ON Semiconductor NCV78763 Power Ballast and Dual LED Driver
2015年09月25日 14:33 发布者:eechina
ON Semiconductor NCV78763 Power Ballast and Dual LED Driver is a single-chip, highly efficient ballast and driver. It's designed for automotive front lighting applications like high beam, low beam, daytime running light (DRL), turn indicator, fog light, static cornering and so on. The NCV78763 is the best fit for high current LEDs and drives two strings up to 60V, by two internal independent buck switch channel outputs, with minimum external components. The output current and voltage can be customized according to the application requirements for each individual LED channel. A provided on−chip diagnostic feature for automotive front lighting eases the safety monitoring from the microcontroller. The device integrates a current−mode voltage booster controller, realizing a unique input current filter with a limited BOM.
More NCV78763 devices can be combined when more than two LED channels are required on one module, with the possibility for the booster circuits to operate in multiphase-mode. This helps to further optimize the filtering effect of the booster circuit and allows a cost effective dimensioning for mid to high power LED systems. Due to the SPI programmability, one single hardware setup can support multiple system configurations for a flexible platform solution approach.
Features
Single Chip Boost-Buck Solution
Two LED Strings up to 60V
High Current Capability up to 1.6A DC per Output
High Overall System Efficiency
Minimum of External Components
Active Input Filter with Low Current Ripple from Battery
Integrated Switched Mode Buck Current Regulator
Integrated Boost Current-mode Controller
Programmable Input Current Limitation
Average Current Regulation Through the LEDs
Applications
Front Lighting High Beam and Low Beam
Automotive
Day time Running Light (DRL)
Position or Park light
Turn Indicator
Fog Light and Static Cornering
View Product ListON Semiconductor NCV787630R1DAGEVB Power LED Boost-to-Buck Evaluation Board
ON Semiconductor NCV787630R1DAGEVB Power LED Boost-to-Buck Evaluation Board is used to evaluate the NCV78763 Power Ballast and LED Driver. It is the daughter board for the NCV786XXAR30GEVK Evaluation Kit.
View Product Detail
