LPC812开发板 CortexM0+最小系统板 USB转串口 支持ISP下载
2013年08月05日 17:39 发布者:ivychen225
LPC812开发板——Cortex-M0+最小系统板,USB转串口功能,支持ISP下载。现批量供应,欢迎订购。以下为LPC812开发板产品细节图:
http://img02.taobaocdn.com/imgextra/i2/62273619/T2dqjzXoFaXXXXXXXX_!!62273619.jpg
http://img03.taobaocdn.com/imgextra/i3/62273619/T26aWZXlFbXXXXXXXX_!!62273619.jpg
http://img03.taobaocdn.com/imgextra/i3/62273619/T2vScaXdhXXXXXXXXX_!!62273619.jpg
http://img01.taobaocdn.com/imgextra/i1/62273619/T2.sMaXbJaXXXXXXXX_!!62273619.jpg
LC812开发板背面图:
http://img01.taobaocdn.com/imgextra/i1/62273619/T2xtoaXb4aXXXXXXXX_!!62273619.jpg
http://img01.taobaocdn.com/imgextra/i1/62273619/T2wdn0Xl4aXXXXXXXX_!!62273619.jpg
提供的例子程序如下:
芯片功能
ARM Cortex-M0+ processor - running at frequencies of up to 30 MHz - Nested Vectored Interrupt Controller (NVIC) - System tick timer. - Serial Wire Debug (SWD) and JTAG boundary scan modes supported - Micro Trace Buffer (MTB) supported.Memory: - Up to 16 kB on-chip flash (ISP and IAP via on-chip bootloader software) - Up to 4 kB SRAM - ROM API support: Boot loader, USART drivers, I2C drivers, Power profilesDigital peripherals: - High-speed GPIO interface with up to 18 General-Purpose I/O (GPIO) pins - GPIO interrupt generation capability - Switch matrix for flexible configuration of each I/O pin function - State Configurable Timer (SCT) - Multiple-channel multi-rate timer (MRT) - Self Wake-up Timer (WKT) - CRC engine. - Windowed Watchdog timer (WWDT)Analog peripherals: - Comparator with external voltage referenceSerial interfaces: - 3 USART interfaces - 2 SPI controllers - I2C-bus interfaceClock generation: - 12 MHz internal RC Oscillator (IRC) - Crystal Oscillator (SysOsc) with operating range of 1 MHz to 25 MHz - Programmable watchdog oscillator with a frequency range of 9.4 kHz to 2.3 MHz - 10 kHz low-power oscillator for the WKT - PLL allows CPU operation up to the maximum CPU rate - Clock output function with divider that can reflect various clocksPower control: - Integrated PMU (Power Management Unit) - Reduced power modes: Sleep mode, Deep-sleep mode, Power-down mode, Deep power-down mode - Power-On Reset (POR) - Brownout detectUnique device serial number for identificationSingle power supply板载功能USB转串口,可通过FlashMagic下载程序RGB LED一个功能按键一个可调电阻所有的I/O引出到板边
装箱清单:
LPC812开发板 1块
高速MiniUSB线 1条
开发光盘:附开发环境及所有相关例程,还有相关的手册资料等。
联系QQ:690971654
电话:020-61392789
手机:15360803087
淘宝店:http://mcuworld.taobao.com/
