基于Verilog的串口调试,在Modelsim中仿真正常,但在FPGA开发板上没反应
2012年11月21日 19:23 发布者:x1i2e3
基于Verilog的串口调试,在Modelsim中仿真正常,但在FPGA开发板上用串口调试助手调试没反应,麻烦高手指教一下。万分感谢!顶层文件
module ckdcwj(rst,clk,rxd,txd,data1,nclk);
input rst;
input clk;
input rxd;
output txd;
inout data1;
inout nclk;
wire data1;
wire nclk;
js_rxd u1(.rst(rst), .nclk(nclk), .rxd(rxd), .data1(data1));
fs_txd u2(.rst(rst), .nclk(nclk), .data1(data1), .txd(txd));
nclk u3(.clk(clk), .rst(rst), .nclk(nclk));
endmodule
接受模块
module js_rxd(rst,nclk,rxd,data1);
input rst;
input nclk;
input rxd;
output data1;
reg count1;
reg count2;
reg data;
reg cnt;
reg rec_reg1;
reg rec_reg2;
reg txdone=1'b1;
reg data1;
reg cunt=0;
parameter start=4'b0000,
bit0=4'b1000,
bit1=4'b1001,
bit2=4'b1010,
bit3=4'b1011,
bit4=4'b1100,
bit5=4'b1101,
bit6=4'b1110,
bit7=4'b1111,
stop=4'b0010;
initial cnt<=start;
always @(posedge nclk or negedge rst)
begin
if(!rst)
begin
cunt<=0;
rec_reg1<=1'b1;
rec_reg2<=1'b1;
data<=8'hzz;
end
else if(rec_reg1&&rec_reg2)
begin
rec_reg1<=rxd;
rec_reg2<=rec_reg1;
end
else if(!rec_reg1&&rec_reg2&&cunt==2)
begin
case(cnt)
start:cnt<=bit0;
bit0:begin
if(count1)begin
data<=rxd;
cnt<=bit1;
end
else cnt<=bit0;
end
bit1:begin
if(count1)begin
data<=rxd;
cnt<=bit2;
end
else cnt<=bit1;
end
bit2:begin
if(count1)begin
data<=rxd;
cnt<=bit3;
end
else cnt<=bit2;
end
bit3:begin
if(count1)begin
data<=rxd;
cnt<=bit4;
end
else cnt<=bit3;
end
bit4:begin
if(count1)begin
data<=rxd;
cnt<=bit5;
end
else cnt<=bit4;
end
bit5:begin
if(count1)begin
data<=rxd;
cnt<=bit6;
end
else cnt<=bit5;
end
bit6:begin
if(count1)begin
data<=rxd;
cnt<=bit7;
end
else cnt<=bit6;
end
bit7:begin
if(count1)begin
data<=rxd;
cnt<=stop;
end
else cnt<=bit7;
end
stop:begin
if(count1)begin
if(txdone)
begin
data1<={1'b1,data,1'b0};
cnt<=start;
rec_reg1<=1'b1;
rec_reg2<=1'b1;
cunt<=0;
end
end
end
default:begin
data<=8'hzz;
rec_reg1<=1'b1;
rec_reg2<=1'b1;
end
endcase
end
else cunt<=cunt+1;
end
begin
if(!rst)
begin
count1<=0;
count2<=0;
end
else if(count2==7)
begin
count2<=0;
count1<=1;
end
else begin
count1<=0;
count2<=count2+1;
end
end
endmodule
发送模块
module fs_txd(rst,nclk,data1,txd);
input rst;
input nclk;
input data1;
output txd;
reg count1;
reg count2;
reg txd;
reg count;
wit0=4'b1000,
wit1=4'b1001,
wit2=4'b1010,
wit3=4'b1011,
wit4=4'b1100,
wit5=4'b1101,
wit6=4'b1110,
wit7=4'b1111,
stop=4'b0001;
initial count<=start;
begin
if(!rst)
txd<=1'bz;
else if(!data1) begin
case(count)
start:begin
if(count1)begin
txd<=data1;
count<=wit0;
end
else count<=start;
end
wit0:begin
if(count1)begin
txd<=data1;
count<=wit1;
end
else count<=wit0;
end
wit1:begin
if(count1)begin
txd<=data1;
count<=wit2;
end
else count<=wit1;
end
wit2:begin
if(count1)begin
txd<=data1;
count<=wit3;
end
else count<=wit2;
end
wit3:begin
if(count1)begin
txd<=data1;
count<=wit4;
end
else count<=wit3;
end
wit4:begin
if(count1)begin
txd<=data1;
count<=wit5;
end
else count<=wit4;
end
wit5:begin
if(count1)begin
txd<=data1;
count<=wit6;
end
else count<=wit5;
end
wit6:begin
if(count1)begin
txd<=data1;
count<=wit7;
end
else count<=wit6;
end
wit7:begin
if(count1)begin
txd<=data1;
count<=stop;
end
else count<=wit7;
end
stop:begin
if(count1)begin
txd<=data1;
count<=start;
end
else count<=stop;
end
default:txd<=1'bz;
endcase
end
end
begin
if(!rst)
begin
count1<=0;
count2<=0;
end
else if(count2==7)
begin
count2<=0;
count1<=1;
end
else begin
count1<=0;
count2<=count2+1;
end
end
endmodule
波特率发生模块
module nclk(clk,rst,nclk);
input clk,rst;
output nclk;
reg nclk;
reg cnt;
parameter yu_clk=50000000,
mu_clk=76800;
wire step=yu_clk/mu_clk-1;
always @( clk or rst)
begin
if(!rst)
begin
nclk<=0;
cnt<=0;
end
else if(cnt==step)
begin
nclk<=~nclk;
cnt<=0;
end
else
cnt<=cnt+1;
end
endmodule
仿真结果
