针对开发人员的1GHz OMAP4“火焰”平板电脑8月面世
2010年06月25日 10:40 发布者:嵌入式公社
“火焰”平板电脑(Blaze Tablet)由TI的OMAP4处理器驱动,在Blaze开发平台上设计,该平台要使软件兼容性达到最大。该平板电脑可容纳modem、WLAN、蓝牙、GPS,甚至FM广播。
该平板电脑具有外部相机模块以及外部DLP微型投影仪模块。核心是1GHz OMAP4430 处理器。
屏幕上10.4英寸XVGA (1024 x 768) LCD触摸屏,有两个USB接口。该设备可由USB供电。存储器是1GB lpDDR2和32GB eMMC。该电脑为开发人员设计,大概8月份可以拿到。
主要特性:
Core Logic
OMAP4430 1GHz application and multimedia processor IC
TWL6030 Phoenix power management IC
TWL6040 Phoenix audio IC
CDC3S04 clock driver IC
Memory
1 GB lpDDR2
32 GB eMMC v4.41
Display
10.4” XGA (1024 x 768) LCD
One (1) standard v1.1a DisplayPort connector
External pico DLP Projector Support
HDMI
User Interface
Projected Capacitance Touch (PCT) sensor
Multi-touch capable touch screen controller
Three (3) tri-color status LEDs used as backlight for “OS” buttons
Two (2) unbalanced mass vibration motors
Buttons and Switches
One (1) recessed, externally operable reset button
One (1) power on/off button
Three (3) front screen “OS” buttons
One (1) “lock” switch
One (1) battery mode switch
Serial Interfaces
One (1) HS USB OTG
Two (2) HS USB host ports
Removable Media
One (1) full size 8-bit SD/MMC external connector
One (1) full size SD/MMC internal connector
One (1) SIM card for modem support
Audio
One (1) 3.5 mm stereo headset jack for audio output and MIC input
Two (2) 1W RMS speakers
Four (4) digital microphones
Expansion
One (1) COM connector for connectivity modules
One (1) full miniPCIe connector for modem modules
Connectivity
WLAN (802.11a/b/g/n) via WL1283 COM7 module
BT via WL1283 COM7 module
GPS via WL1283 COM7 module
FM TX/RX via WL1283 COM7 module
Modem (Wide Area Network) Support
LTE modem support via standard miniPCIe module
3G modem support via standard miniPCIe module
To clarify, only one modem can be used at any given moment
Sensors
3-axis accelerometer
3-axis gyro
Temperature sensor
Ambient light sensor
Proximity sensor
Pressure (barometric) sensor
Digital compass
External Camera modules (optional)
5MP AF camera modules mounted externally on tablet frame
The camera module(s) will be connected to the Blaze via standard HDMI cables
Each OMAP4430 CSI-2 camera interface will have a dedicated HDMI-style connector
Mechanical
The mechanical envelope, is 10.48″ (266.094 mm) x 8.28″ (210.294 mm) x 1.14″ (29 mm)
The frame of Blaze Tablet is aluminum
The frame of the Blaze Tablet will be grooved to allow for external camera module and pico DLP projector attachment
The attachment system will provide flexibility to the pointing angles of the external camera modules and pico DLP projector
Power
Support for USB power
One (1) standard 5V input for wall power
4100 mAHr single-cell LiON Battery
Debug
One (1) 802.3 (wired) Ethernet port (RJ-45 connector)
One (1) MIPI Test and Debug connector
One (1) USB connector which has serial (UART) data
Optional debug LEDs
phoenixmy 2010年06月26日
关键是价格
关键是价格
nuaachu 2010年07月01日
关键是价格
关键是价格
nuaachu 2010年07月01日
关键是价格
关键是价格
429hyl 2010年07月02日
关键是价格
关键是价格
guokeqin 2010年07月05日
kankan!!
kankan!!
发骚胆 2011年02月19日
真漂亮!关键是价格。
真漂亮!关键是价格。
期待。。。。。。。。。。。。。
