Analog Devices Precision Signal Conditioning
2015年11月09日 16:25 发布者:eechina
Analog Devices Precision Signal Conditioning solutions are suited to designers' diverse application requirements in performance, speed, power, and size. These solutions allow designers to simplify the operation and adoption of new systems.Analog signals generally require some form of modification before they can be digitized. Signal conditioning prepares signals for the next stage of processing and can dramatically improve the signal-to-noise ratio.
Signal conditioning is one of the most important aspects of an effective data acquisition system. Many high precision applications require signal conditioning before a data acquisition device can accurately measure the signal. Precision signal conditioning solutions can greatly improve the efficacy and sensitivity of a system or application.
Analog Devices industry-leading, precision signal processing components meet the combined requirements of integration, low power dissipation, and space savings for data acquisition, monitoring, and processing in high-performance applications. The precision signal conditioning portfolio features analog front end (AFE) devices, amplifiers, analog-to-digital converters (ADC), and digital-to-analog converters (DAC) designed to deliver unmatched performance in current and next generation designs.
View Product ListPrecision Amplifiers
The Analog Devices precision amplifiers are specifically designed to support traditional trimmed and zero-drift amplifier technology.
See all precision amplifiers
Precision ADCs
Analog Devices Precision Analog-to-Digital Converters (ADCs) are vital component of any analog sampling network, given they determine system performance. The precision ADC devices provide industry-leading performance with speeds up to 10MSPS, 8- bit to 32-bit resolution, and a range of ADC architectures including SAR—Successive Approximation ADCs, Σ-Δ Modulators, and isolated ADC.
See all precision ADCs
Precision DACs
Analog Devices Precision Digital-to-Analog Converters (DACs) achieve speeds up to 12MHz and are critical data conversion components used in most high performance signal processing systems. Analog Devices offers the industry's largest portfolio of DACs ranging from 8 bits to 20 bits in resolution. These DACs are recommended for use with the ADI clocking and timing products, op amps, and power management solutions that are designed to meet the demanding requirements of DAC applications.
See all precision DACs
Precision AFEs
Analog Devices offers precision Analog Front End (AFE) devices for photodetectors or other sensors whose output produces a current proportional to the sensed parameter or voltage input applications where the system requires the user to select between very precise gain levels to maximize the dynamic range.
See all precision AFEs
