Embedded Linux Howto
2009年07月16日 11:55 发布者:诸葛孔明
此文为转载的,希望能对大家有点帮助。------------------------------------------------------------------------
This document describes how to create a small linux system to be used as
embedded purpose from your desktop linux and some additional
specialized packages.
1. Introduction
1.1 Subject
1.2 New Versions
1.3 History
1.4 TODO
1.5 License
1.6 Contact
2. Dependencies
2.1 A Desktop Linux
2.2 Some software packages
3. The boot process.
3.1 Bios
3.2 The boot loader
3.3 The Kernel
3.4 Init
3.5 inittab
3.6 The login process
4. Creating a root file system
4.1 Creating a new partition
4.2 Creating an ext2 file system on the new partition
4.3 Mounting the partition
4.4 Populating the filesystem
5. Installing TinyLogin & login dependencies
5.1 Configuring TinyLogin
5.2 Installing TinyLogin
5.3 Installing Sysvinit & start-stop-daemon
5.4 Configuring Sysvinit
5.5 Creating initial boot scripts
5.6 Copying passwd & group files
6. Not finished: Installing the ash root shell
6.1 Preparing ash
6.2 Configuring ash
7. Not finished: Installing BusyBox
7.1 Preparing BusyBox
7.2 Deploying BusyBox
8. Not finished: Installing required libraries
8.1 Which ones ?
8.2 Copying
8.3 ldconfig
诸葛孔明 2009年07月16日
2. Dependencies
2.1 A Desktop Linux
You will need a full linux distribution to build your own embedded linux
OS. It will contains everything you need (utilities, sources, compiler,
debugger, documentation....).
This is a list of the software i used to make LEM. Other specialized
software for embedded purpose may be foud at http://linux-embedded.org
TinyLogin
TinyLogin is a suite of tiny Unix utilities for handling logging into,
being authenticated by, changing one's password for, and otherwise
maintaining users and groups on an embedded system. It also provides
shadow password support to enhance system security. TinyLogin is, as the
name implies, very small, and makes an excellent complement to
BusyBox on an embedded System. TinyLogin is being maintained by Erik
Andersen
TinyLogin is available at http://tinylogin.lineo.com
BusyBox
Busybox is a multicall binary used to provide a minimal subset of
POSIX style commands and specialized functions.It is geared toward the
very small, i.e. boot floppies, embedded-systems, etc. Specifically it
is used in the Debian Rescue/Install system (which caused the original
busybox to be made), the Linux Routeur Project, LEM, lineo and others.
Busybox is being maintained by Erik Andersen
Busybox is available at http://busybox.lineo.com
Ash
Ash is a very small Bourne shell available at http://www.debian.
org/Packages/unstable/shells/ash.html
Sysvinit
Sysvinit is the most used init package for Linux. We will use init and
the C version of the start-stop-deamon. Sysvinit is available at \"ftp.
debian.org/debian/dists/slink/main/source/base\"
2. Dependencies
2.1 A Desktop Linux
TinyLogin
Andersen
BusyBox
Ash
Sysvinit
诸葛孔明 2009年07月16日
This section is for the most based on the Bootdisk-HOWTO.
3.1 Bios
All PC systems start the boot process by executing code in ROM
(specifically, the BIOS) to load the sector from sector 0, cylinder 0 of
the boot drive. The boot drive is usually the first floppy drive
(designated A: in DOS and /dev/fd0 in Linux). The BIOS then tries to
execute this sector. On most bootable disks, sector 0, cylinder 0
contains either:
Code from a boot loader such as LILO, which locates the kernel, loads it
and executes it to start the boot proper.
he start of an operating system kernel, such as Linux.
If a Linux kernel has been raw-copied to a diskette, a hard drive or
another media, the first sector of the disk will be the first sector
of the Linux kernel itself. This first sector will continue the boot
process by loading the rest of the kernel from the boot device.
3.2 The boot loader
We will use a boot loader like lilo to operate our boot process. It
permits to have the dev and production platforms on the same hardware
and to switch from one to the other by only rebooting. The lilo boot
loader is loaded by the bios. Then, it loads kernels or the boot sectors
of other operating systems. It also provides a simple command-line
interface to interactively select the item to boot with its options.
More may be found in the Lilo documentation at ftp://sunsite.unc.
edu/pub/Linux/system/boot/lilo/.
3.3 The Kernel
The kernel checks the hardware and mounts the root device. Then it looks
for the init program on the root filesystem and executes it.
3.4 Init
Init is the parent of all other processes that will run on your linux
OS, it will watch it's child processes and start, stop, re-lauch them if
needed. init takes all information from /etc/inittab.
3.5 inittab
The file /etc/inittab/ refers to scripts named /etc/rc... to do the
system setup. It also has entries for the getty tool to handle the login
process.
