内部终端屏蔽寄存器INTMSK和外部中断寄存器MSK进行屏蔽控制。其中,外部中断源通过GPIO以复用的方式成为内部中断源的一部分。但是我们清楚,INTMSK是一个32位的寄存器,最多只能支持32中断,它是如何对应这么多中断的呢?
首先我们先看INTMSK对应的位。
INTERRUPT MASK (INTMSK) REGISTER (Continued)
INT_ADC 0 = Service available, 1 = Masked 1
INT_RTC 0 = Service available, 1 = Masked 1
INT_SPI1 0 = Service available, 1 = Masked 1
INT_UART0 0 = Service available, 1 = Masked 1
INT_IIC 0 = Service available, 1 = Masked 1
INT_USBH 0 = Service available, 1 = Masked 1
INT_USBD 0 = Service available, 1 = Masked 1
INT_NFCON 0 = Service available, 1 = Masked 1
INT_UART1 0 = Service available, 1 = Masked 1
INT_SPI0 0 = Service available, 1 = Masked 1
INT_SDI 0 = Service available, 1 = Masked 1
INT_DMA3 0 = Service available, 1 = Masked 1
INT_DMA2 0 = Service available, 1 = Masked 1
INT_DMA1 0 = Service available, 1 = Masked 1
INT_DMA0 0 = Service available, 1 = Masked 1
INT_LCD 0 = Service available, 1 = Masked 1
INT_UART2 0 = Service available, 1 = Masked 1
INT_TIMER4 0 = Service available, 1 = Masked 1
INT_TIMER3 0 = Service available, 1 = Masked 1
INT_TIMER2 0 = Service available, 1 = Masked 1
INT_TIMER1 0 = Service available, 1 = Masked 1
INT_TIMER0 0 = Service available, 1 = Masked 1
INT_WDT_AC97 0 = Service available, 1 = Masked 1
INT_TICK 0 = Service available, 1 = Masked 1
nBATT_FLT 0 = Service available, 1 = Masked 1
INT_CAM 0 = Service available, 1 = Masked 1
EINT8_23 0 = Service available, 1 = Masked 1
EINT4_7 0 = Service available, 1 = Masked 1
EINT3 0 = Service available, 1 = Masked 1
EINT2 0 = Service available, 1 = Masked 1
EINT1 0 = Service available, 1 = Masked 1
EINT0 0 = Service available, 1 = Masked 1
我们发现INTMSK的第5,6位对应了EINT4_7, EINT8_23,20个外部中断,也就是所,这20个GPIO引脚只能触发这两个中断。
但是当中断到来时,我们如果判断是由哪一个GPIO引脚触发的呢?这个时候我们可以通过查询EINTMASK来判断中断源。
EINTMASK Bit Description
EINT23 0 = enable interrupt 1= masked
EINT22 0 = enable interrupt 1= masked
EINT21 0 = enable interrupt 1= masked
EINT20 0 = enable interrupt 1= masked
EINT19 0 = enable interrupt 1= masked
EINT18 0 = enable interrupt 1= masked
EINT17 0 = enable interrupt 1= masked
EINT16 0 = enable interrupt 1= masked
EINT15 0 = enable interrupt 1= masked
EINT14 0 = enable interrupt 1= masked
EINT13 0 = enable interrupt 1= masked
EINT12 0 = enable interrupt 1= masked
EINT11 0 = enable interrupt 1= masked
EINT10 0 = enable interrupt 1= masked
EINT9 0 = enable interrupt 1= masked
EINT8 0 = enable interrupt 1= masked
EINT7 0 = enable interrupt 1= masked
EINT6 0 = enable interrupt 1= masked
EINT5 0 = enable interrupt 1= masked
EINT4 0 = enable interrupt 1= masked
Reserved Reserved
但是还有一个疑问,不是说60个中断源吗?除去24个外部中断源应该还有60-24 -(32-6)=10个内部中断源啊。他们在哪呢?
其实这里涉及到了子中断源的概念。
Sub Sources Descriptions Source
INT_AC97 AC97 interrupt INT_WDT_AC97
INT_WDT Watchdoc interrupt INT_WDT_AC97
INT_CAM_P P-port capture interrupt in camera interface INT_CAM
INT_CAM_C C-port capture interrupt in camera interface INT_CAM
INT_ADC_S ADC interrupt INT_ADC
INT_TC Touch screen interrupt (pen up/down) INT_ADC
INT_ERR2 UART2 error interrupt INT_UART2
INT_TXD2 UART2 transmit interrupt INT_UART2
INT_RXD2 UART2 receive interrupt INT_UART2
INT_ERR1 UART1 error interrupt INT_UART1
INT_TXD1 UART1 transmit interrupt I NT_UART1
INT_RXD1 UART1 receive interrupt INT_UART1
INT_ERR0 UART0 error interrupt INT_UART0
INT_TXD0 UART0 transmit interrupt INT_UART0
INT_RXD0 UART0 receive interrupt NT_UART0
