SM89516芯片解密--芯谷
2010年04月23日 16:48 发布者:chip2010
芯谷芯片解密事业部专业优势提供MICROCHIP单片机、SYNCMOS单片机、ALTERA单片机、ATMEL单片机、VERSACHIPS单片机、HITACHI单片机、NXP单片机、EMC单片机、DALLAS单片机、INTEL单片机、ZILOG单片机、XILINX单片机、WINBOND单片机、Freescale单片机、STC单片机、SST单片机、LATTICE单片机等近五十个系列单片机解密服务。提供SM89516解密等SYNCMOS系列芯片解密服务,依靠我们在SYNCMOS系列芯片解密技术研究领域的丰富经验积累和多年来在解密技术研究中整合的各类技术资源优势,我们能够为客户的每一颗芯片提供极具高效性、可靠性的解密方案。SYNCMOS系列芯片解密是芯谷芯片解密事业部优势解密项目,SM89516是该系列典型芯片型号,有SM89516芯片解密以及其他典型的SYNCMOS系列IC解密需求者欢迎与芯谷芯片解密事业部联系咨询更多解密详情
芯片解密咨询电话:0755-82815425,82816682
The SM89516 series product is an 8 - bit single chip micro controller with 64KB flash & 1KB RAM embedded.It is a derivative of the 8052 micro controller family.With its hardware features and powerful instruction set,it’s straight forward to make it a versatile and cost effective controller for those applications which demand up to 32 I/O pins for PDIP package or up to 36 I/O pins for PLCC/QFP package, or applications which need up to 64KB memory either for program or for data or mixed. To program the on-chip flash memory, a commercial writer is available to do it in parallel programming method.
Features
Working voltage: 3.0V ~ 3.6V For L Version
4.5V ~ 5.5V For C Version
General 8052 family compatible
12 clocks per machine cycle
64 KB internal flash memory
1024 bytes data RAM
Three 16 bit timers/counters
Four 8-bit I/O ports for PDIP package
Four 8-bit I/O ports + one 4-bit I/O ports
for PLCC or QFP package
Full duplex serial channel
Bit operation instruction
Page free jumps
8-bit unsigned division
8-bit unsigned multiply
BCD arithmetic operations
Direct addressing
Indirect addressing
Nested interrupts
Two priority level interrupts
A serial I/O port
Power save modes:
Idle mode and power down mode
Code protection function
One watch dog timer (WDT)
Low EMI (inhibit ALE)
文章来源:http://www.szxpjm.com/ic/SM89516xpjm__xg_112.html