There is one getty available in the inittab file for each console you
allow for the users. Getty will launch /bin/login to verify the user
password.
More info about the boot process may be found at Linux Documentation
Project and in the init and inittab man pages.
3.1 Bios
contains either:
3.2 The boot loader
3.3 The Kernel
3.4 Init
3.5 inittab
process.
password.
诸葛孔明 2009年07月16日
Quoted from the LFS-HOWTO at http://huizen.dds.nl/~glb/
Before we can build our new Linux system, we need to have an empty Linux
partition on which we can build our new system. If you already have a
Linux Native partition available, you can skip this subsection and the
following one.
Start the fdisk program (or cfdisk if you prefer that program) with
the appropriate hard disk as the option (like /dev/hda if you want to
create a new partition on the primary master IDE disk). Create a Linux
Native partition, write the partition table and exit the (c)fdisk
program. If you get the message that you need to reboot your system to
ensure that that partition table is updated, then please reboot your
system now before continuing.
To create a new ext2 file system we use the mke2fs command. Give $LFS as
the only option and the file system will be created.
From now on I'll refer to this newly created partition as $EMBPART.
$EMBPART should be substituted with the partition you have created.
To access the newly created filesystem, you have to mount it. For this
create a /mnt/hda? directory and type at shell prompt:
mkdir /mnt/hda?
mount $EMBPART /mnt/hda?
If you created your partition on /dev/hda4, and you mounted it on
/mnt/hda4, when this document will tell you to copy a file to $dollar;
EMBPART/usr/bin then you will need to copy that file to
/mnt/hda4/usr/bin.
The root filesystem must contain everything needed to support a full
Linux system. We will build a directory structure not that far from
the File Hierarchy Standard
Directories
Directories are made by using the mkdir fonction in the new mounted
filesystem.
/proc
Directory stub required by the proc filesystem.
/etc
System configuration file
/sbin
Critical System binaries
/bin
Basic binaries considered part of the system
/lib
Shared Libraries to provide run time support
/mnt
Mount point for maintenance
/usr
Additional utilities and applications
cd /mnt/hda?
mkdir bin dev home proc sbin usr boot etc liv mnt root tmp var
mkdir -p usr/bin usr/sbin usr/share usr/lib
mkdir -p etc/config etc/default etc/init.d etc/rc.boot
mkdir -p etc/rc0.d etc/rc1.d etc/rc2.d etc/rc3.d etc/rc4.d etc/rc5.d
etc/rc6.d etc/rcS.d
the /dev directory
The dev directory is the stub required to perform devices input /
output. Each file in this directory may be created using the mknod
function. You may avoid losing time by directly copying the required dev
entries from your desktop Linux.
cp -av /dev/???? /mnt/hda?
following one.
mkdir /mnt/hda?
/mnt/hda4/usr/bin.
Directories
filesystem.
/proc
/etc
/sbin
/bin
/lib
/mnt
/usr
cd /mnt/hda?
etc/rc6.d etc/rcS.d
the /dev directory
诸葛孔明 2009年07月16日
TinyLogin is available at http://tinylogin.lineo.com.
It will give us the following tools in less than 35Ko :
/bin/addgroup, /bin/adduser, /bin/delgroup, /bin/deluser, /bin/login,
/bin/su, /sbin/getty, /sbin/sulogin, /usr/bin/passwd
Please refers to your main distribution doc or man pages to have a
full description of those commands.
[... part of TinyLogin README ...] TinyLogin is modularized to easily
allow you to build only the components you need, thereby reducing binary
size. To turn off unwanted TinyLogin components, simply edit the file
tinylogin.def.h and comment out the parts you do not want using C++
style (//) comments.
After the build is complete a tinylogin.links file is generated which is
then used by 'make install' to create symlinks to the tinylogin
binary for all compiled in functions. By default, 'make install' will
place a symlink forest into `pwd`/_install unless you have defined the
PREFIX environment variable.
After the kernel is done loading it attempts to run the init program
to finalize the boot process.
Unpack the Sysvinit archive.
Go to the src directory
Compile the package by running make
Copy the init executable in $EMBPART/sbin
The Sysvinit package also offers a C version of the start-stop-deamon in
the contrib directory.
Compile it.
