飞思卡尔16位单片机
2015年10月28日 10:22 发布者:herohxb
MCU clock speed: 4000000 HzBlock Module Name Address Range Status
0 PFLASH 4000 - 7FFF Programmed - Unselected
1 PFLASH C000 - FFFF Programmed - Unselected
2 PFLASH E08000 -E7BFFF Programmed - Unselected
3 PFLASH F88000 -FFBFFF Programmed - Unselected
4 DFLASH 800 -1F0BFF Programmed - Unselected
FP: The UNPROTECT command is not available for the PFLASH flash module => Skipped.
FP: The UNPROTECT command is not available for the DFLASH flash module => Skipped.
executing .\cmd\TBDML_vppon.cmd
!// Before programming the flash, the commands written below will be executed
done .\cmd\TBDML_vppon.cmd
Vppon command file correctly executed.
FP: Operation failed on PFLASH flash module.
FP: Operation failed on DFLASH flash module.
executing .\cmd\TBDML_vppoff.cmd
!// After programming the flash, the commands written below will be executed
done .\cmd\TBDML_vppoff.cmd
Vppoff command file correctly executed.
FP: Arm FLASH for loading.
FP: FLASH disarmed.
executing .\cmd\TBDML_reset.cmd
!// After reset the commands written below will be executed
done .\cmd\TBDML_reset.cmd
Reset command file correctly executed.
executing .\cmd\TBDML_postload.cmd
!// After load the commands written below will be executed
RESET
done .\cmd\TBDML_postload.cmd
Postload command file correctly executed.
Error: Loading failed!
in>
已经困扰我好久了,我尝试过解锁,能解锁;但每次解完,就显示"unable to connect to target CPU",求大神指点!!!!!!!!!
