BeagleBone Black Cortex-A8 AM335x开发板 最新REV.C
2014年07月04日 14:23    发布者:jia110
原装美国版本,直接美国进货,少量现货!
  产品链接:http://item.taobao.com/item.htm?id=39883226184&ll=2960441481
  BeagleBone Black (Rev C)也是美国版最新版本Rev C
产品特写:
http://gd2.alicdn.com/imgextra/i2/837925103/TB2d7HJXVXXXXXjXXXXXXXXXXXX_%21%21837925103.jpghttp://gd2.alicdn.com/imgextra/i2/837925103/TB2AgDIXVXXXXaBXXXXXXXXXXXX_%21%21837925103.jpghttp://gd1.alicdn.com/imgextra/i1/837925103/TB2vEDHXVXXXXcaXXXXXXXXXXXX_%21%21837925103.jpghttp://gd1.alicdn.com/imgextra/i1/837925103/TB2StPFXVXXXXXBXpXXXXXXXXXX_%21%21837925103.jpghttp://gd1.alicdn.com/imgextra/i1/837925103/TB2FCTHXVXXXXaxXXXXXXXXXXXX_%21%21837925103.jpghttp://gd4.alicdn.com/imgextra/i4/837925103/TB2lr_GXVXXXXcEXXXXXXXXXXXX_%21%21837925103.jpghttp://gd3.alicdn.com/imgextra/i3/837925103/TB2w_jFXVXXXXcNXXXXXXXXXXXX_%21%21837925103.jpg
Beaglebone Black
Description: The Beaglebone Black is a low-cost credit-card-sized development platform with good support from a fast growing community. The Beaglebone Black differs slightly from the regular version by providing you with an onboardmicro HDMIport,512MB of DDR3L DRAM,4GBonboard flash memory, anAM3358processor at 1GHz, and making JTAG optional with a user supplied header. Ultimately, the Beaglebone Black is still perfect for physical computing and smaller embedded applications.
With plenty of I/O and processing power for real-time analysis provided by the TI Sitara?AM3358 ARM? Cortex?-A8processor, Beaglebone Black can be complemented with cape plug-in boards which augment Black’s functionality.They’re called capes because Underdog is a beagle and he wears a cape. Makes sense, right?
At over 3 million Dhrystone operations per second and vector floating point arithmetic operations, Beaglebone Black is capable of not just interfacing to all of your robotics motor drivers, location or pressure sensors and 2D or 3D cameras, but also running OpenCV, OpenNI and other image collection and analysis software to recognize the objects around your robot and the gestures you might make to control it. Through onboard micro HDMI or VGA and LCD expansion boards, it is capable of decoding and displaying multiple video formats utilizing a completely open source software stack and synchronizing playback over Ethernet or USB with other BeagleBoards to create massive video walls. If what you are into is building 3D printers, then Beaglebone Black has the extensive PWM capabilities, the on-chip Ethernet and the 3D rendering and manipulation capabilities all help you eliminate both your underpowered microcontroller-based controller board as well as that PC from your basement.
Note: We are limiting orders to 1 unit, if you require more you will need to contact customer service.
Features:
[*]AM3358 1GHz ARM? Cortex-A8 Processor
[*]4GB 8-bit eMMC Onboard Flash
[*]3D Graphics Accelerator
[*]NEON Floating-Point Accelerator
[*]2x PRU 32-bit Microcontroller
[*]Connectivity:
[*]USB Client for power and communications
[*]USB Host
[*]Ethernet
[*]Micro HDMI
[*]2x 46-pin Headers
[*]Software Compatability
[*]Angstrom Linux
[*]Android
[*]Ubuntu
[*]Cloud9 IDE on Node.js with BoneScript
[*]and More…
Includes:
[*]1x 3ft USB-A to Mini-B USB Cable
Documents:
[*]Schematic
[*]Datasheet(AM3358)
[*]Reference Manual
[*]Beaglebone Black Wiki
[*]Product Page
[*]GitHub
包裝清单:
Beaglebone Black 板 *1
USB线(USB-miniUSB) *1
