进口代理G2 Ringging Sheave
2015年08月23日 22:00 发布者:coastaltrading
深圳湾边贸易公司 TEL:0755-86216601
品牌:G2 Ringging Sheave
原装进口代理G2 Ringging Sheave,交货更快,价格优惠!
Introduction
This manual explains the use and care of 14” rigging sheaves manufactured by Wireline Technologies, Inc. The sheave is available in two
models. The original model has shielded bearings and is identified by an orange cover. The sealed bearing model is identified by a yellow
cover. Each is available in two configurations. The no-shroud configuration, shown in figure 1, will allow a rope socket or “torpedo” to pass
over the wheel. The half-shroud configuration, shown in figure 2, has a cable shroud covering part of the wheel to aid in containing the line
in the wheel groove. Please read and become familiar with all of the information in this manual before using this equipment.
Warnings
• Read entire manual before operating this equipment.
• If proper procedures are not followed, loads may disengage.
• A falling load can cause serious injury or death.
• Never use this product for hoisting personnel.
• Always anchor or hang the sheave via the clevis, never by way of the cover or any ancillary equipment.
• Never apply more force than the Safe Working Load (SWL) listed on the affixed tag.
• The listed Safe Working Load is for the sheave assembly; the safe line tension will be less.
• Attachment to other equipment with lower SWL will reduce the allowable load.
• Always use a hand guard when the sheave is used around personnel.
• Always make sure the sheaves are properly maintained and properly rigged.
No-Shroud (Optional)
Figure 1
Half-Shroud (Standard)
Figure 2 2
Safe Working Load
The rated safe working load (SWL) for a WTI 14” sheave is 15,000 lbs. (6,800 kg.), with the exception of those manufactured for
Schlumberger. These sheaves, as directed by Schlumberger, have a safe working load of 10,000 lbs. (4,530 kg.). The allowable line pull will
depend upon both the SWL and the angle the line is deflected. If the sheave is used as a top sheave, it deflects the line 180°, see figure 3. If
the sheave is used as a bottom sheave, it deflects the line 90°, see figure 4. Never exceed the SWL, unless special precautions are taken in
accordance with your company’s policy. These precautions should include, but are not limited to, clearing the rig floor of all personnel. If
the SWL is exceeded, the sheave should be re-certified before it can safely be placed back in service.
Top Sheave
Max. line tension
7,5000 lbs. (3,400 kg)
Schlumberger Limit
Max. line tension
5,000 lbs (2,260 kg)
Bottom Sheave
Max. line tension
10,600 lbs. (4,800 kg)
Schlumberger Limit
Max. line tension
7,070 lbs (3,200 kg)
Safe Line Tension for
90-Degree Deflection
Figure 4
180-Degree Deflection
Figure 3 3
Clevis Options
Five clevis swivel assembly options for suspending/anchoring the sheave are available: These options are shown in figures 5 – 9 below. The
Clevis-Eye has an opening about 2.5” X 3.3” for a chain or sling. The opening width of the Clevis -AWS is 1 3/4” with a hole for a 1” pin.
The opening width of the Clevis -HLS is 1 1/4” with a hole for a 1” pin. The opening width of the Clevis-SJ is 7/8” with a hole for a 1 1/2”
pin. The shackle clevis has about the same opening as the Clevis-Eye.
Clevis-Eye
Part # RS-1075A
Figure 5
Clevis-AWS
Part # RS-1252A
Figure 6
Clevis-HLS
Part # RS-1552A
Figure 7
Clevis-SJ
Part # RS-1052A
Figure 8
Clevis-Shackle
Part # RS-1152A
Figure 9
