Fairchild USB Type-C Portfolio
2015年11月09日 15:52 发布者:eechina
Fairchild USB Type-C Portfolio sets the convenience and simplicity standard for users, designers and manufacturers. It's optimized for cost, footprint and low-power use with a complete portfolio of discrete, flexible USB Type-C solutions from controllers to power switches and SuperSpeed switches. Power consumption is 1/10 of the nearest competitive solution and packages are up to 43% smaller.Features
Ultra-low-power consumption in standby mode
Flexible to accommodate standard changes
DFP, UFP, DRP role support
Active cable detection and power support
Small solutions in WLCSP and MLP packages, as small as 1.2x1.2x0.4mm
Thin USB Power Delivery (PD) interface for adaptive charging and vendor-defined messages
Audio and Debug Accessory Detection
View Product ListBlock Diagram
Controllers
Part NumberFunctionModeStandby Current typ (μA)Standby Current typ (nA)Package/Dimensions
(mm)Additional Resources
FUSB300C
Learn More
Programmable controllerDFP, UFP, DRP, accessory support202200WLCSP-9/1.2x1.2x0.4
DatasheetFUSB301
Notify Me
Autonomous controller with SuperSpeed switch controlDFP, UFP, DRP, accessory support53.5TMLP-10/1.6x1.2x0.4
Product BriefFUSB301A
Notify Me
Autonomous controller with configurable I2C addressDFP, UFP, DRP, accessory support53.5TMLP-12/1.6x1.6x0.4
Product BriefFUSB302Programmable controller with PDDFP, UFP, DRP, accessory support25370WLCSP-9, MLP-14/1.2x1.3x0.6, 2.5x2.5x0.8
DatasheetFUSB3301
Notify Me
Autonomous power adapter controllerDFP10—MLP-10/3x3x0.8
Product BriefData Switches
Part NumberFunctionData RateInsertion LossActive Current (μA)Package/Dimensions
FUSB340
USB 3.1 SuperSpeed switchUp to 10Gbps
-1.0dB at 2.5GHz12MLP-18/2x2.8x0.4
DatasheetProtection ICs
Part NumberFunctionDC Current (A)RDSON (mΩ)FeaturesPackage/Dimensions
FPF2290
Learn More
Over-voltage protection load switch4.533Selectable OVP, 100V surgeWLCSP-12/1.2x1.6x0.6
DatasheetFPF2411
Bi-directional load switch610RCB protection, slew rate controlWLCSP-12/1.2x1.6x0.6
DatasheetFPF2495
Learn More
VCONN protection4.533Over-voltage, over-current protectionWLCSP-9/1.2x1.2x0.6
Datasheet