Copy the file in $EMBPART/usr/sbin
Sysvinit needs a configuration file named inittab and placed in
$EMBPART/etc. The following is the one used in the LEM distro:
# /etc/inittab: init(8) configuration.
# $Id: inittab,v 1.6 1997/01/30 15:03:55 miquels Exp $
# Modified for LEM 2/99 by Sebastien HUET
# default rl.
# first except in emergency (-b) mode.
si::sysinit:/etc/init.d/rcS
# single-user mode.
~~:S:wait:/sbin/sulogin
# /etc/init.d executes the S and K scripts upon change
# 0:halt 1:single-user 2-5:multi-user (5 may be X with xdm or other) 6:
reboot.
l0:0:wait:/etc/init.d/rc 0
l1:1:wait:/etc/init.d/rc 1
l2:2:wait:/etc/init.d/rc 2
l3:3:wait:/etc/init.d/rc 3
l4:4:wait:/etc/init.d/rc 4
l5:5:wait:/etc/init.d/rc 5
l6:6:wait:/etc/init.d/rc 6
# CTRL-ALT-DEL pressed.
ca:12345:ctrlaltdel:/sbin/shutdown -t1 -r now
# Action on special keypress (ALT-UpArrow).
kb::kbrequest:/bin/echo "Keyboard Request--edit /etc/inittab to let this
work."
# /sbin/mingetty invocations for runlevels.
1:2345:respawn:/sbin/getty 9600 tty1
2:23:respawn:/sbin/getty 9600 tty2
#3:23:respawn:/sbin/getty tty3 #you may add console there
#4:23:respawn:/sbin/getty tty4
As seen in the inittab file, Sysvinit needs additional scripts in
their own directories.
Creating the necessary directories and base files
cd $EMBPART/etc
mkdir rc0.d rc1.d rc2.d rc3.d rc4.d rc5.d rc6.d init.d
rcS.d rc.boot
Go to the unpacked Sysvinit source directory.
Copy the debian/etc/init.d/rc to:$EMBART/etc/init.d
Go to the $EMBPART/etc/init.d/
Create a new file rcS like those in LEM:
#!/bin/sh
PATH=/sbin:/bin:/usr/sbin:/usr/bin
runlevel=S
prevlevel=N
umask 022
export PATH runlevel prevlevel
./etc/default/rcS
export VERBOSE
# Trap CTRL-C only in this shell so we can interrupt subprocesses.
trap ":" 2 3 20
# Call all parts in order.
for i in /etc/rcS.d/S??*
do
[ ! -f "$i" ] && continue
case "$i" in
*.sh)
trap - 2 3 20
. $i start
$i start
esac
done
# run the files in /etc/rc.boot
[ -d /etc/rc.boot ] && run-parts /etc/rc.boot
Copy run-parts from your distro to $EMBPART/bin
Adding base scripts
Create a new file reboot containing the following:
#!/bin/sh
echo -n "Rebooting... "
reboot -d -f -i
Create a new file halt containing the following:
#!/bin/sh
halt -d -f -i -p
Create a new file mountfs containing the following:
Creating initial scripts
Compile it.
# default rl.
# single-user mode.
reboot.
work."
cd $EMBPART/etc
rcS.d rc.boot
#!/bin/sh
runlevel=S
prevlevel=N
umask 022
./etc/default/rcS
export VERBOSE
trap ":" 2 3 20
do
case "$i" in
*.sh)
trap - 2 3 20
. $i start
$i start
esac
done
Adding base scripts
#!/bin/sh
reboot -d -f -i
#!/bin/sh
halt -d -f -i -p
诸葛孔明 2009年07月16日
6.1 Preparing ash
6.2 Configuring ash
8.1 Which ones ?
8.2 Copying
8.3 ldconfig
6.1 Preparing ash
6.2 Configuring ash
8.1 Which ones ?
8.2 Copying
8.3 ldconfig
hqgboy 2009年07月22日
考弟兄们英语呢????
考弟兄们英语呢????
alpha321 2010年08月05日
More performance, few words,
as a user instructor.
1. Introduction
1.1 Subject
I made the LEM distro (aka Linux EMbedded) in February 1999. It is a
tiny linux distribution i used with some x86 hardware to make a touch
panel Graphical User Interface to audio, video, conferencing and polling
hardware for ERE Acoustic. It is not hard to make a small linux from
scratch. However, i made this document to spare people losing time
wrestling with many (usefull) docs and howtos. This document describes
how the LEM distro has been made.
1.2 New Versions
The latest version of the document may be found at http:
1.3 History
This document is started for a while but has never been published before
v0.3 because lacking a good structure. Recently, i have discovered
Gerard Beekmans's Linux From Scratch Howto, and decided to rewrite
this document using the structure from the LFS-HOWTO. Luc Herman's and
Paul Moody also granted me to use their jobs to improve this document.
1.4 TODO
...At least a todo section...
1.5 License
Copyright ? 1999,2000 by Sebastien Huet.
This document may be distributed under the terms set forth in the
Linux Documentation Project License at http:://linuxdoc.org
This is free documentation. It is distributed in the hope that it will
be useful, but without any warranty; without even the implied warranty
of merchantability or fitness for a particular purpose.
1.6 Contact
Feel free to send me your informations and comments at
sebhuet@linux-embedded.org.
