Avnet ISM网络FMC模块解决方案
2012年08月18日 10:23 发布者:1770309616
Avnet公司的ISM网络FMC模块能和任何的Avnet 或Xilinx有FMC功能的基板一起工作,采用FMC低引脚连接器连接到载板.具有两个IEEE1588兼容的10/100以太网接口,两个CAN接口,RS485 接口和RS-232接口,主要用于工业,科学和测量系统.本文介绍了ISM网络FMC模块主要特性,方框图,以太网方框图以ISM网络FMC模块电路图和材料清单.The industrial networking FMC module adds key interfaces to support a wide range of industrial, scientific and measurement requirements. From dual 1588 compatible 10/100 Ethernet PHYs, to CAN, RS232, and RS485, the ISM Networking FMC can quickly get you started with either Spartan-6 or Virtex-6 based designs.
The ISM Networking FMC Module is designed to operate with any Avnet or Xilinx base board that is FMC enabled. The module uses an FMC Low Pin Count (LPC) connector to interface to the carrier board. The industrial networking FMC module adds key interfaces to support a wide range of industrial, scientific and measurement requirements.
ISM网络FMC模块主要特性:
Board I/O Connectors
— FMC LPC connector
— (2) 8-pin GPIO headers (one per PHY)
— 9-pin female DB9 for RS-232 communications
— RJ-45 connectors for Ethernet communications
Miscellaneous I/O Connectors
— 4-position user selectable DIP switch
— 6-pin Digilent header
— 6-pin PHY JTAG header
Memory
— EEPROM #1: used as module identification for FMC compliance
— EEPROM #2: used for EtherCAT configuration storage
Communication
— Dual IEEE 1588 compatible 10/100 Ethernet interfaces
— Dual CAN interfaces
— RS485 interface
— RS-232
图1.ISM网络FMC模块外形图
图2.ISM网络FMC模块方框图
图3.以太网方框图
图4.ISM网络FMC模块电路图(1)
图5.ISM网络FMC模块电路图(2)
图6.ISM网络FMC模块电路图(3)
图7.ISM网络FMC模块电路图(4)
图8.ISM网络FMC模块电路图(5)
图9.ISM网络FMC模块电路图(6)
ISM网络FMC模块材料清单:
详情请见:
https://www.em.avnet.com/Support%20And%20Downloads/ism_networking_fmc_module-ug-reva062910.pdf
和
https://www.em.avnet.com/Support%20And%20Downloads/ism_networking_fmc_module-sch-reva052810.pdf
以及
https://www.em.avnet.com/Support%20And%20Downloads/ism_networking_fmc_module-bom-reva041910.pdf
来源:网络
