Rust 0.3 发布,Mozilla 的编程语言
2012年07月13日 12:05 发布者:1770309616
Rust 0.3 发布了,Rust 是 Mozilla 目前正在开发一个新的编程语言,由web语言的领军人物Brendan Eich(js之父),Dave Herman以及Mozilla公司的Graydon Hoare 合力开发。创建这个新语言的目的是为了解决一个很顽疾的问题:软件的演进速度大大低于硬件的演进,软件在语言级别上无法真正利用多核计算带来的性能提升。Rust是针对多核体系提出的语言,并且吸收一些其他动态语言的重要特性,比如不需要管理内存,比如不会出现Null指针等等。
Rust 0.3 Changes:
* ~1900 changes, numerous bugfixes
* New coding conveniences
* Integer-literal suffix inference
* Per-item control over warnings, errors
* # and # attributes
* Documentation comments
* More compact closure syntax
* 'do' expressions for treating higher-order functions as
control structures
* *-patterns (wildcard extended to all constructor fields)
* Semantic cleanup
* Name resolution pass and exhaustiveness checker rewritten
* Region pointers and borrow checking supersede alias
analysis
* Init-ness checking is now provided by a region-based liveness
pass instead of the typestate pass; same for last-use analysis
* Extensive work on region pointers
* Experimental new language features
* Slices and fixed-size, interior-allocated vectors
* #!-comments for lang versioning, shell execution
* Destructors and iface implementation for classes;
type-parameterized classes and class methods
* 'const' type kind for types that can be used to implement
shared-memory concurrency patterns
* Type reflection
* Removal of various obsolete features
* Keywords: 'be', 'prove', 'syntax', 'note', 'mutable', 'bind',
'crust', 'native' (now 'extern'), 'cont' (now 'again')
* Constructs: do-while loops ('do' repurposed), fn binding,
resources (replaced by destructors)
* Compiler reorganization
* Syntax-layer of compiler split into separate crate
* Clang (from LLVM project) integrated into build
* Typechecker split into sub-modules
* New library code
* New time functions
* Extension methods for many built-in types
* Arc: atomic-refcount read-only / exclusive-use shared cells
* Par: parallel map and search routines
* Extensive work on libuv interface
* Much vector code moved to libraries
* Syntax extensions: #line, #col, #file, #mod, #stringify,
#include, #include_str, #include_bin
* Tool improvements
* Cargo automatically resolves dependencies
Rust 的下载地址:请点这里
文/开源中国
