Linear LT3791升降压100W LED驱动方案
2012年09月26日 15:45 发布者:1770309616
Linear公司的LT3791是同步的四开关升压-降压LED驱动控制器,可使VIN高于,低于或等于VOUT,效率高达98.5%,输入电压4.7V-60V,输出电压0-60V,LED电流精度±6%,真彩色PWM和模拟调光,每个IC输入功率100W或大于100W,主要用于汽车前灯/行驶灯和通用照明.本文介绍了LT3791主要特性,方框图,多种应用电路以及演示板DC1666A主要特性,电路图,材料清单和PCB元件布局图,测试电路图.The LT®3791 is a synchronous 4-switch buck-boost LED driver controller. The controller can regulate LED current up to 52V of LED string with input voltages above, below, or equal to the output voltage. The constant-frequency, forced-continuous current mode architecture allows its frequency to be adjusted or synchronized from 200kHz to 700kHz. No top MOSFET refresh switching cycle is needed in buck or boost operation. With 60V input, 60V output capability and seamless transitions between operating regions, the LT3791 is ideal for LED driver applications in automotive, industrial, and even battery-powered systems.
The LT3791 provides input current monitor, LED current monitor, and open or shorted LED fault condition, during which the LT3791 either restarts or latches off.
LT3791主要特性:
4-Switch Single Inductor Architecture Allows VIN Above, Below or Equal to VOUT
Synchronous Switching: Up to 98.5% Efficiency
Wide VIN Range: 4.7V to 60V
Wide VOUT Range: 0V to 60V (52V LED)
±6% LED Current Accuracy: 0V ≤ VLED < 52V
True Color PWM™ and Analog Dimming
LED and Input Current Regulation with Current Monitor Outputs
No Top MOSFET Refresh in Buck or Boost
VOUT Disconnected From VIN During Shutdown
Open or Shorted LED Fault Protection
Capable of 100W or Greater per IC
38-Lead TSSOP with Exposed Pad
LT3791应用:
Automotive Head Lamps/Running Lamps
General Purpose Lighting
图1.LT3791方框图
图2.LT3791效率98% 50W(25V2A)升-降压LED驱动电路图
图3.LT3791效率98.5% 100W(33.3V3A)升-降压LED驱动电路图
演示板DC1666A
Demonstration circuit DC1666A is a synchronous fourswitch buck-boost LED driver controller. It accepts an input voltage from 4.7V to 60V, and drives up to 25V of LEDs at 2A. DC1666A features both PWM and analog dimming of the LED string. It has an OPENLED flag that indicates when the LED string has been removed and it has a SHORTLED flag that indicates that the output has been shorted to GND. In both cases, the IC remains in control and well protected.
DC1666A features very high efficiency at 300kHz switching frequency and continuous conduction mode (CCM). The synchronous four-switch topology both steps up and steps down voltage while regulating up to 50W of constant LED output current at efficiencies up to 98%. The circuit can be altered for applications requiring over 100W of LEDs.
An optional SYNC terminal is provided for synchronizing to an external clock and CLKOUT terminal provides asource to sync another converter to the internal clock of the LT®3791.
Three sense resistors provide constant output current control and monitoring, peak switch current control, and DC input current limit and monitoring. The ISMON and IVINMON outputs tell the user how much current is flowing through the output and input sense resistors.
Small ceramic input and output capacitors are used to save space and cost. The open LED overvoltage protection uses the ICs constant voltage regulation loop to limit the output to approximately 28.3V if the LED string is opened.
For low input voltage operation, the CTRL pin voltage is reduced as the input voltage drops below 6.5V, reducing LED brightness and restraining the peak switch currents in order to limit inductor and switch size. UVLO turns the LEDs off when VIN drops below 4.7V. When input rises above 57.6V, overvoltage lockout turns the switches off to protect them and they turn back on when VIN drops below 56.2V.
DC1666A PWM dimming is simple. The PWM dimming MOSFET turns the LED string on and off with an input to the PWM dimming terminal. For the highest PWM dimming ratio, it is recommended to use 100Hz as a PWM dimming frequency. Information regarding PWM dimming ratios and performance can be found in the Applications Information section of the LT3791 data sheet. Analog dimming is also simple with a simple voltage source on the CTRL terminal.
Modifications can be made to DC1666A in order to convert the board to higher or lower power or from an LED driver to a constant voltage regulator or battery charger. Please consult the factory or the LT3791 data sheet for details.
The LT3791 data sheet gives a complete description of the part, operation and applications information. The data sheet must be read in conjunction with this demo manual for demonstration circuit DC1666A. The LT3791 is assembled in a 38-lead plastic TSSOP package with a thermally enhanced ground pad. Proper board layout is essential for maximum thermal performance. See the Layout Considerations section in the data sheet.
图4.演示板DC1666A电路图
演示板DC1666A材料清单(BOM):
图5.演示板DC1666A测试电路图
详情请见:
89040和
89041
来源:网络
LT3791:升降压100W LED驱动方案
Linear公司的LT3791是同步的四开关升压-降压LED驱动控制器,可使VIN高于、低于或等于VOUT,效率高达98.5%,输入电压4.7V~60V,输出电压0V~60V,LED电流精度±6%,真彩色PWM和模拟调光,每个IC输入功率100W或大于100W。主要用于汽车前灯/行驶灯和通用照明。
其连续恒定频率和强制恒定电流模式架构,使其可以进行调整,或同步200kHz~700kHz的频率。在降压或升压操作时无需顶部MOSFET开关循环周期。该器件为60V输入,60V输出。和工作区域之间的无缝转换,使LT3791成为LED驱动器在汽车、工业、电池供电系统的较理想选择。
LT3791在重新启动或闭锁时,具有输入电流监控器,LED电流监控器,以及LED开路或短路保障。
95966
图1 LT3791方框图
LT3791主要特性
• 4开关单电感器架构允许VIN高于,低于或等于VOUT
• 同步切换:效率高达98.5%
• 4.7V~60V的宽VIN范围:
• 宽VOUT范围:0V~60V(52V LED)
• ±6%的LED电流精度:0V≤VLED<52V
• True Color PWM和模拟调光
• LED电流监视器输出和输入电流调节
• 在降压或升压时无Top MOSFET刷新
• 在关机时,VOUT与 VIN断开
• 开路或短路LED故障保护
• 每IC 100W或更高的
• 带裸焊盘的38引脚TSSOP
LT3791应用
• 汽车头灯/行车灯
• 通用照明
95965
图2 LT3791效率98% 50W(25V2A)升-降压LED驱动电路图
95964
图3 LT3791效率98.5% 100W(33.3V3A)升-降压LED驱动电路图
95963
图4 DC1666A演示板电路图
演示板DC1666A
DC1666A演示电路是一个同步四开关降压-升压型LED驱动器控制器。它的输入电压为4.7V~60V,最高驱动2A、25V的LED。 DC1666A具有LED串的PWM和模拟调光功能。当LED串被移动时,它的OPENLED标志显示;当输出短路到GND时,它的SHORTLED标志显示。在这两种情况下,该IC保持控制,并有良好的保护。
DC1666A具有非常高的效率,其开关频率为300kHz,并具有连续导通模式(CCM)。其同步四开关拓扑结构,在调节50W恒定LED输出电流时(升压和降压),效率高达98%。该电路可以变化,用于超过100W的LED的应用。一个可选的SYNC端子,用于同步一个外部时钟和CLKOUT终端,并提供了另一个转换器和内部时钟(LT3791)的同步资源。三个检测电阻器提供了恒定的输出电流控制和监测、峰值开关电流控制和DC输入电流限制和监控。其ISMON和IVINMON输出可以告诉用户有多少电流流经输出和输入的感测电阻。小陶瓷输入和输出电容器,以节省空间和成本。 LED开路过压保护采用了IC恒定电压调节环路,以限制输出(大约28.3V,如LED串被打开)。对于低输入电压操作,当输入电压低于6.5V时,CTRL引脚电压被降低,并降低了LED的亮度和限制峰值开关电流,以限制电感和开关的大小。 当VIN降至低于4.7V时,UVLO将LED关闭。当输入上升到高于57.6V时,过压闭锁功能将开关关闭作为保护,当VIN降至56.2V时,重新开启。
DC1666A PWM调光则很简单,PWM调光MOSFET利用PWM调光终端的输入来导通和关闭LED串。对于最高的PWM调光比,建议使用100Hz作为PWM调光频率。对于PWM调光比和性能的信息,可以参见应用信息部分的LT3791数据表。模拟调光也很简单,采用一个简单的CTRL终端电压源。
DC1666A可以作出修改,以转换该板到更高或更低的功率,或者以一个LED驱动器到一个恒定的电压调节器或电池充电器。
LT3791数据表给出了一个完整的,操作和应用信息的描述。数据表必须和使用手册一并阅读,以了解DC1666A电路。LT3791组装在一个38引脚塑料TSSOP封装里,并具有耐热增强型地垫。正确的电路板布局对热性能是必不可少的。
(中电网、《世界电子元器件》)
