MKL25Z128开发板freescale CortexM0+开发板USBHost/device 可接U盘
2013年08月05日 17:38 发布者:ivychen225
盈钰电子产品——MKL25Z128开发板闪亮登场,支持USBHost、Device。现已批量供应啦,欢迎订购!http://img03.taobaocdn.com/imgextra/i3/62273619/T2bPwGXlVaXXXXXXXX_!!62273619.jpg_620x10000.jpg
http://img03.taobaocdn.com/imgextra/i3/62273619/T2Q_TSXkdXXXXXXXXX_!!62273619.jpg_620x10000.jpg
http://img02.taobaocdn.com/imgextra/i2/62273619/T2gS9zXfFcXXXXXXXX_!!62273619.jpg_620x10000.jpg
http://img02.taobaocdn.com/imgextra/i2/62273619/T23ukNXoFXXXXXXXXX_!!62273619.jpg_620x10000.jpg
开发板的物理尺寸:44x55.5mm处理器主要参数•Operating Characteristics–Voltage range: 1.71 to 3.6 V–Flash write voltage range: 1.71 to 3.6 V–Temperature range (ambient): -40 to 105°C•Performance–Up to 48 MHz ARM? Cortex-M0+ core• Memories and memory interfaces– Up to 128 KB program flash memory– Up to 16 KB RAM• Clocks– 32 kHz to 40 kHz or 3 MHz to 32 MHz crystal oscillator– Multi-purpose clock source• System peripherals– Nine low-power modes to provide power optimization based on application requirements– 4-channel DMA controller, supporting up to 63 request sources– COP Software watchdog– Low-leakage wakeup unit– SWD interface and Micro Trace buffer– Bit Manipulation Engine (BME)•Security and integrity modules–80-bit unique identification (ID) number per chip•Human-machine interface–Low-power hardware touch sensor interface (TSI)–General-purpose input/output•Analog modules–16-bit SAR ADC–12-bit DAC–Analog comparator (CMP) containing a 6-bit DAC and programmable reference input•Timers–Six channel Timer/PWM (TPM)–Two 2-channel Timer/PWM (TPM)–Periodic interrupt timers–16-bit low-power timer (LPTMR)–Real-time clock•Communication interfaces–USB full-/low-speed On-the-Go controller with onchip transceiver and 5 V to 3.3 V regulator–Two 8-bit SPI modules–Two I2C modules–One low power UART module–Two UART modules开发板的硬件配置USB2.0(全速内置PHY)从设备接口USB2.0(全速内置PHY)主设备接口(主、从共用)USB转串口RGB LED两个功能按键一个可调电阻所有的I/O引出到板边,部分管脚根据功能集中排列
提供的测试程序
装箱清单:
MKL25Z128开发板 1块
高速MiniUSB线 1条
开发光盘:附开发环境及所有相关例程,还有相关的手册资料等。
盈钰工作室:http://www.elechome.com
http://elechome.21ic.org
E-mail:senxin79@126.com
联系QQ:690971654
电话:020-61392789
手机:15360803087
淘宝店:http://mcuworld.taobao.com/
