【代码】Android开发与PHP进行数据加密传输
2013年08月16日 16:01    发布者:reggae
本文介绍在Android开发中,Android开发应用如何与PHP之间进行加密传输数据,详细的代码请参考本文。
(PS:新建的QQ群,有兴趣可以加入一起讨论:Android学习交流群278744577,验证:eec
java代码:
1 mcrypt = new MCrypt();
2 /* Encrypt */
3 String encrypted = MCrypt.bytesToHex( mcrypt.encrypt("Text to Encrypt") );
4 /* Decrypt */
5 String decrypted = new String( mcrypt.decrypt( encrypted ) );
PHP代码:
1 $mcrypt = new MCrypt();
2 #Encrypt
3 $encrypted = $mcrypt->encrypt("Text to encrypt");
4 #Decrypt
5 $decrypted = $mcrypt->decrypt($encrypted);
MCrypt.java代码:
1 public class MCrypt {
2         private String iv = "fedcba9876543210";//Dummy iv (CHANGE IT!)
3         private IvParameterSpec ivspec;
4         private SecretKeySpec keyspec;
5         private Cipher cipher;
6         private String SecretKey = "0123456789abcdef";//Dummy secretKey (CHANGE IT!)
7         public MCrypt()
8          {
9             ivspec = new IvParameterSpec(iv.getBytes());
10             keyspec = new SecretKeySpec(SecretKey.getBytes(), "AES");
11             cipher = Cipher.getInstance("AES/CBC/NoPadding");
12          }
13         public byte[] encrypt(String text) throws Exception
14          {
15             if(text == null || text.length() == 0)
16                  throw new Exception("Empty string");
17              byte[] encrypted = null;
18                  cipher.init(Cipher.ENCRYPT_MODE, keyspec, ivspec);
19                  encrypted = cipher.doFinal(padString(text).getBytes());
20              return encrypted;
21          }
22         public byte[] decrypt(String code) throws Exception
23         {
24              if(code == null || code.length() == 0)
25                  throw new Exception("Empty string");
26              byte[] decrypted = null;
27                  cipher.init(Cipher.DECRYPT_MODE, keyspec, ivspec);
28                 decrypted = cipher.doFinal(hexToBytes(code));
29              return decrypted;
30          }
31          public static String bytesToHex(byte[] data)
32          {
33              if (data==null)
34              {
35                  return null;
36             }
37             int len = data.length;
38              String str = "";
39              for (int i=0; i 40                 if ((data&0xFF)<16)
41                     str = str + "0" + java.lang.Integer.toHexString(data&0xFF);
42                  else
43                      str = str + java.lang.Integer.toHexString(data&0xFF);
44              }
45              return str;
46         }
47          public static byte[] hexToBytes(String str) {
48             if (str==null) {
49                  return null;
50              } else if (str.length() < 2) {
51                 return null;
52              } else {
53                 int len = str.length() / 2;
54                  byte[] buffer = new byte;
55                  for (int i=0; i 56                      buffer = (byte) Integer.parseInt(str.substring(i*2,i*2+2),16);
57                 }
58                  return buffer;
59              }
60          }
61
62          private static String padString(String source)
63          {
64            char paddingChar = ' ';
65            int size = 16;
66            int x = source.length() % size;
67            int padLength = size - x;
68           for (int i = 0; i < padLength; i++)
69           {
70                source += paddingChar;
71            }
72            return source;
73          }
74      }
mcrypt.php代码:
1 class MCrypt
2 {
3     private $iv = 'fedcba9876543210'; #Same as in JAVA
4     private $key = '0123456789abcdef'; #Same as in JAVA
5
6     function __construct()
7      {
8      }
9     function encrypt($str) {
10       //$key = $this->hex2bin($key);
11        $iv = $this->iv;
12        $td = mcrypt_module_open('rijndael-128', '', 'cbc', $iv);
13        mcrypt_generic_init($td, $this->key, $iv);
14        $encrypted = mcrypt_generic($td, $str);
15        mcrypt_generic_deinit($td);
16        mcrypt_module_close($td);
17        return bin2hex($encrypted);
18     }
19      function decrypt($code) {
20        //$key = $this->hex2bin($key);
21        $code = $this->hex2bin($code);
22        $iv = $this->iv;
23        $td = mcrypt_module_open('rijndael-128', '', 'cbc', $iv);
24        mcrypt_generic_init($td, $this->key, $iv);
25        $decrypted = mdecrypt_generic($td, $code);
26        mcrypt_generic_deinit($td);
27        mcrypt_module_close($td);
28        return utf8_encode(trim($decrypted));
29      }
30     protected function hex2bin($hexdata) {
31        $bindata = '';
32        for ($i = 0; $i < strlen($hexdata); $i += 2) {
33         $bindata .= chr(hexdec(substr($hexdata, $i, 2)));
34        }
35        return $bindata;
36     }
37 }
