PCB及PCBA缺陷中英文对照表 PCB制作流程英语表达
2012年08月02日 09:30 发布者:premier_nana
1内层开路Inner open 2内层断路Inner short
3外层开路Outer open
4外层断路Outer short
5内层蚀刻过度Inner over ecthing
6外层蚀刻过度Outer over ecthing
7内层树脂气泡Resin void
8内层杂物Foreign material
9内层图形移位Inner pattern mis-registration
10层与层移位Layer to layer mis-registration
11打孔不良Improper targeting
12内层蚀刻不净Inner under etching
13露布纹Weave texture/exposure
14檫花(氧化膜面)Scratch(Oxide surface)
15板损坏Damaged board
16分层(物料)Delamination (Raw material)
17内层不配套Excessive inner core
18板过厚Over thickness
19白点(压板)Measling (Pressing)
20白点(喷锡)Measling (HSAL)
21板曲Warpage
22板焦黄Burnt
23起皱Wrinkle
24起泡(压板)Blistering (Pressing)
25镀层起泡Blistering (Cu plating)
26喷锡起泡Blistering (HSAL)
27板面凹痕DENT (Pressing profilling G/F)
28白斑Crazing
29胶渣Gum residue
30孔未穿Incomplete drilling
31披锋Burr
32多孔Extra hole
33偏孔Hole shift
34孔径大Hole oversize
35孔径小Hole undersize
36少孔Missing Hole
37塞孔Block hole
38崩孔Hole breakout
39孔粗糙(镀铜)Hole roughness(Cu plating)
40孔粗糙(机械钻孔)Hole roughness(mechanical drill)
41崩线、线路缺口Nick / void on trace
42缺口Nick / void on pad
43曝光过度Over-exposure
44曝光不良Under exposure
45显影不足Under develop
46干膜脱落D/F Peel off
47干膜碎D/F Rdsidue
48干膜移位D/F Mis-registration
49标志不清(曝光)Illegible marking (exposure)
50错菲林Wrong A/W
51非镀铜孔有铜Copper in NPTH
52镀铜孔内无铜No copper in PTH
53渗镀Nickel smear
54电镀粗糙Rough plating
55孔壁缺口Hole void (Cu)
56金手指颜色不良Gold Finger discoloration
57金面颜色不良Gold discoloration
58金面阴阳色Two tone colour on gold surface
59铜、镍脱落Copper/Nickel peel off
60铜镀层厚度超要求Copper thickness out of requirement
61漏镀(金手指等)Skip plating(G/F ENIG Cu)
62金面污点Stain on gold surface
63电镀针孔Plating pits (Cu)
64镀锡缺点Tin plating defect
65铜碎Copper residue
66黑孔Black Hole
67镀层白渍Plating haze
68金手指凸出Protrusion (G/F)
69板污Board contamination
70手指套Glove mark
71褪锡不良Improper Tin stripping
72微短路Micro short
流程简介:开料Cut Lamination--钻孔Drilling--干膜制程Photo Process(D/F)--压合Lamination--减铜Copper Reduction--电镀Horizontal Electrolytic Plating--塞孔Plug Hole--防焊(绿漆/绿油)Solder Mask--镀金Gold plating--喷锡Hot Air Solder Leveling--成型Profile--开短路测试Electrical Testing--终检Final Visual Inspection
PCB英语术语 PCB英语表达 PCB制作流程英语 PCB中英对照 PCB英语
更多信息 可以见我新浪博客哈
http://blog.sina.com.cn/u/1747420037
dddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddd
